My DIY Theater Marquee....build thread... in the spirit of RH - AVS Forum | Home Theater Discussions And Reviews
 52Likes
post #1 of 58 Old 03-04-2019, 10:47 AM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
Hey guys. I’ve got another fun project I’m completing. My theater entrance. I thought I’d do a quick tutorial, in order to help others.
I’m going to be trying to match a piece of furniture from Restoration Hardware(RH).
The finish is “Waxed Black” (it’s like a satin black...sort of-rustic)
Jglass4788 is offline
post #2 of 58 Old 03-04-2019, 10:52 AM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
Here is my entrance starting with the surround.
post #3 of 58 Old 03-04-2019, 10:54 AM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
Using 3/4 MDF
post #4 of 58 Old 03-04-2019, 10:57 AM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
Header panel is up
post #5 of 58 Old 03-04-2019, 11:00 AM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
And now for the lighting..... the outlet installed is “half hot”
This is so I can control the main lights with a wall switch, then I’ll also have the Phillips hue lightstrip on the top, which is controlled via WiFi.
BIGmouthinDC likes this.
post #6 of 58 Old 03-05-2019, 01:02 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
So in regards to ripping the MDF to length... There is simply no substitution for a “track saw”... Wow, you can cut an 8’ piece of MDF absolutely perfectly straight, with basically no “tear-out” (single operator....try that on your table saw). I freakn love this thing!!
Tedd and bubbrik like this.
post #7 of 58 Old 03-05-2019, 07:04 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
The bottom header board is going up.
These clamps are perfect.
brazensol and bubbrik like this.
post #8 of 58 Old 03-05-2019, 07:07 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
There will be a Phillips hue light strip above the marquee.
post #9 of 58 Old 03-05-2019, 07:09 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
So I can control it WiFi. And match or contrast the bar area.
post #10 of 58 Old 03-05-2019, 07:10 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
post #11 of 58 Old 03-05-2019, 07:12 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
The main kit is only 80”......so I needed an extension
post #12 of 58 Old 03-05-2019, 07:16 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
So now I can match the bar lighting or do independent colors. Phillips hue is not the cheapest option, but very “user friendly”.
post #13 of 58 Old 03-06-2019, 05:29 AM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
Lastly(for the day)..... I need to wire up
The spot lighting. These are LEDs that you can change color(temp) with a switch....which I really like.Click image for larger version
ID:	2535006Click image for larger version
ID:	2535008Click image for larger version
ID:	2535010Click image for larger version
ID:	2535012Click image for larger version
ID:	2535014Click image for larger version
ID:	2535016Click image for larger version
ID:	2535018Click image for larger version
brazensol, Ladeback and bubbrik like this.
post #14 of 58 Old 03-06-2019, 06:34 AM
Ladeback's Avatar
Quoted: 1606 Post(s)
Liked: 619
Send a message via MSN to Ladeback
I am going to use Philips Hue products for my theater as well. Right now it's a work in progress and I have one color bulb in the room so I can tell my Google Mini when to turn it of and one or what ever else I want. They aren't cheap is right, but should last longer then a normal bulb.
You marquee looks great. Do you have a build thread for your theater?
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #15 of 58 Old 03-06-2019, 06:52 AM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
Thanks! I don’t have a build thread for the theater “yet”.
My theater is fully functional, but all the cosmetics still need to be complete (which I’ll start as soon as I finish the marquee).
Stay tuned!!
I like the Phillips Hue stuff so far... Super easy to set-up and control. The app works great. But ultimately I’ll have home automation that will take control.
Ladeback likes this.
post #16 of 58 Old 03-06-2019, 03:16 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
All right...next steps...
All the upper/lower bracing is complete.
So I still need to add the cover board that will “face” the marquee.
But also need to get my columns ready...
As you can see I have an 8’ colonial style column(got a set off of Craigslist for~$100.00). The first set will be”split”, and cut down to size, and placed against the wall on the marquee.
The second set will be in the theater.
They need to be stripped as well....Click image for larger version
ID:	2535386Click image for larger version
ID:	2535388Click image for larger version
ID:	2535390Click image for larger version
d-rail34 and bubbrik like this.
post #17 of 58 Old 03-10-2019, 02:57 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
Header panel is basically done...covered in 1/4 inch underlayment..(it’s going to be painted so grain,etc doesn’t matter).
And now onto the columns....Click image for larger version
ID:	2537052Click image for larger version
ID:	2537054Click image for larger version
ID:	2537056Click image for larger version
ID:	2537058Click image for larger version
post #18 of 58 Old 03-11-2019, 04:16 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
There is also crown molding that will go up(the rope light is tucked behind it).
But for now...”splitting the columns”...
Again this “track saw” is worth its weight in gold.
One person job...perfectly straight cutClick image for larger version
ID:	2537482Click image for larger version
ID:	2537484Click image for larger version
ID:	2537486Click image for larger version
ID:	2537488Click image for larger version
ID:	2537490Click image for larger version
bubbrik likes this.
post #19 of 58 Old 03-12-2019, 02:39 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
Columns are split!! No into the “test fitting”phase... needed to cut them down about a foot.Click image for larger version
ID:	2538016Click image for larger version
ID:	2538018Click image for larger version
bubbrik likes this.
post #20 of 58 Old 03-13-2019, 02:41 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
Now for the “crown”Click image for larger version
bubbrik likes this.
post #21 of 58 Old 03-14-2019, 05:20 PM
pkinneb's Avatar
Quoted: 374 Post(s)
Liked: 1278
Originally Posted by Jglass4788 View Post
Now for the “crown”Attachment 2538608
That is looking great!
Jglass4788 likes this.
pkinneb is online now
post #22 of 58 Old 03-15-2019, 04:05 AM
pcdoctor's Avatar
When I think I've seen it all, here comes something else.
Simply amazing!
pcdoctor is offline
post #23 of 58 Old 03-16-2019, 01:09 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
Thanks for the positive feedback!!
Really fun project...enjoying it.
Have a couple issues- 1st one: I needed to trim down the bases. But my saw caught it and broke a corner.
So I needed to build it back. Click image for larger version
ID:	2540050Click image for larger version
ID:	2540052Click image for larger version
ID:	2540054Click image for larger version
ID:	2540056Click image for larger version
ID:	2540058Click image for larger version
ID:	2540060Click image for larger version
ID:	2540062Click image for larger version
bubbrik likes this.
post #24 of 58 Old 03-16-2019, 01:12 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
2nd issue: I’ve been trying the crown around the”curve”, but I just cant get it to go.
I bought the PVC Crown, but that doesn’t work either(to much curve).
So I needed to purchase the flexible Crown.
$125 for 12 ft—-Yikes!!Click image for larger version
post #25 of 58 Old 03-16-2019, 01:28 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
So both columns are trimmed/fitted.
Now I’ll take them back out to the garage to strip the paint off them
Then looks like I’ll be waiting till my flexible Crown Molding comes in {about one week....Ugh}Click image for larger version
bubbrik likes this.
post #26 of 58 Old 04-01-2019, 03:03 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
Finally got the flexible crown molding. I gotta say...not cheap, but simply amazing stuff!!
bubbrik likes this.
post #27 of 58 Old 05-27-2019, 05:51 AM
Superman07's Avatar
Quoted: 191 Post(s)
Liked: 53
Any more updates?!
Superman07 is offline
post #28 of 58 Old 05-29-2019, 06:19 PM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
So nice outside....been working on the “outdoor theater”(gotta keep on with speaker addiction) not much more progress...but soon I’ll update this.
post #29 of 58 Old 06-03-2019, 08:48 AM
nebrunner's Avatar
Quoted: 148 Post(s)
Liked: 108
*picking jaw up off floor*
- subscribed -
nebrunner is offline
post #30 of 58 Old 06-06-2019, 09:25 AM - Thread Starter
Jglass4788's Avatar
Quoted: 22 Post(s)
Liked: 138
Alright....after a short pause....I’m back at it!
The challenge has been with this “flexible crown molding. Base upon my curve, the crown keep “folding” up.
I tried putting some blocks between it and the ceiling, but it doesn’t lock in.
Reply Theater Room Items & Accessories
