Projector shelf? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-29-2019, 10:49 AM - Thread Starter
Cla55clown's Avatar
Quoted: 389 Post(s)
Liked: 120
Projector shelf?
Has anyone sourced a good quality wooden projector shelf that mounts to the back wall? I have an Epson 3700 that I want to place on it. A quick Amazon search doesn't provide the look or quality I'm looking for. I know I could DIY one but with 2 very young toddlers and a full time job, I don't have a lot of time for building stuff.
My basement finishing company is charging $250 to build one from scratch and I feel that's a little expensive for what it is.
Cla55clown is offline
post #2 of 5 Old 10-29-2019, 01:27 PM
Quoted: 6172 Post(s)
Liked: 5856
Spray paint a color to go with your room and run a screw through the top into the support so it doesn't fold up.
https://www.amazon.com/Furinno-FNAJ-...fsclp_pl_dp_11
post #3 of 5 Old 11-13-2019, 02:04 PM
genaccmiller's Avatar
Quoted: 789 Post(s)
Liked: 184
Jeff - How do you ensure the projector does not fall off?
Step by Step Theater Build - http://imgur.com/gallery/2tpaSru
My Theater Build Youtube Channel - https://www.youtube.com/channel/UCs_..._as=subscriber
My Theater Build Thread - https://www.avsforum.com/forum/19-de...ld-thread.html
genaccmiller is offline
post #4 of 5 Old 11-13-2019, 02:36 PM
Liked: 5856
Mount it level, use non slip rug pads under the feet if you are concerned. As MM commented on your thread this isn't big enough for the projectors you are looking at. I'm sure there are other larger versions.
post #5 of 5 Old 11-13-2019, 05:52 PM
Quoted: 789 Post(s)
Liked: 184
I think it is big enough. The 3800 dimensions are: 16.1 x 13 x 6.5 which this can easily accommodate.
Sent from my Moto G (5) Plus using Tapatalk
Reply Theater Room Items & Accessories
