My DIY Theater Marquee....build thread... in the spirit of RH - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 42Likes
post #31 of 45 Old 06-06-2019, 10:27 AM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 127
So I’m making little wedges to help to keep the crown “in place”. Starting with the correct angle
pkinneb likes this.
Jglass4788 is offline
post #32 of 45 Old 06-07-2019, 06:15 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 127
So I built little wedges that helped. Pull out the crown. No just working on the gap underneath.
Then I can finish the crown and start the most time consuming part “ the finish”
Ladeback and pkinneb like this.
post #33 of 45 Old 06-12-2019, 10:59 AM
brazensol's Avatar
Quoted: 777 Post(s)
Liked: 600
More please!
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP; (2) iNuke NX3000D; (3) HTM-12; (14) RSL C34e surrounds; (2) 18" DA RSS460HO-4 Subwoofers; (1) DA UM18-22 18" Ultimax Subwoofer; (4) DA RSS390HO-4 15" Reference HO Subwoofers; BOSS Platform - (12) 12" Subwoofers
brazensol is offline
post #34 of 45 Old 06-22-2019, 04:28 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 127
. Finally got the last piece of Crown up.
Now it’s time to start the sanding!
post #35 of 45 Old 11-11-2019, 01:42 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 127
Finally after a couple months....I’m back at it!
post #36 of 45 Old 11-11-2019, 01:46 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 127
Found a RH sconce at the outlet store, that will look great next to it. Sure hope I can find the other one on EBay, etc. they are a little “pricey”...
Also getting the wiring complete, for the Movie Poster TV
post #37 of 45 Old 11-11-2019, 02:23 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 127
Tedd likes this.
post #38 of 45 Old 11-11-2019, 02:24 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 127
Brick is going up!
post #39 of 45 Old 11-11-2019, 07:02 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 127
Tedd and pkinneb like this.
post #40 of 45 Old 11-20-2019, 04:47 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 127
Almost done with the 1st side..
Goes up quick...till you need to do all the cuts
post #41 of 45 Old 11-21-2019, 12:19 PM
Quoted: 161 Post(s)
Liked: 422
Looks great!
Just a heads up not sure how you will be painting the flexible trim but I just sprayed a piece I used for base molding in my basement trim and it took 6 coats to cover and look like the primed trim which got 3 coats.
My Theater Build - Full Circle Cinema
pkinneb is online now
post #42 of 45 Old 11-25-2019, 07:32 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 127
Tedd, BIGmouthinDC and pkinneb like this.
post #43 of 45 Old 11-25-2019, 07:33 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 127
Sconce is up...brick is complete(minus grout)..
post #44 of 45 Old 11-26-2019, 09:09 AM
Ladeback's Avatar
Quoted: 1416 Post(s)
Liked: 523
Send a message via MSN to Ladeback
Looking good. Do you have a build thread for your theater itself?
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #45 of 45 Old 11-30-2019, 03:09 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 127
Thanks! The theater build thread is not started yet. As soon as the Marquee is done...I’ll be starting the actual theater. I’ll start a new thread.
Reply Theater Room Items & Accessories
