Berkline reclining chair problem - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 31 Old 11-09-2011, 06:44 PM - Thread Starter
imblind's Avatar
When I press the recline button, it makes the click sound and moves the chair just an inch. If I press the button again, same thing. I have to press the button about 50 damn times to get the chair to recline in little increments. Do you think it's the motor or the control box?
CIAR SpA 61100 Type: LM25 motor
CIAR SpA 61100 Type SU15 box
imblind is offline
post #2 of 31 Old 11-10-2011, 05:52 AM
rsh
rsh's Avatar
Quoted: 218 Post(s)
Liked: 196
Ciar components are made in Italy and was used by Berkline on some of the recliners in the past. They switched and began using the power components kits made by Refined at some point of time. I have no idea where to find the CIAR components, but I just had someone with similar problem. I sent him an actuator made by Refined to try if it would work.
Roman
rtheaters.com
FusionCollectionSeating.com
Ultimate Home Entertainment
rsh is offline
post #3 of 31 Old 11-11-2011, 08:02 AM - Thread Starter
imblind's Avatar
Do you think my problem is with the actuator or with the control box?
imblind is offline
post #4 of 31 Old 11-11-2011, 08:05 AM
rsh
rsh's Avatar
Quoted: 218 Post(s)
Liked: 196
It is hard to say, but I think it is a power control box. If you have another chair you can swap them and test for that.
Roman
rtheaters.com
rsh is offline
post #5 of 31 Old 11-15-2011, 09:40 AM - Thread Starter
imblind's Avatar
I swapped over the control boxes, same behavior. It must be the actuator. Can local electronics shops rebuild these or do I need to buy a new one? (If that's even possible anymore)
imblind is offline
post #6 of 31 Old 11-15-2011, 10:02 AM
rsh
rsh's Avatar
Quoted: 218 Post(s)
Liked: 196
I think you would need a new one...
Roman
rtheaters.com
rsh is offline
post #7 of 31 Old 11-22-2011, 05:41 PM
rsh
rsh's Avatar
Quoted: 218 Post(s)
Liked: 196
FYI: One of my customers who had CIAR transformer and actuator just replaced the CIAR actuator with the one from REFINED and here is what he wrote to me:
Roman,
I installed the actuator and it was basically a direct replacement for the Ciar unit, same connector, mount points etc. The only slight difference is that when the chair is full upright the foot rest doesn't retract 100% as before, it probably closes 98%, it does leave a small gap but almost not noticeable.
I was looking at the mounting bracket (where the actuator bolts to the chair) and it looks like you could easily take it off and put a slight bend in it to make it close all the way but the small gap didn't bother my wife or I so we just left it.
Roman
rtheaters.com
rsh is offline
post #8 of 31 Old 11-23-2011, 03:06 PM
mccabekyle's Avatar
Good info in this thread. I assumed that the Refined actuator would pretty much be "plug n play" with the CIAR. As far as I can tell, the components are virtually the same, from the switches to the transformers to the actuators themselves.
Kyle McCabe
Carolina Interiors Home Decor
Theater Seating Specialist
mccabekyle is offline
post #9 of 31 Old 11-23-2011, 03:30 PM
rsh
rsh's Avatar
Quoted: 218 Post(s)
Liked: 196
Nope - the transformer is different. The REFINED transformer that Berkline used in their chairs(except for the last containers that were shipped in 2010/2011) was bigger and bulkier. If someone has a problem with the transformer they can still use the one from REFINED, but would need to figure out a way of mounting it since the CIAR will have different mounting bracket.
Roman
rtheaters.com
rsh is offline
post #10 of 31 Old 12-06-2011, 06:56 AM
Sakislayer's Avatar
FYI -- if you need a replacement part from CIAR -- you can call Ultra-Mek Inc. in Denton NC -- ask for "MONICA"...... her number is 336-859-4552.
I e-mailed CIAR in Italy about getting a replacement transformer for my Berklines and they are the ones who gave me the contact info for Ultra-Mek.
Sakislayer is offline
post #11 of 31 Old 03-13-2020, 09:35 PM
Jim Cutter's Avatar
Quoted: 202 Post(s)
Liked: 192
So has anyone found a replacement for this issue? I had one of my Berkline chairs stop reclining. I swapped the large motor labeled "CIAR SpA 61100 Pesaro" with another chair and it worked so I know that it's this part. I've looked everywhere I can think of for a replacement with no luck. Can anyone help?
Theater Room - JVC RS2000, Dalite 148" Scope, Pioneer SC-65, Panasonic UB820, Energy APS 5+2(2), Energy AC 300(1), Energy CR-3(4), PSA 15"Sub(2)
Sports Room - JVC RS4810, Dalite 106" 16:9, Onkyo TX-SR875, Oppo BDP-103, Energy C-7(2) w/Energy S8.2(2), Energy C-C3(1) w/Energy S10.2(1), Energy CR-3(3), Energy S12.3
Jim Cutter is offline
post #12 of 31 Old 03-17-2020, 02:43 PM
Quoted: 6564 Post(s)
Liked: 6435
we don't know what part you are talking about. and just because the motor works doesn't pinpoint the problem, could be the switch, a sensor, the wiring, the transformer, and even the outlet.
post #13 of 31 Old 03-17-2020, 11:22 PM
Jim Cutter's Avatar
Quoted: 202 Post(s)
Liked: 192
That's why I described it and listed the part name and number. It's a large cube about 4"x4"x4" in size. I know it's the part that is bad because I swapped it with another chair and it worked okay.
post #14 of 31 Old 03-18-2020, 12:15 PM
Liked: 6435
"I swapped the large motor labeled "CIAR SpA 61100 Pesaro" with another chair and it worked"
I thought you meant you moved the motor to another chair and it worked, got it, you brought in another motor and it worked.
there is one listed on an international ebay site, 50 euros
https://www.ebay-kleinanzeigen.de/s-...07648-226-1926
One for sale:
https://archiwum.allegro.pl/oferta/s...595488524.html
post #15 of 31 Old 04-21-2020, 08:51 AM
Liked: 0
Exclamation Berkline Theatre Chiars wont recline after moving them
We have a set of 3 Berkline Theatre Chairs. They were working perfectly. We moved homes last night and I was careful to unplug all parts of the chairs to detach the seat backs for moving. We were very careful when moving all pieces. All cords have been reattached correctly and seat back placed back on. The two outside chairs will not recline after the move. The center chair will recline still. Also, all other components will work on the outside chairs (heat/massage). Neither outside chair will recline at all. Is there something I’m missing? A reset? A switch? This makes no sense that both of them are doing the same thing. I do notice the center chair has a square box underneath that has the plug into it that looks like a phone line....I do not see those boxes on the outside chairs. Wouldn’t they have them also? Would not placing batteries in the electrical plug box make any difference (they never had batteries prior to this and worked just fine...I’m assuming that is just as a backup to a power outage)? Help!
Julia Houston is offline
post #16 of 31 Old 04-21-2020, 10:01 AM
rsh
rsh's Avatar
Quoted: 218 Post(s)
Liked: 196
Square plastic boxes are power supplies, and usually each chair has its own with the power cord that needs to be plugged into the power outlet. The 9V batteries are optional and can let you bring the chair into upright position in case you loose power in the house. It will work for a few times only., and should be be used as a main source of power.
If you never had the power supply boxes in outside chairs, maybe they were getting power from the same power supply? If yes, than you need to check all the connections and see how the outside chairs were plugged in and where they were getting power from.
Roman
rtheaters.com
rsh is offline
post #17 of 31 Old 04-21-2020, 10:42 AM
Liked: 0
They each have their own power supply (plug with box on the power cord). I have checked and quadruple checked that all connections are plugged into the correct places. I’m stumped!
post #18 of 31 Old 04-21-2020, 11:50 AM
rsh
rsh's Avatar
Quoted: 218 Post(s)
Liked: 196
Usually there are two wires plugged into the power supply - one comes from the motor, and one from a control switch.
Try to unplug and replug the wires to ensure firm connection, but before that check all the wires to see whether some of them got accidentally pinched or cut by the reclining mech.
markrubin likes this.
Roman
rtheaters.com
rsh is offline
post #19 of 31 Old 04-22-2020, 02:16 PM
Jim Cutter's Avatar
Quoted: 202 Post(s)
Liked: 192
This sounds like the same thing that went out on mine. I know that this is what went out since I swapped 2 of them and the problem followed the part. I can't find one anywhere and the parts that everyone is showing haven't been the right part.
post #20 of 31 Old 04-23-2020, 10:12 AM
hdtvluvr's Avatar
Quoted: 94 Post(s)
Liked: 69
Does it look like this?
JLDP Power Control Box
If you want to try a repair check my thread here:
Power Supply Repair
hdtvluvr is offline
post #21 of 31 Old 04-24-2020, 12:37 AM
Jim Cutter's Avatar
Quoted: 202 Post(s)
Liked: 192
Power Supply Repair
I'm excited to try this fix since my power supply is the 2nd one in the pics. Thanks.
post #22 of 31 Old 04-24-2020, 08:26 AM
hdtvluvr's Avatar
Quoted: 94 Post(s)
Liked: 69
Good luck and let us know if you get it working.
hdtvluvr is offline
post #23 of 31 Old 04-24-2020, 10:51 PM
Jim Cutter's Avatar
Quoted: 202 Post(s)
Liked: 192
Will do, I just ordered the part today.
post #24 of 31 Old 05-02-2020, 11:51 PM
Jim Cutter's Avatar
Quoted: 202 Post(s)
Liked: 192
So I swapped the transformer and it's doing the same thing. When I tested it the seat reclined but won't move back to the upright position. I swapped the parts with another chair and it did the same thing so it must be an issue with the circuit board in the box. I looked closely at it but couldn't tell if anything was wrong. It looked okay from my untrained eye. You instructions were perfect though as the transformer swap went smoothly.
Can we get the circuit board replaced? Here is the circuit board that must be the problem. Something is bad on it and not allowing the chair to move back to the upright seating position. The other picture is from when I had finished swapping the transformer and I was full of hope.
ID:	2720184   Click image for larger version
post #25 of 31 Old 05-03-2020, 12:24 PM
hdtvluvr's Avatar
Quoted: 94 Post(s)
Liked: 69
Have you tried using a controller from a working chair on this chair? If so, does this chair then work correctly?
How are your soldering skills?
EDITED:
Please look at the attachment and let me know the answers.
hdtvluvr is offline
post #26 of 31 Old 05-04-2020, 08:57 PM
Jim Cutter's Avatar
Quoted: 202 Post(s)
Liked: 192
EDITED:
Yes, I swapped the part that I worked on to get the seat back into the upright position. The chair works fine with the part swapped so that's how I know it has to be the circuit board that you showed. I'll have to take it back out and look at what you asked about. I looked at it the other day but didn't notice anything but I didn't know what I was looking at.
I've never soldered anything like this and my skills are basic at best.
post #27 of 31 Old 05-05-2020, 09:40 AM
hdtvluvr's Avatar
Quoted: 94 Post(s)
Liked: 69
Attach a good photo of that relay in question. It looks like it is melted or damaged on the side.
And the end of the large capacitor looks like it is bulging in the photo. That shouldn't cause your issue but if it goes bad the board obviously won't work at all.
The 2 relays. They are wired such that one is + and - and the other is - and +. This allows reversing the current to drive the DC chair motor forward or backward depending on which side of the switch you activate for the chair. I'd suspect that relay in question is bad.
hdtvluvr is offline
post #28 of 31 Old 05-10-2020, 09:43 AM
satishmovva's Avatar
Berkline replacement parts
I found Berkline parts available here and posted in the other thread as well.
Berkline parts:
https://www.fastfixparts.com/Berkline-Parts_c_170.html
LM60
https://www.fastfixparts.com/CIAR-LM...ent_p_114.html
LM55
https://www.fastfixparts.com/CIAR-LM...or-_p_125.html
Manufacturer:
https://ciar.it/catalog/en/35-linear-actuator-kits
satishmovva is offline
post #29 of 31 Old 05-10-2020, 10:24 AM
hdtvluvr's Avatar
Quoted: 94 Post(s)
Liked: 69
Jim,
Have you had the time to take the controller apart again?
hdtvluvr is offline
post #30 of 31 Old Yesterday, 12:54 AM
Jim Cutter's Avatar
Quoted: 202 Post(s)
Liked: 192
Jim,
Sorry about the delay on this. I was out of town for 2 1/2 weeks and have been crazy busy since being back. So here are some more pics. It does appear that one of the black boxes looks melted. Not sure about anything else. Here are some more pics. Any help would be appreciated.
ID:	2737768   Click image for larger version
ID:	2737770   Click image for larger version
ID:	2737772   Click image for larger version
Reply Theater Room Items & Accessories
