Cloth seats on a budget? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-14-2019, 08:06 PM - Thread Starter
bloodta's Avatar
Quoted: 89 Post(s)
I’m looking for a row of 4 seats finished with cloth and on a budget. BTW My room is 12’8” wide, so I would like some clearance on both sides.
bloodta is offline
post #2 of 3 Old 08-17-2019, 01:15 AM
Shawn Colton's Avatar
Here you go ... just choose Microfiber from the options ...
https://www.theaterseatstore.com/oct...t-xs750-custom
You can squeeze a few more inches by doing a IOIOOIOI configuration (chair/loveseat/chair).
-Shawn
Shawn Colton is offline
post #3 of 3 Old 08-17-2019, 05:29 PM - Thread Starter
bloodta's Avatar
Quoted: 89 Post(s)
Thanks for the link
I’️m looking for a row of 4 seats finished with cloth and on a budget. BTW My room is 12’️8” wide, so I would like some clearance on both sides.
-Shawn
bloodta is offline
Reply Theater Room Items & Accessories
