AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Theater Room Items & Accessories (https://www.avsforum.com/forum/32-theater-room-items-accessories/)
-   -   Media Console for 75" TV and Large center channel (https://www.avsforum.com/forum/32-theater-room-items-accessories/3007388-media-console-75-tv-large-center-channel.html)
Test_Engineer 10-08-2018 11:09 AM
I'm about at the halfway point in my basement project and starting to look at furniture for the new space. It seems there are very few options for consoles that can house a large center channel. I am planning on using Klipsch Reference Premier Line for everything, so that means a RP-504C center channel at dimensions of 6.81” x 31.13” x 14.46”.
What I have found so far is the Horizon or Haven EX 82-inch Solid Wood Media Console by Standout Designs ($3,000), and the SYNERGY MODEL 245 by Salamander Design ($2,000).
I really don't want to "stack" the TV on top of the center channel on top of a cabinet, as I want to keep the TV at a reasonable viewing height for a 75-85" TV.
Are there any others I should consider?
SmittyJS 10-10-2018 07:46 AM
I've looked really long and hard for consoles that hold a large center channel and as you've found, Standout is the only one I've found that will hold something as big as yours. But the price is ridiculous. Fortunately for me a BDI 8137 ($1,700) or Furntech 70" ($1,000) are about the only others that will hold my center (Paradigm Signature C3), but yours is too wide.
Test_Engineer 10-11-2018 07:45 AM
Those were the other 2 I found that can fit larger centers, but they won't fit the big Klipsch. I already own a different Salamander Designs Synergy model for our main living room, so I have no problem with that one. The StandOut Designs ones do look really nice and are all hardwood. I don't mind paying for quality, but $1,000 more is a bit much. If it was $2,400 or 2,500, I think it would be reasonable.
SikOne 10-30-2018 07:33 AM
You should check the site again. They are having a holiday sale.
I'm looking for a TV stand as well but I don't mind setting the center speaker on top as I will wall mount the TV. Any general recommendations on brands that put out a good product? I would want to stay in the $1500-$2000 range. Going 65" most likely with the TV.
thetman 10-31-2018 10:41 AM
I just received the Horizon 82" in black delivered a few weeks ago. I ordered it during their labor day sale. I have a 75" Tv on it. I can tell you that it is a beautiful piece of furniture. Its made to order and the craftsmanship is top notch. Sure it pricey- but its real hand made wood furniture. And its a joy to put all your gear in. the backs come off the shelves are vented and plenty of run-throughs for all your cables to keep it very neat.
Also from the order to the shipment ( I had white glove-its a heavy piece) was top notch. Alan is a nice guy and responds to your questions and
e-mails quickly. I highly recommend it.
nbk13nw 10-31-2018 10:49 AM
Test_Engineer 11-03-2018 09:17 PM
I think I am going to end up with the same one. The bar I am planning to build in the same room will have a black dyed butcher block top, so that should go well together.
thetman 11-06-2018 10:18 AM
its a fine piece of furniture- you won't be disappointed. not cheap but something you can own a lifetime. I went to many furniture stores around my area and found nothing I liked.
ahtoh 10-19-2019 07:39 PM
1 Attachment(s)
$3000 is way too much for me
Even $1000 is more than I'm willing to pay
My central channel speaker is 24x8"
Is there something closer to $300?
I'm also considering building it.
Something like this would work, just need a solid wood construction (pictured is MDF). Do you know where I can buy thick solid wood material to build this?
pkinneb 10-20-2019 05:30 PM
I would not use solid wood for two reasons. First wood movement there is a lot going on there if you used solid wood it would almost certainly crack somewhere and most likely in multiple places. Secondly if you are planning on using hardwood that will be a substantial investment in wood, way over $300. If you use big box store 2x material see number one as it will blow itself apart as it dries out.
ahtoh 11-28-2019 09:16 PM
Update: I eventually purchased PLATEAU SR-V 75 for $430
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
