LCR Speakers for AT Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-08-2019, 05:54 PM - Thread Starter
Liked: 0
I'm a complete newbie when it comes to home theater and I have a basic question. I want to use in wall speakers behind an AT screen to save space. After some research it looks like using the same speakers for LCR is recommended. Do I use three L/R speakers or three center speakers?
I'm not a audiophile and with my low budget I won't be spending a lot of money on speakers but I want to make sure I make an informed decision. Any information would be appreciated.
James Thomas is offline
post #2 of 4 Old 04-09-2019, 08:22 AM
Mr.G's Avatar
Quoted: 1173 Post(s)
Liked: 1006
You don't state your budget so I'm assuming the lower the price the better. If you're mounting in-wall speakers for your left, center and right channels take a look at some of the in-wall speakers at the Monoprice.com website.
https://www.monoprice.com/category/a...iling-speakers
Be sure to include a separate subwoofer with any in-wall speakers you select. Remember most wall studs are 16" on center so factor that into your speaker selection.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is online now
post #3 of 4 Old 04-09-2019, 08:53 AM
Quoted: 5291 Post(s)
Liked: 4891
You use identical L/C/R speakers. The number of center channel speakers that can be used both vertically and horizontally is limited and be aware of marketing claims versus measured polar response in your desired position. Stick with a speaker intended for L/R as your center and you won't go wrong.
post #4 of 4 Old 04-09-2019, 04:06 PM - Thread Starter
Liked: 0
That answers my question. Thank you very much!
Reply Theater Room Items & Accessories
