MoviePoster - Virtual movie poster display software. - Page 53 - AVS Forum | Home Theater Discussions And Reviews
 382Likes
post #1561 of 2945 Old 09-28-2015, 10:16 AM
harrytasker1's Avatar
Quoted: 21 Post(s)
Wink
Originally Posted by meyer64 View Post
Probably a few weeks. There isn't that much more to do, but I want to get the ticket maker finished up. Then I'll get back to MoviePoster. I just need to do a little cleanup testing and package it all up.
I found this site: https://xboxapi.com/documentation
Maybe you could implement it to show which game i am playing on my XBOX ONE.
I don't know how difficult it is to implement cause i don't have any understanding of programming.
Would be a nice addition though
turls likes this.
Format Neutral
harrytasker1 is offline
post #1562 of 2945 Old 09-28-2015, 10:33 AM - Thread Starter
meyer64's Avatar
Quoted: 391 Post(s)
Liked: 319
Yeah, I looked into it probably a year ago or more. It's possible, though there is a bit of a delay. One day I'll probably make a plugin for it. I had rough test programs working for xbox live and PSN at one point.
harrytasker1 likes this.
meyer64 is offline
post #1563 of 2945 Old 10-01-2015, 01:07 PM
str1der's Avatar
Quoted: 29 Post(s)
Just had a thought. Would it be possible to port this to run on something like a Fire Stick? With them being so cheap and small it seems like a perfect fit.
str1der is offline
post #1564 of 2945 Old 10-01-2015, 01:34 PM - Thread Starter
meyer64's Avatar
Quoted: 391 Post(s)
Liked: 319
I have experimented with porting to Android. But its a lot of work and may never be finished. Realistically, if you want something anytime soon your best bet for a small cheap device is an Intel compute stick or something like the Vensmile Mini PCs.
meyer64 is offline
post #1565 of 2945 Old 10-01-2015, 02:26 PM
str1der's Avatar
Quoted: 29 Post(s)
Understood. No problem just thought about not having to fool with Windows at all.
str1der is offline
post #1566 of 2945 Old 10-04-2015, 12:54 AM
rmilyard's Avatar
Quoted: 285 Post(s)
Liked: 39
So I upgraded to Kodi 15.1 today. Looks like MP not showing poster info when movies or shows playing. Shows connected to 15.1 stable. Also shows start and stop times right and title etc. Ideas?
rmilyard is offline
post #1567 of 2945 Old 10-04-2015, 10:27 AM
tha_kid's Avatar
Liked: 2
i believe this is a known issue that will be addressed in an upcoming release
tha_kid is offline
post #1568 of 2945 Old 10-04-2015, 11:30 AM
rmilyard's Avatar
Quoted: 285 Post(s)
Liked: 39
Good to know. Hope can get it fixed.
rmilyard is offline
post #1569 of 2945 Old 10-06-2015, 10:15 AM
AXLCMT's Avatar
Quoted: 189 Post(s)
Liked: 74
Just wanted to share with you the latest details regarding my 50" Insignia Movie Poster build which of course is going to utilize Meyer64's Movie Poster App plus his
Movie Poster Motion Sensor to to it on and off when it senses movement (I typed this last word as moviement before I corrected it. Lol!).
Latest update: 10/6/14
In this post:
1. Added air ventilation holes in the TV Mount support frame because the TV is going to get hot behind the TV since it will be completely enclosed inside a wall.
(I almost went with taking out all of the 2 x 4 upright Mount supports except for the very left and very right 2 x 4s in order to allow more space/air to surround the Insignia TV but I chose to just drill holes).
2. Added "side supports" for the drywall and to hold the "MDF Supports".
3. Added "MDF Supports" which will hold the "MDF Molding up around the TV with Velcro (I wanted to make the "Molding" around the TV removable in case I needed to remove the TV and/or get behind the TV). The MDF molding will cover the line where the drywall meets the TV. I guess I could have purchased pre-designed/pre-built molding from a local molding manufacturer but I wanted a more "seemless" and "flat" molding around the TV. If this MDF Molding idea does not work out, I will move forward with purchasing a simple molding design.
4. Installed the electrical outlet that will power the Movie Poster TV, speakers, and the computer that will run the Meyer64's Movie Poster app.
First I took out the part of the TV Mount that goes onto the TV itself and I installed it.
Then I unboxed the TV. Here is the TV before it is unveiled in all of its 50" glory.
Do you remember that "sample frame" I made to see what the size of the TV would be to figure out if the TV will fit in the hallway?
I finally was able to test and see if I made the right size. It turns out that I made it the exact dimensions of the TV.
The TV Mount brackets were put on the TV with no problems:
Here is the Movie Poster TV hanging in its new home for the first time.
AXLCMT is offline
post #1570 of 2945 Old 10-06-2015, 10:17 AM
AXLCMT's Avatar
Quoted: 189 Post(s)
Liked: 74
Double post (I got the error message that you have to wait 10 seconds between posts but I failed
to refresh the screen and I just re-clicked the save button)
AXLCMT is offline
post #1571 of 2945 Old 10-06-2015, 10:17 AM
AXLCMT's Avatar
Quoted: 189 Post(s)
Liked: 74
Double post
AXLCMT is offline
post #1572 of 2945 Old 10-06-2015, 10:19 AM
AXLCMT's Avatar
Quoted: 189 Post(s)
Liked: 74
Here is the TV Mount and the support 2 x 4s before I drilled the holes for ventilation. As I said earlier, I was on the fence about taking out the middle three 2 x 4s
in the middle or just drill holes for ventilation. I just drilled the holes because I would have to take ALL of the 2 x 4s down and that would run the risk of a loss of alignment.
I did have to move the support frames forward. As you can see here, the TV is not 1/2" further "out" past the framing to compensate for the 1/2" drywall.
The TV had to be sticking out 1/2" beyond the framing to be flush with the 1/2 drywall.
Here, as you can see, the TV is even 1/2" too "deep/far back" so I had to move it forward towards the wall a lot!
All of the 2 x 4s are out. (Please note this was done before I was on the "fence" about having to either cut the ventilation holes or remove the middle 2 x 4s)
2 x 4s are back in and you can now see that the TV is sticking out 1/2" so that AFTER the 1/2" drywall is installed, the TV will be flush with the wall.
View from behind the TV.
I also had to adjust the mount because it was not level:
AXLCMT is offline
post #1573 of 2945 Old 10-06-2015, 10:20 AM
AXLCMT's Avatar
Quoted: 189 Post(s)
Liked: 74
The ventilation holes:
I brought this hole saw attachment for something else so I just used it for this application. It turned out that the size was perfect for this application:
Almost done:
Made a lot of saw dust:
Done with the ventilation holes:
(note: I will be installing two HVAC "vents" from Home Depot to let air out of the wall)
Then it was time to install the electrical outlet for the TV, speakers and the PC.
Made sure it worked:
Here is a top down view of the layers involved with my hopeful design. If the MDF is too thin/brittle and breaks as I take the MDF Molding on and off, then I will go with a different design that involves purchasing molding from a local molding distributor. Tonight and every night this week, including the weekend, I will be working on the MDF molding. It should not take more an a few hours to put it together though.
AXLCMT is offline
post #1574 of 2945 Old 10-06-2015, 10:22 AM
AXLCMT's Avatar
Quoted: 189 Post(s)
Liked: 74
Edit: Double post
AXLCMT is offline
post #1575 of 2945 Old 10-07-2015, 10:37 AM
AXLCMT's Avatar
Quoted: 189 Post(s)
Liked: 74
After trying to make the "MDF molding" last night with the design above, it turns out that it is not worth the effort and work. The velcro makes it flimsy. If I ever need to remove the TV, I'm just going to have to use a molding "removal" wedge tool to remove it and then finish nail it back in. It was just too much work making the dado cuts into the soft MDF because it was just too difficult or beyond my patience and skill level.
AXLCMT is offline
post #1576 of 2945 Old 10-07-2015, 02:38 PM - Thread Starter
meyer64's Avatar
Quoted: 391 Post(s)
Liked: 319
For those interested, I've posted the first release of the GDC TicketMaker. For now, this is a standalone application but I do have plans to integrate ticket printing with the Showtimes feature in MoviePoster at some point.
I've created a new thread for the TicketMaker here:
https://www.avsforum.com/forum/32-the...l#post37882625
Sample Ticket:
AXLCMT likes this.
meyer64 is offline
post #1577 of 2945 Old 10-07-2015, 02:41 PM
AXLCMT's Avatar
Quoted: 189 Post(s)
Liked: 74
There must be something wrong with AVSForum.com website because I had the same issue with a Double Post as per meyer64's double post above. I feel better now that I know it wasn't just me! Lol.
Thanks for the great ticket generator software meyer64!
AXLCMT is offline
post #1578 of 2945 Old 10-07-2015, 02:46 PM - Thread Starter
meyer64's Avatar
Quoted: 391 Post(s)
Liked: 319
Yeah, if you try to submit multiple posts in a short time frame, you get a 'you must wait at least 10 seconds between posts' message, so i submitted the post again after a few seconds, but it seems to have posted the first one anyway.
meyer64 is offline
post #1579 of 2945 Old 10-07-2015, 03:30 PM
rmilyard's Avatar
Quoted: 285 Post(s)
Liked: 39
Sample Ticket:
Looks cool! I will use it for my daughters Girl Scout party. You have a user guide for it yet?
Also any ETA for update for MP? Having issues with 15.1 not showing NOW PLAYING posters etc.
rmilyard is offline
post #1580 of 2945 Old 10-12-2015, 10:42 AM
AXLCMT's Avatar
Quoted: 189 Post(s)
Liked: 74
I just wanted to share the continuing sage of my Movie Poster TV build.
Here are photos of the speaker boxes for the Movie Poster Speakers:
First the Right side:
AXLCMT is offline
post #1581 of 2945 Old 10-12-2015, 10:43 AM
AXLCMT's Avatar
Quoted: 189 Post(s)
Liked: 74
Then, for the right speaker box, I had an issue with the volume knob not fitting in, so I drilled a hole for it to fit:
Right side speaker box complete (I covered it with its original packaging bag because I don't want drywall dust or anything to damage it).
Then it was onto the Left Speaker box:
AXLCMT is offline
post #1582 of 2945 Old 10-12-2015, 10:43 AM
AXLCMT's Avatar
Quoted: 189 Post(s)
Liked: 74
Left speaker box complete (and also wrapped up to protect it from the tons of drywall sanding dust coming its way).
A view from behind the Movie Poster TV location:
AXLCMT is offline
post #1583 of 2945 Old 10-12-2015, 10:48 AM
AXLCMT's Avatar
Quoted: 189 Post(s)
Liked: 74
Meyer64, how much R13 pink insulation can I fill the area around and behind my 50" Insignia screen?
How much space should I leave. Please note also that I am going to be installing a 10" x 7" "vent" to on the inside of the theater wall near the top of the wall
to allow the rising heat of the 50" LED TV to vent out. How many inches left and right should I leave for a gap between the TV and the Pink Insulation? I will not be installing pink insulation above the TV for obvious reason (heat rises). Please see my layout photos in my dedicate build thread if you have not seen photos of my wall.
AXLCMT is offline
post #1584 of 2945 Old 10-16-2015, 03:09 AM
Liked: 0
Anybody use a new Raspberry Pi 2 with win 10 for the app? I'm looking at building one but all my computers are mac and I don't want to sink too much into getting a full windows setup.
Afakhori is offline
post #1585 of 2945 Old 10-16-2015, 06:23 AM
Liked: 0
Meyer64,
Can you, or other users, confirm that 'now showing' is not showing anything except the playing time?
Is it correct that there is no option to turn 'now showing' off?
I would like to play some music but at the same time watch the trailers/posters on the screen...
I really love this little piece of software and looking forward to a new(er) version, thanks again!
Luuk
bassiened is offline
post #1586 of 2945 Old 10-16-2015, 06:24 AM
Liked: 0
Meyer64,
Luuk
post #1587 of 2945 Old 10-16-2015, 06:50 AM
ConradC's Avatar
Quoted: 72 Post(s)
Liked: 103
Win10 for the RP2 is only for IoT (Internet of Things). It's designed to run headless (no interface/GUI). It won't run standard Windows applications.
Originally Posted by bassiened View Post
Meyer64,
Luuk
If you are using Kodi 14, it's a known issue. Read a few posts above. You will need to either wait until he releases the updated version that works or go back to Kodi version 13 or older. If you aren't using Kodi, then sorry for this reply.
ConradC is offline
post #1588 of 2945 Old 10-16-2015, 07:00 AM
Liked: 0
ConradC,
I`m indeed a Kodi user. But i`m currently using Kodi 15.2
I guess I`ll have to wait for a fix or a newer version.
Can you tell me if it`s possible to keep the posters/trailers showing, while playing music in Kodi?
Thanks for your help so far!
Luuk
post #1589 of 2945 Old 10-16-2015, 08:02 AM
ConradC's Avatar
Quoted: 72 Post(s)
Liked: 103
ConradC,
Luuk
Sorry. I gave you bad intel! It's broken on Kodi 15 and newer. It works just fine on 14 and under. I'm using Kodi 15.0 myself.
Posters and trailers will continue to work while playing music in Kodi.
ConradC is offline
post #1590 of 2945 Old 10-16-2015, 08:53 AM
Liked: 0
No problem ConradC! Thanks for the clarification
For posters and trailers continue to work, I`ll guess I need Kodi 14 (or under) as well, right?!
I think I`ll wait for a newer version of movieposter, since I finally have my x10 lights working in Kodi 15.2
Reply Theater Room Items & Accessories
