Berkline Theater Seating Parts - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By GPowers
post #1 of 14 Old 12-21-2018, 07:19 PM - Thread Starter
gaspower's Avatar
Hello,
I have Berkline theater seating. One of my chairs is having a issue opening the footrest. Any pressure on the footrest and the opening stops. Take any pressure off and it will open fine. Closing works fine, so I am assuming a issue with the electric motor. Is there anywhere to purchase just the electric motor and not the complete motor and slide.
Thank you,
JR
ID:	2499642   Click image for larger version
gaspower is offline
post #2 of 14 Old 12-21-2018, 07:32 PM
torii's Avatar
Quoted: 3778 Post(s)
Liked: 2164
I had a problem with one of my berkline power recliners and had a free estimate done by a repairman. the estimate to fix was more than what I paid for brand new seat...I therefore just bought new seats. now if gonna diy...maybe if your time free its ok...but I suspect berkline just disposable furniture
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #3 of 14 Old 12-22-2018, 05:53 AM
Quoted: 6194 Post(s)
Liked: 5878
just google the information on the motor, first hit, there may be others
http://www.liftchairsrus.com/CIAR-LM...tor_p_342.html
post #4 of 14 Old 12-22-2018, 06:14 AM - Thread Starter
gaspower's Avatar
Hello,
Thank you BIGmouthinDC. Sorry, my error, as I did find the complete set like you mentioned. I was just looking for the replacement motor as it is the only part that went bad. I appreciated the link.
JR
gaspower is offline
post #5 of 14 Old 12-22-2018, 08:30 PM
Liked: 5878
Contact the vendors. While they may only sell the assembly they may have one sitting around with a damaged rail or can sell you just the motor. A lot of small companies don't list everything on their sites that they can sell.
post #6 of 14 Old 12-30-2018, 11:52 AM - Thread Starter
gaspower's Avatar
Thank you very much.
gaspower is offline
post #7 of 14 Old 10-03-2019, 12:54 PM
GPowers's Avatar
Quoted: 95 Post(s)
Liked: 129
Did you ever find a replacement motor assembly? BigMouthinDC link is a store that is no longer in business. Most of the remaining link are not the Ciar part. Is there a direct replacment?
GPowers is offline
post #8 of 14 Old 10-04-2019, 06:56 AM - Thread Starter
gaspower's Avatar
Hello,
No, but I did luck out for a short time and was able to make it work again, but it has failed once more. I am actually ordering (https://www.amazon.com/IRONWALLS-Ele.../dp/B07KR5B4GQ), and going to modify it to fit.
Jr
gaspower is offline
post #9 of 14 Old 10-07-2019, 11:49 AM
GPowers's Avatar
Quoted: 95 Post(s)
Liked: 129
This one from Amazon is a 90% replacement.
Mophorn Replacement Parts for Lift Sofa 29V DC Stroke Length 1000N/220LBS 13.4"/340mm
by Mophorn
Learn more: https://www.amazon.com/dp/B07D51PPB7..._JP3MDb0DGYNEH
GPowers is offline
post #10 of 14 Old 10-08-2019, 03:34 PM - Thread Starter
gaspower's Avatar
Thank you
gaspower is offline
post #11 of 14 Old 10-11-2019, 11:41 AM
GPowers's Avatar
Quoted: 95 Post(s)
Liked: 129
I was able to get the new actuator to work 100%.
The replacement actuator would not close the footrest 100%. After thinking about it for a while I add a second set of holes between the original hole and the bracket that attaches to the nylon slide. The new holes are mabey a half an inch from the original holes. This pulls the footrest in just enough to close completely and the motor stops without stressing the gears.
Jim Cutter and HT Geek like this.
GPowers is offline
post #12 of 14 Old 10-11-2019, 05:28 PM
Liked: 5878
Thank you for your service to our community. Good information for all Berkline owners.
post #13 of 14 Old 12-04-2019, 01:39 PM
Jim Cutter's Avatar
Quoted: 200 Post(s)
Liked: 192
I just had a motor fail on one of my Berkline chairs. Unfortunately it failed with the footrest up and leaned back. I need to get under it and get some numbers off of the motor. I thought that it would be easy find a replacement motor with as many of these chairs that Berlin has sold.
Theater Room - JVC RS2000, Dalite 148" Scope, Pioneer SC-65, Panasonic UB820, Energy APS 5+2(2), Energy AC 300(1), Energy CR-3(4), PSA 15"Sub(2)
Sports Room - JVC RS4810, Dalite 106" 16:9, Onkyo TX-SR875, Oppo BDP-103, Energy C-7(2) w/Energy S8.2(2), Energy C-C3(1) w/Energy S10.2(1), Energy CR-3(3), Energy S12.3
Jim Cutter is offline
post #14 of 14 Old 12-06-2019, 03:23 PM
Liked: 0
I found a replacement motor on ebay a couple of years ago. I took a chance on a used one, but it's worked so far. I was surprised how hard it was to find a replacement. But these chairs are pretty old now and probably need to be replaced. When I do, I should probably pull the recline motor assemblies and sell them on ebay.
Also, the problem with my motor was weird. It worked perfectly to recline the chair, but wouldn't put it down at all. So it's like the motor would work in one direction but not the other. I kept it thinking I might be able to fix that, but I've never messed with it.
Binny is offline
Reply Theater Room Items & Accessories
