MoviePoster - Virtual movie poster display software. - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 334Likes
post #2791 of 2812 Old 03-19-2019, 09:59 AM
glabrecque's Avatar
Quoted: 89 Post(s)
Liked: 63
Originally Posted by DougUSMC View Post
Did you get the serial #, enter it into the software, then restart the machine?
yes I did enter the serial and after several restarts on on the webview pc it updated and is working. The only issue I can't seem to get to work is the manual now playing feature. It will rotate through coming soon posters all day but when I try to select a poster and hit manual now playing it never works?
Epson 5040ub
LG 65E6P OLED
Yamaha RX-A3070
BIC Acoustech 7.2 Speakers
Panasonic DP-UB820
glabrecque is offline
post #2792 of 2812 Old 03-26-2019, 05:50 AM
Liked: 0
Deviceidtowatch
Hey guys,
Has anyone figured out a way to only watch say an IP address rather than a "deviceIDToWatch"? A friend also uses a shield like i do and my movie posters won't display correctly. I'd hate to cut him off so i could have my posters haha. Any help would be great.
I love this product!!
dvohasek is offline
post #2793 of 2812 Old 03-26-2019, 03:32 PM
Shawn Colton's Avatar
The Shield version of MoviePoster is available???
Shawn Colton is offline
post #2794 of 2812 Old 03-29-2019, 10:22 AM
Quoted: 20 Post(s)
Liked: 6
This software is very cool! I have it installed and running. I'm only running into one issue. I can't seem to get new posters. It downloaded a few from newer movies but when I go to add new posters I do a search and nothing comes back. Is there something I'm doing wrong?
mladams922 is offline
post #2795 of 2812 Old 03-29-2019, 05:51 PM
Quoted: 20 Post(s)
Liked: 6
I managed to fix it. I just had to reboot and for some reason that resolved it.
post #2796 of 2812 Old 03-29-2019, 06:10 PM
vemulasri's Avatar
Quoted: 31 Post(s)
What do you mean shield version? I have kodi 18 and it works with my shield TVs. I have movieposter installed on windows PC.
vemulasri is offline
post #2797 of 2812 Old 03-30-2019, 01:34 AM
Batiatus Rules's Avatar
Quoted: 61 Post(s)
Liked: 37
Popping back in after some time to check how things are going. I've been putting some more work/thought into my project and it's nearing actual progress. I am running 2.3.0.3 as I believe that is the most current?
Here is the model of the display as it will be soon built and hung. I'm curious if some of those who've had their unit up for a bit have some ideas on a couple issues I'm working out.
First, I'm using an Arduino nano to run the marquee lights. Does anyone know if it's possible to use the nano, on start-up, to send an IR signal to a display to turn on? And subsequently to send an IR signal to the TV to turn off when powered off?
Has the web-remote received any update? The 2 functions I'm really looking for is to be able to push any local or cached poster from the web remote manager to the display and also have an always visible "pause" button along the top. This way I can start/stop the posters at any time.
Last, any other ideas/options for powering on your displays in a more remote manner than using physical remotes pointed at them or the button on the units?
Name:	Digital Poster 04.jpg
ID:	2546180   Click image for larger version
Name:	Digital Poster 05.jpg
Batiatus Rules is offline
post #2798 of 2812 Old 03-30-2019, 02:17 AM
dalum's Avatar
I just started trying to get this working. I'm a little stuck with the multimonitor settings for using this. I'm using Kodi on windows7 on a NUC that has 2 display outputs. I'm using hdmi as the primary display for movie/desktop to my TV and the miniDP output running to a 27" monitor trying to get this going. For the life of me I can't get the poster to stay on the second monitor! I can't find what settings I should have in windows + the app. The poster seems to start up at 0,0 on the main display but I want it on the secondary display (obviously). I can drag the app over to the 2nd display, maximize it and it works great but after a restart its snapped back to 0,0 upper left corner of the primary display. I've tried both the stable and dev versions with no difference.
I only have 1 DisplayID. Under "Show on monitor" i can select \\.\DISPLAY1 or \\.\DISPLAY2 but it never moves changing those settings. I'm very knowledgeable in this stuff and this has me feeling very stupid.
dalum is offline
post #2799 of 2812 Old 04-04-2019, 08:27 AM
Johnny14o's Avatar
Quoted: 77 Post(s)
In all seriousness.... How do you have yours working?
Several of us (including the developer) are having issues with getting Kodi 18 to work properly with the Shield TV (I would gather it is with all Android TV platforms). There is the "Now Playing Black Screen" issues.
I too have a Shield TV and Movie Poster app running on a PC. I have poured over the issue and have come up with no solution to solve this problem.
Could you please provide some insight into your setup (ex hardware, maybe even some screenshots of your settings) so the rest of us may be able to get ours working too?
Thanks in advance!
Johnny14o is offline
post #2800 of 2812 Old 04-04-2019, 11:36 AM
vemulasri's Avatar
Quoted: 31 Post(s)
Thanks in advance!
Sure i am out of town right now and will definitely post next week after i go back. I have not changed anything in the last year or so. I turned on last week and it was working. It could be because, I have not played any new movies recently and the movie i was playing last weekend was a repeat and it might have already had that in the cache. This had happened to me in the past and I just tried creating the folder in the cache and restart and it worked. Not sure exactly why but it was working last week. I will check next week and update if that is still the case. I will try a new movie that i never played and see the behaviour.
Johnny14o likes this.
post #2801 of 2812 Old 04-04-2019, 01:07 PM
Johnny14o's Avatar
Quoted: 77 Post(s)
Fantastic! Thanks for helping out with this.
Sent from my SM-G965U using Tapatalk
post #2802 of 2812 Old 04-05-2019, 06:57 PM - Thread Starter
meyer64's Avatar
Quoted: 389 Post(s)
Liked: 323
Hello everyone. It seems that I have neglected to keep to keep up on this thread. I'm glad you've all been having fun without me
I am finishing up a new dev build which addresses a few issues, mainly the "kodi black screen now playing issue"
I am currently traveling for work but hope to get it posted in the next couple days.
meyer64 is offline
post #2803 of 2812 Old 04-05-2019, 07:14 PM - Thread Starter
meyer64's Avatar
Quoted: 389 Post(s)
Liked: 323
I actually build a device that can power on/off your display based on motion. You can check it out here. http://movieposterapp.com/products.html I'm very low on components at the moment , but feel free to shoot me a message if you are interested. Personally, I think its great. I haven't manually powered my screen on or off in a very long time. Its on when I'm in the area and off when I'm not. I'm sure you can do it with a nano if your handy with those sort of things.
When in the cache page, there are two ways that you can send a poster to the display. simply clicking the poster in the list will sent it to the primary displaygroup. or you can use the options menu to send it to a specific displaygroup in you have more than one.
I can add a pause toggle button to any page in the webremote without too much trouble. For consistency I'll probably add it to the 'actions' menu thats in the top right. you'd be able to slide out the menu and pause without needing to go back to the remote page.
meyer64 is offline
post #2804 of 2812 Old 04-05-2019, 07:21 PM - Thread Starter
meyer64's Avatar
Quoted: 389 Post(s)
Liked: 323
Originally Posted by dvohasek View Post
Hey guys,
You should be able to change the name of the device in the plex settings so you can modify the name of yours to be unique. The method varies a bit depending on your device, and I dont have my Shield handy at the moment, but it should be in the settings somewhere.
meyer64 is offline
post #2805 of 2812 Old 04-05-2019, 09:40 PM
Quoted: 61 Post(s)
Liked: 37
Thanks for the response. I haven't been able to get the poster push to work in the browser but I'll tinker with it some more. For the pause button I think maybe some basic controls on the top bar of any screen would be perfect. A play/pause button, next and previous poster buttons. Just so anyplace you are in the web browser you can quickly hit those few keys.
*** After testing a bit more I guess I should clarify that I can't seem to push a poster to the display from the user posters lists. I manage and curate everything manually so I have the posters I want and not what ever happens to be downloaded on that particular day.
I'd also note that the buttons to pause/play the posters being a slide toggle can be tricky to use, especially when on a touch interface. A simpler double-click/tap button would work much easier.
Also discovered that the TV I'd intended to use asn't going to fit as planned as I'd miss-measured the available space. And then the TV decided to not even turn on when I tried to further test things. Ugh!
post #2806 of 2812 Old 04-08-2019, 07:33 AM
Spyderturbo007's Avatar
Quoted: 239 Post(s)
Liked: 97
I have a few questions about trailers. I found the FAQ on the developer's website that indicated I can drop a trailer in the appropriate folder named whatever-trailer and it will play. I see that some trailers that I copied have been renamed by the software, which is fine with me. However, I don't see any of the .mov trailers being renamed, only some of the .mp4 trailers have been renamed.
Does the software support .mov trailer files?
Also, under settings - > trailer options, can someone explain the "Frequency slider". Is 0 no trailers and 10 all trailers?
Spyderturbo007 is offline
post #2807 of 2812 Old 04-08-2019, 12:21 PM
mrfrankmrfrank's Avatar
Just a heads up, the black screen now playing is also an issue with emby...
mrfrankmrfrank is offline
post #2808 of 2812 Old 04-09-2019, 12:39 PM
Liked: 3
Just to add to the discussion. I am successfully running movieposter on a pc connected to NVIDIA shield pro using kodi 17.6. When I tried kodi 18 I do get a black screen but 17.6 works great.
enovison is offline
post #2809 of 2812 Old 04-10-2019, 03:38 AM
Quoted: 45 Post(s)
Liked: 2
meyer where will you be uploading the latest version to?
shazza6887 is offline
post #2810 of 2812 Old 04-14-2019, 04:21 AM
Does your NOW PLAYING posters work? When I start a movie, it doesn't switch to the playing movie poster with the Shield TV. I"m running Kodi 18.1.
post #2811 of 2812 Old 04-14-2019, 07:09 AM
Liked: 3
Yes, my now playing posters work great, but only if I run kodi 17.6.
enovison is offline
post #2812 of 2812 Old 04-14-2019, 01:56 PM
Liked: 0
Can confirm as follows
Running on PC
2.3.0.3 Dev (2-18-2018) & Kodi 18 Not showing now playing poster
MoviePoster 2.2.0.1 & Kodi 18 Not showing now playing poster
MoviePoster 2.2.0.1 & Kodi 17.6 Showing now playing poster no problem
shawy2004 is offline
Reply Theater Room Items & Accessories
