DVD storage rack help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-22-2019, 12:07 PM - Thread Starter
jphillips63's Avatar
Quoted: 305 Post(s)
Liked: 136
Hello I’m in need of storage for all my Blu-ray movies. I have in excess of 200 movies and growing so I’d like to find a nice rack that doesn’t take up a lot of floor space yet big enough to hold my collection.
Thanks in advance on any advice given.
Sent from my iPhone X using Tapatalk
Sony 65" A1E | Samsung 55" UH8500
Marantz SR6011 AVR l Martin Logan motion 40's, motion 30, and motion 15 rears, Martin Logan AFX Atmos speakers atop the front L&R
SVS PB 16 Ultra x3 l SVS PC12 Plus
Oppo UDP-203 | Samsung UBD-K8500
jphillips63 is offline
post #2 of 7 Old 02-22-2019, 12:12 PM
eljaycanuck's Avatar
Quoted: 1846 Post(s)
Liked: 2591
eljaycanuck is offline
post #3 of 7 Old 02-26-2019, 11:30 AM
Moebius's Avatar
Quoted: 224 Post(s)
Liked: 139
If you have basic handyman skills (cut a straight line, pre-drill a pilot hole), you can create a nice semi-built in shelving system for relatively cheap. I spent less than $100 on my setup, and that was with paying more for some premium 1x3s to give a more polished look. I've got more than 600 discs on these two shelves. And I don't know why the forum insists on rotating this picture 90 degrees, but it does...
Edit: Also, just to note this pic was taken before I painted the screw heads black to match.
Name:	Media Shelves.jpg
Remember, no matter where you go... You're not where you were anymore.
HJ Movie House Build Thread
Moebius is offline
post #4 of 7 Old 02-27-2019, 08:49 AM
mskreis's Avatar
Quoted: 148 Post(s)
Liked: 48
Looks very nice. It’s hard to tell from the photo but are your shelves the same depth as the sides?
JVC RS640; RUIPRO 10m HDMI cable; Marantz AV7704; Lumagen Pro 4240; Oppo BDP-203;Triad Silver LCR, Onwall Bronze Surround, Inwall Bronze Omni, KEF Inceiling Ci 160QR x 4; Dual RSS460HO-4 18" SWs
mskreis is offline
post #5 of 7 Old 02-27-2019, 12:24 PM
Moebius's Avatar
Quoted: 224 Post(s)
Liked: 139
Yes, everything was built with 1x3s. They stand on the floor (by my choice) and as such I use a single bracket at the top to secure to the wall. The design was based on some Youtube videos on building one for $25. I choose to go with higher end lumber so it was straighter. Cut to my needed sizes, pre-drilled holes for the side screws, and painted. Because I was able to go much taller than any store bought shelving is going to, I was able to fit all of my discs in that corner, which amounts to some 650 movies, plus another 50-100 miscellaneous videos, box sets, and TV series.
Moebius is offline
post #6 of 7 Old 03-25-2019, 02:40 AM
Liked: 0
I was running out of storage space for my growing DVD collection. I was also running out of ideas but Neo’s compact DVD storage boxes saved my time and my collection.
Lift Rank is offline
post #7 of 7 Old 03-25-2019, 05:40 AM
Tedd's Avatar
Quoted: 1978 Post(s)
Liked: 802
I have a bunch of old bedframes that came out of the trash and a reuse it center, and they were cut down with a Harbor Freight 4" angle grinder, and cleaned up with
it. They are sitting in the garage in primer, waiting for the nice weather and finish coat of paint. I will notch some nice 2x4, and insert the L shaped metal, and secure with
a screw in the face of the metal. I expect to end up with cheap storage, that will be very solid and nice looking and fill a 14' section of wall.
Tedd is offline
Reply Theater Room Items & Accessories
