LED Poster Frame/Light Box: Hiding or Recessing Cords and PS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-25-2019, 12:09 PM - Thread Starter
SaulP's Avatar
Quoted: 35 Post(s)
Liked: 53
I have two LED backlit poster frames and just purchased four more. Each of them has a short 12v power cable "dongle" coming out of the bottom corner of the frame. There is a "power brick" that converts line voltage to 12v. A standard 2 prong power cord goes into one end of the brick and a longer 12v cable goes out from the other and attaches to the frame "dongle".
Here's a picture, I hope of a very similar frame with very similar cables.
I'm having some work done on my HT room and would like to hide the cables and was hoping that folks on this board might have some ideas how to do that. I could recess a power receptacle behind the poster, but it would have to be pretty big to fit the power cable and brick. Any other thoughts? Pictures?
SaulP is offline
post #2 of 4 Old 03-25-2019, 04:52 PM
Liked: 3
I don't know how deep you need for the PS, but something like this might work:
https://www.lowes.com/pd/CARLON-3-Ga...al-Box/3421352
The heading says low voltage, but the description said dual voltage, and it has a picture of an outlet, so it should be able to handle 110v.
Good2BCh13f is offline
post #3 of 4 Old 03-26-2019, 05:43 AM
Quoted: 5291 Post(s)
Liked: 4891
do something like this, a big recessed box behind the poster, cut the plug end off the power cord leaving 6-8 inches. Use twister nuts to connect the power cord bare wire to Romex in the box. Stuff everything in the box and hang the poster. If you need more room they make 3 and 4 gang old work boxes.
post #4 of 4 Old 04-06-2019, 09:25 PM
Tedd's Avatar
Quoted: 1869 Post(s)
Liked: 742
You float them off of the wall, by a couple of vertical boards, which would effectively would hide the new electrical outlet and the power brick.
That would give you an open top and bottom, for any needed cooling of the power brick (which appears to be ventilated).
Tedd is offline
Reply Theater Room Items & Accessories
