Power conditioner for wall mount TV - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By BIGmouthinDC
post #1 of 8 Old 07-19-2019, 10:41 AM - Thread Starter
biglen's Avatar
Quoted: 221 Post(s)
What are you guys doing for a power conditioner, with your wall mounted TV? Do they make one that fits behind the TV?
Sent from my SM-G950U using Tapatalk
biglen is offline
post #2 of 8 Old 07-19-2019, 01:12 PM
Quoted: 5626 Post(s)
Liked: 5199
You can use a power bridge that you plug into your selected power conditioner. There are several similar brands, Midlite, Monoprice.
https://www.powerbridgesolution.com/...t/model-one-ck
bluer101 likes this.
post #3 of 8 Old 07-19-2019, 01:29 PM
Jawaburger's Avatar
Quoted: 192 Post(s)
Liked: 190
This may work for you, it is made by Panamax:
https://www.amazon.com/Panamax-MD2-A...34352778&psc=1
Sharp LC-80LE844U | Marantz BD8002 | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | Phase Tech PC 9.1 (FL/FR) | Phase Tech PC 3.1 (C/SL/SR) | Dual PSA S1811 Subs
Jawaburger is online now
post #4 of 8 Old 07-19-2019, 07:50 PM
bluer101's Avatar
Quoted: 632 Post(s)
Liked: 714
Power bridge is the way to go. Have them in every room where there is a tv. Also use diy power bridges in my theater.
bluer101 is online now
post #5 of 8 Old 07-20-2019, 05:39 AM - Thread Starter
biglen's Avatar
Quoted: 221 Post(s)
I can't see how the Power Bridge would work for me. My TV is mounted on my movie room wall, and it's the only thing on the wall. I have all my audio equipment hidden in a closet, so I don't have a TV stand or entertainment center that would hide the power cord of the Power Bridge.
biglen is offline
post #6 of 8 Old 07-20-2019, 09:33 AM
Liked: 5199
you put the power inlet in the equipment closet and run all the wires to the TV. The only difference is the power bridge pictures show it just below the TV, it doesn't have to be there, In your case I would just order this and run Romex to an outlet behind the TV. https://www.amazon.com/Midlite-MDT46...gateway&sr=8-1
This solution is all about tucking the power conditioner out of sight in a different location than the TV, If you can fit something behind your TV that satisfiesyour requirements, do it. There are plenty of outlet based surge protectors if that is all you need. https://www.homedepot.com/p/Leviton-...E&gclsrc=aw.ds
post #7 of 8 Old 07-20-2019, 08:12 PM
bluer101's Avatar
Quoted: 632 Post(s)
Liked: 714
Yep, this is how my rear powered subs, projector, and poster display are done. Romex is ran from my rack outside the room to these items. Then I have short extension plugs that plug into my power conditioner or battery backup.
Parts list.
Power inlet.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Wall plates.
Power cords.
Outlet boxes (deep)
https://www.homedepot.com/p/Carlon-1...120R/202077323
You can see them in this picture.
post #8 of 8 Old 07-20-2019, 08:25 PM - Thread Starter
biglen's Avatar
Quoted: 221 Post(s)
I found this. It looks like a great option.
https://www.av-iq.com/avcat/ctl1642/...b-200-iw-2-wht
biglen is offline
Reply Theater Room Items & Accessories
