My new Fusion - Lagoon chairs from Roman - Page 59 - AVS Forum | Home Theater Discussions And Reviews
 147Likes
post #1741 of 1804 Old 03-14-2019, 05:17 AM
rsh
rsh's Avatar
Quoted: 155 Post(s)
Liked: 92
Ladeback,
Sorry to hear about the surgery. I hope it is not anything serious, and wish you quick recovery.
I would definitely opt to move the door from the back to the side wall. This will give you more space for the bar or seating width and depth wise.
In terms of how many chairs in a row you would want - it would depends on how wide and deep your room is, and how many seats in your theater you would ultimately want.
Remember, you need at least 2 feet for each isle (with the door on the side your back row of seating gets more width - no isles needed), and at least 6 - 6.5 foot depth for the second row seating platform.
Roman
rtheaters.com
FusionCollectionSeating.com
Ultimate Home Entertainment
rsh is offline
post #1742 of 1804 Old 03-14-2019, 11:32 AM
Ladeback's Avatar
Quoted: 1298 Post(s)
Liked: 465
Send a message via MSN to Ladeback
Originally Posted by rsh View Post
Ladeback,
Roman,
It is not serious, I had some weight loss surgery and am trying to get healthier so I will be around longer I hope.
As for the room it is 14'x25'-9"x8'-6". I am looking to going from a fixed 120" 16:9 screen first row eyes to screen is 11' to a 153" 2.39:1 AT screen with first row eyes to screen 11'. With this set up I figure I could do either 2 rows with a bar or two rows. Just not sure if 2 rows of 4 will work. I know the Jive is 21.5 and my current recliner I set in is that wide and fit just fine. I was thinking ether going with a couch in the Jive lOOOOl or the four seat with center love seat lOlOOlOl and for the second row a regular 4 seat lOlOlOlOl. If I go with the the two rows of three and a bar a was thinking of going with the Lagoon 1011. I also like the Tribute 1015, because of the adjustable headrest.
On the leather/vinyl combo, what part is leather and what part is vinyl? Not sure when I would need them. May do one row and use what three chairs I have in the room now if I went with the three row set up.
Here are my two room designs based on the door just past the middle.
ID:	2538924   Click image for larger version
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #1743 of 1804 Old 03-14-2019, 12:03 PM
rsh
rsh's Avatar
Quoted: 155 Post(s)
Liked: 92
Good for you.
ok, here are my thoughts:
1. With 14 foot wide room, and 2 foot isles (that is all you really need), you will have 10'=120" for the chairs. You do not have to go with the IOOOOI configuration.
You can do any of the following:
Lagoon-1011
Straight set of 4 with the loveseat in the middle IOIOOIOI - 118" wide
Jive-1013
Straight set of 4 with the arms in between IOIOIOIOI - 114.25" wide
Straight set of 4 with the loveseat in the middle IOIOOIOI - 109" wide
Curved set of 4 with the loveseat in the middle IOVOOVOI - 115.25" wide
Tribute-1015
Straight set of 4 with the loveseat in the middle IOIOOIOI - 120" wide
Streamline-1017
Straight set of 4 with the loveseat in the middle IOIOOIOI - 121" wide
2. With 25 foot long room, you can do a bar in the back - will take 4-5 feet, leaving you with 20-21 feet for the 2 rows of seats, which is more than enough. if you build a 12' deep riser from the back of the room and use 5' for the bar area, it will place your front row of seats 13' away from the screen. This is just a example. You can play around with the numbers and do what works best. It is definitely doable.
Roman
rtheaters.com
rsh is offline
post #1744 of 1804 Old 03-14-2019, 12:22 PM
Moebius's Avatar
Quoted: 224 Post(s)
Liked: 139
Since you're room dimensions are very close to mine minus the sloped ceiling (I'm at 14x24), you've got some options to work with. With eyes at 11', the back of the front row would sit at roughly 12'. 6' riser takes you to 18', leaving 7' for a bar behind. You'll want to tailor the bar size to allow room behind (especially if you're not able to move the door as you plan).
A couple of thoughts/questions. How many people are you looking to seat most regularly? For example, if you wanted to have a little more room for a bar, you could do what several folks around here (myself included) have done and use theater style seats for the second row as overflow. However, if you'd be having more than just the front row as the norm rather than exception, that might not be as preferable, so you're back to 2 rows of recliners.
If you want a basic perspective since our rooms are pretty close. I have a front row of 4 Fusion Jives with eyes at 11' from screen (12' from wall) from the screen, a 5' riser with 4 theater seats which allows plenty of room to move around seated people, then a standing bar immediately behind the riser (in fact mounted to the back of the riser) that is 14" deep and sits about 46" from the back wall.
Remember, no matter where you go... You're not where you were anymore.
HJ Movie House Build Thread
Moebius is offline
post #1745 of 1804 Old 03-14-2019, 04:11 PM
Ladeback's Avatar
Liked: 465
Thanks guys for the input.
Moebius, most of the time it will just be my wife and I maybe another couple or two for movie nights. The bar is more for overflow or when I am just want to sit up high as md maybe mess around with my laptop in the theater. I have thought of the regular movie seats, but I would have them in the front row. I want the second row especially the middle seat MLP to the place to sit, so I want the good seats there. If I went with a 133" 16:9 regular screen I could have more room for the bar area.
Roman, I know what your you mean by I could fit the full Jive or others in there, was just thinking it would be nice to watch football in the theater and be laying on a couch. That's the reason I was going for it. The other option would be with the love seat 4 seat in the front and a regular 4 seat in the second row. Now not sure how often I would fill 8 to 12 seats if I went three rows of 4, but it would be cool.
Thanks again for the help.
Ladeback is offline
post #1746 of 1804 Old 03-15-2019, 07:01 AM
rsh
rsh's Avatar
Quoted: 155 Post(s)
Liked: 92
I would not do the 4 seat couch configuration. These are very comfortable recliners, and after your sit in them and see that you are able to adjust your reclining position to your liking you would never need to lay across that couch. Also with the couch you have to have armless pieces, and you loose the armrest with the storage compartment, tray table and USB port. Chair/loveseat/chair would be much better solution. if you want to have a loveseat.
Ladeback likes this.
Roman
rtheaters.com
rsh is offline
post #1747 of 1804 Old 03-15-2019, 08:28 AM
Moebius's Avatar
Quoted: 224 Post(s)
Liked: 139
To add to what Roman said, I'll second the no couch idea. We use the 2 chair/loveseat combo and have been VERY happy with it. When we've got company over, the armrest goes in, and while it does narrow the seat a bit, unless you're ogre sized like me, it's not that much. But when it's just the wife and me, we pull it out and snuggle up in the loveseat with the recliners back. Heck, there are even times when I've been alone, sat in the loveseat section and reclined both seats so I could stetch out a bit sideways.
Moebius is offline
post #1748 of 1804 Old 03-15-2019, 12:02 PM
Ladeback's Avatar
Liked: 465
Thanks for the input. I am currently a very large guy, working on trying to get smaller. If I get small enough we should be able leave the armrest in or out. Not sure when I would be ready though. It will be a while.
Ladeback is offline
post #1749 of 1804 Old 03-16-2019, 07:56 AM
Moebius's Avatar
Quoted: 224 Post(s)
Liked: 139
If you want a basis for comparison, I'm 6'7", and maxed out at 375lb (down about 35 since I decided enough was enough in November). With the armrest in place, it does come up against my legs, but in all honesty the only time we use it is with company, and we're usually giving the company the prime seats anyway, so I rarely sit there when it's in place.
Moebius is offline
post #1750 of 1804 Old 03-16-2019, 08:45 AM
Ladeback's Avatar
Liked: 465
I am currently 6' 394 working to getting into the low 200's. I'm a ways off from needing seats.
One question other question; we want leather, I take the main sitting area and the arm rest are leather and the sides and backs are vinyl?
Sent from my SM-N960U using Tapatalk
Ladeback is offline
post #1751 of 1804 Old 03-18-2019, 04:42 AM
rsh
rsh's Avatar
Quoted: 155 Post(s)
Liked: 92
The chairs we stock are mostly in top grain leather on all the surfaces you touch, and matching vinyl on the sides of the chair arms and very back of the chairs.
I do have a set or two in ALL TOP GRAIN leather, and if necessary any of our style groups can be done this way as a custom order in variety of colors.
Roman
rtheaters.com
rsh is offline
post #1752 of 1804 Old 04-05-2019, 06:08 PM
rsh
rsh's Avatar
Quoted: 155 Post(s)
Liked: 92
Gamingphreek,
Have you finished your room?
Do you have any more pictures?
Roman
rtheaters.com
rsh is offline
post #1753 of 1804 Old 04-09-2019, 09:25 AM
Liked: 2
Last week I took delivery of 4 Escape chairs. I live close to the warehouse so I was able to test all the models first - but for me the Escape was the best choice. I am 6'3" so the powered headrest was the killer feature. We got the black top grain leather.
These chairs look awesome in our room. We love them. They are extremely comfortable. I love the deep arm storage and the tables. Might order an LED light.
I sit about 8'10" from a 75" Vizio TV. the 4K looks amazing, but regular TV (DirecTV 720P content) is not that great at that distance. I am waffling about returning the 75" for a 65". Can't figure out what to do. any suggestions?
Nothing to add about the customer service with Roman - all good. If you are considering the Escape chairs go for it, you will not be disappointed.
jonrud12 is offline
post #1754 of 1804 Old 04-09-2019, 10:15 AM
tcramer's Avatar
Quoted: 386 Post(s)
Liked: 203
My suggestion - don't ever go smaller! DirecTV will still not look any better, just a smaller picture. I think the trade off of slightly more up scaled artifacts for a larger picture is worth it.
tcramer is offline
post #1755 of 1804 Old 04-09-2019, 11:37 AM
trey99's Avatar
Liked: 0
Great Chairs
I purchased 6 of the Escape chairs and I've been extremely happy with them. I was originally looking at the other models, but after driving from DC to test out the chairs in NJ, I really had to have the Escape's. They are extremely comfortable and the ability to move the neck support is awesome. We also bought quite a few of the accessories and they've been great. I bought:
  • flexible tray table - seems pretty nice but we really don't use the tables for much of anything
  • wine glass holder - work really well and very sturdy
  • LED light - produces just the right amount of light to illuminate a notebook without destroying everyone else's experience
I'm 6'2" 200 lbs and my wife is 5'7" 120 lbs and the chairs work great for both of us. My young kids love them too but they'd probably be fine in anything.
Based upon space constraints I had to push my chairs off to one side and it's been working fine. I'm also planning to put in a platform for the back chairs but haven't quite gotten to it yet.
Roman was extremely helpful with all of my questions. The shipping and white glove delivery worked great. I did not have any issues and would definitely recommend the product and the team.
ID:	2550860   Click image for larger version
trey99 is offline
post #1756 of 1804 Old 04-10-2019, 08:10 AM
rsh
rsh's Avatar
Quoted: 155 Post(s)
Liked: 92
Trey,
I really like your room - very clean modern look, and the ceiling looks cool as well.
Roman
rtheaters.com
rsh is offline
post #1757 of 1804 Old 04-10-2019, 08:54 AM
Liked: 0
Originally Posted by FGPass View Post
Just placed my order for 9 Lagoon 1011's! Doing a row of 5 straight in the back and a row of 4 with center love seat. Pics/review to come (when my theater is done). Roman is the man!
Just realized I never posted my update when things got done. Still some work to do in the room but the seats are great, especially for the price and how many I needed!
I think my only comment is I wish I could somehow mount them to each other so they don't move when my kids decide they want to jump over them.
FGPass is offline
post #1758 of 1804 Old 04-10-2019, 10:01 AM
Ladeback's Avatar
Liked: 465
Nice chairs and great looking room.
What is your room dimensions and what size is your screen?
Ladeback is offline
post #1759 of 1804 Old 04-15-2019, 07:06 AM
rsh
rsh's Avatar
Quoted: 155 Post(s)
Liked: 92
I do not believe the chairs that are on the carpet will move, but if you really want to physically have them attached one to another, you can get heavy duty wire ties, and tie metal frames under the chairs together.
Roman
rtheaters.com
rsh is offline
post #1760 of 1804 Old 04-22-2019, 05:55 AM
trey99's Avatar
Liked: 0
My room is 20' x 13.5' and the screen is 135" diagonal.
trey99 is offline
post #1761 of 1804 Old 04-22-2019, 11:12 AM
howiee's Avatar
Quoted: 35 Post(s)
Hi Roman,
Do you have an idea of recommended distance between Fusion Jive rows?
howiee is offline
post #1762 of 1804 Old 04-22-2019, 11:33 AM
Ladeback's Avatar
Liked: 465
Originally Posted by howiee View Post
Hi Roman,
I was just looking at the Jive's and they seem top be 65" fully extended and need 4" to 6" space needed behind them from a wall and I would give them at least 6" space from the front row so those with long legs don't put their feet into the back of the front row. I was going to go with a 84" deep riser, but you could probably get away with 78" to 80" from the front row.
I am still interested in what Roman has to say as well to see if I am close or way off.
Ladeback is offline
post #1763 of 1804 Old 04-22-2019, 11:42 AM
rsh
rsh's Avatar
Quoted: 155 Post(s)
Liked: 92
My recommendation would be at very minimum 6 (preferably 6.5) foot deep riser. While 65" include those additional inches you need behind the chair for full recline, if you place the front row of seating up against the riser, the chairs will overhang the riser a bit, so you need extra depth. If you have the space I would recommend even longer riser, so you can push the back row of seating away from the back wall for better surround sound.
Roman
rtheaters.com
rsh is offline
post #1764 of 1804 Old 04-22-2019, 01:20 PM
Quoted: 5489 Post(s)
Liked: 5075
why you should oversize your riser, the fronts row leans back and your pontoons extend past the edge. I always use 6 1/2 ft as a minimum, if you can you also don't want to sit close to the rear wall. Your low frequencies will be quite boomy. If you can, make it at least 8ft and keep the chairs well in front of the wall.
post #1765 of 1804 Old 04-22-2019, 01:28 PM
howiee's Avatar
Quoted: 35 Post(s)
Cheers guys. Just to clarify as I don't fully understand - you mean the total depth of the riser and not ~6.5 feet between the rows?
In one of the plans i'm putting together the back of the 2nd row is 3.5ft from the back wall (not reclined), which i'm hoping is decent enough for surround sound.
howiee is offline
post #1766 of 1804 Old 04-22-2019, 01:32 PM
rsh
rsh's Avatar
Quoted: 155 Post(s)
Liked: 92
Yes, the riser depth is what we are referring to.
That would be perfect.
howiee likes this.
Roman
rtheaters.com
rsh is offline
post #1767 of 1804 Old 04-22-2019, 01:45 PM
howiee's Avatar
Quoted: 35 Post(s)
Thanks, Roman.
howiee is offline
post #1768 of 1804 Old 04-24-2019, 08:39 AM
rsh
rsh's Avatar
Quoted: 155 Post(s)
Liked: 92
You are very welcome.
Let us know if you have any other questions.
Roman
rtheaters.com
rsh is offline
post #1769 of 1804 Old 04-26-2019, 07:37 AM
rbouch8828's Avatar
Quoted: 54 Post(s)
Liked: 50
Fusion Jive Seating Midnight Blue
With lots of help from Roman along the way, I finally have my 8 Fusion Jive Midnight Blue Reclining seats with Buttkickers and trays, wine glass holders, iPad Tablet holder, set up and fully functional.
We are now enjoying 4K movies and other video sources in both Blue-ray and streaming video from Xfinity, Apple TV, Netflix, Prime, etc., in our new Dolby Atmos theater.
ID:	2558420   Click image for larger version
ID:	2558422   Click image for larger version
BIGmouthinDC and Ladeback like this.
rbouch8828 is offline
post #1770 of 1804 Old 04-26-2019, 09:24 AM
Ladeback's Avatar
Liked: 465
I was wondering what the Jive dual love seats looked like in a narrow theater. Mine will be 14' so this would work or nicely. I really like the blue theme as well.
Ladeback is offline
Reply Theater Room Items & Accessories
