MovieNow! Digital movie poster app for Raspberry pi - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #91 of 132 Old 11-30-2019, 08:27 AM - Thread Starter
0raid's Avatar
Quoted: 38 Post(s)
Liked: 48
Originally Posted by harrytasker1 View Post
Yes i got it to work, thank you. Little donation on the way
I’m glad it worked out , and thanks for your support/donation!!
0raid is online now
post #92 of 132 Old 11-30-2019, 11:32 AM
harrytasker1's Avatar
Your welcome!
Everything boots up fine now, but somehow i can't get any movies from my Kodi. I have Kodi installed on my Nvidia Shield TV.
I can login to the Kodi from my PC through port 8080. Put all the settings in the config file, but cant get it to work.
Is there some sort of log file for debugging? Thanks!
Format Neutral
harrytasker1 is offline
post #93 of 132 Old 11-30-2019, 11:47 AM
MidnightWatcher's Avatar
Quoted: 195 Post(s)
Liked: 201
@0raid , maybe put a Frequently Asked Questions section on the homepage and on the original post page 1 of common questions and solutions.
MidnightWatcher is offline
post #94 of 132 Old 12-01-2019, 05:46 AM - Thread Starter
0raid's Avatar
Quoted: 38 Post(s)
Liked: 48
Your welcome!
maybe something is wrong in your config.js file
example:
var host = '192.168.5.180'; // kodi IP. (be careful that you have the ' and the ; in the end)
var port = '9090'; // kodi port
your web port is 8080 , but the tcp port is 9090 , so in the config file dont put 8080 , leave it 9090.......also did you have password in your kodi? if yes then in the config.js put the kodi url like this:
var host = username[email protected]'; // kodi IP. (be careful that you have the ' and the ; in the end)
let me know if it works.
0raid is online now
post #95 of 132 Old 12-01-2019, 12:26 PM
example:
I already did the following:
allow remore control via http
allow remote control from application on this system
allow remote control from applocation om other systems
My config file looks like this:
Code:
// MovieNow!
var host = '192.168.1.142'; // kodi IP
So i think i did everything right. I'll just wait till the next release the coming week hopefully i will get it running then!
Thanks for the help!
Format Neutral
post #96 of 132 Old 12-01-2019, 05:06 PM
Liked: 0
I just setup a Plex server and really looking forward to your 2.0 update with Plex support. I wasn't sure how much Plex support this would get as it seems Plex stopped Plugin support a few years ago? Wasn't sure how hard it would be to setup. Just curious can we follow your progress on a social media like Twitter?
Thanks again for all your hard work.
Jason Schnabel is offline
post #97 of 132 Old 12-01-2019, 05:07 PM
Quoted: 36 Post(s)
Still wishing this was on GitHub! Would love to develop support for additional players.
Good2BCh13f likes this.
livitup311 is offline
post #98 of 132 Old 12-01-2019, 06:46 PM - Thread Starter
0raid's Avatar
Quoted: 38 Post(s)
Liked: 48
Code:
// MovieNow!
did you see the banner coming soon? , also when you play a movie from your kodi library did you see the banner now playing?
0raid is online now
post #99 of 132 Old 12-01-2019, 06:51 PM - Thread Starter
0raid's Avatar
Quoted: 38 Post(s)
Liked: 48
if anyone need support , just find me & add me in skype: Georgios_Raid
0raid is online now
post #100 of 132 Old 12-03-2019, 08:55 PM
Liked: 0
Same here with things not working. I am using kodi 18.5 on xbuntu 18.04.3. Movienow is on a Raspberry Pi 2 with a wifi adapter. (tried hardwired as well)
- Enabled all remote control and apps on Kodi (tested with phone app and C4 remote)
- Burned image
- booted pi
- change config.js to match Kodi IP
- rebooted
I only see the bottom icons no header (no coming soon or Now showing) and a black screen
what I tested
- Can see my Kodi web control from Movienow
- Can see Movienow settings from Kodi
- Can see usual web traffic on movienow (google searches) **however, if I exit full screen and do a web search, when I reboot movienow doesn't show up. Google search does**
- Tried only using wired (removed module)
- Tried only wifi
- Tried pi 3B+
- Different Kodi skins
- Different Kodi movies
All produced the same results. Movienow boots to black screen with logos at the bottom. It never connects to kodi
thetechhipster is offline
post #101 of 132 Old 12-04-2019, 06:43 AM
opeters's Avatar
Quoted: 14 Post(s)
- Burned image
- booted pi
- rebooted
what I tested
- Tried only wifi
- Tried pi 3B+
You need to clear the chromium cache folder. I encountered the same issue.
Connect to the pi (SSH or SFTP) and clear the cache folder.
I cant access the system now so I can't give you the exact location of the folder.
opeters is offline
post #102 of 132 Old 12-04-2019, 07:31 AM
YumMasterYum's Avatar
Quoted: 26 Post(s)
Liked: 31
I have a spare Raspberry Pi. I have a spare Monitor. I have a Synology NAS drive. but... I don't use Kodi.
Is there a way to easily set-up a Kodi server on my existing NAS drive for the sole purpose of using MovieNow? Would I then just download some movie posters and throw them in a folder?
YumMasterYum is online now
post #103 of 132 Old 12-04-2019, 09:28 AM - Thread Starter
0raid's Avatar
Quoted: 38 Post(s)
Liked: 48
connect to movienow terminal and run this command
sudo rm -r ~/.cache/chromium/Default/Cache/*
this delete the cache folder......
then reboot with this command
sudo reboot
0raid is online now
post #104 of 132 Old 12-04-2019, 08:34 PM
Liked: 0
sudo reboot
That got be back to the black screen but that's it. Still no headers or posters
post #105 of 132 Old 12-04-2019, 08:48 PM
Liked: 0
Ok I have no idea what happened but the second time I cleared the cache while a movie was playing everything just worked. This looks amazing. I can't wait to see where the project goes. Now to design a frame.
post #106 of 132 Old 12-05-2019, 05:42 AM - Thread Starter
0raid's Avatar
Quoted: 38 Post(s)
Liked: 48
i'm glad things are working out for you , enjoy the app! second version is coming very soon , still i am trying to find the time to compile the new version!
* new version has in the settings a button to clear the cache!
George
Randybw1 and tjambro like this.
0raid is online now
post #107 of 132 Old 12-05-2019, 11:01 AM - Thread Starter
0raid's Avatar
Quoted: 38 Post(s)
Liked: 48
I want to thank all the people who has donate and support the project! thats why all this people will get first the second version before the public release + personal support and custom features.
0raid is online now
post #108 of 132 Old 12-05-2019, 12:03 PM - Thread Starter
0raid's Avatar
Quoted: 38 Post(s)
Liked: 48
with a little coding , yes you can do it!!
0raid is online now
post #109 of 132 Old 12-05-2019, 03:33 PM
Quoted: 26 Post(s)
Liked: 31
Coding isn't really my thing. Is there a write-up on running Kodi on a NAS with this app?
post #110 of 132 Old 12-06-2019, 08:12 PM
audiomirage's Avatar
Quoted: 36 Post(s)
I guess I had better get my donation in!.......Done!
11.2 Home Theater: SPEAKERS: Front Main-Mirage OMD-28's, Center-Mirage OMD-C2, Front High-Mirage OMD-5's, Front Wide-Mirage OMD-5's, Side & Rear Surrounds-Mirage OMD-5's, Subwoofers, (2) Klipsch R-112SW. EQUIP: Receiver:Denon AVR-X8500H, Amplifier: Emotiva XPA-3, Projector:3D Epson PowerLite Home Cinema 5030UB, Screen: Draper 3D PREMIER TECVISION 161" HDTV (16:9) XT1800X WHITE, Blu-ray Player:Oppo UDP-203, Gaming: Xbox One X
audiomirage is offline
post #111 of 132 Old Yesterday, 10:46 AM - Thread Starter
0raid's Avatar
Quoted: 38 Post(s)
Liked: 48
Thank you for your support/donation!! i have start to compile the second version!
harrytasker1 and audiomirage like this.
0raid is online now
post #112 of 132 Old Yesterday, 07:23 PM
RockDawg's Avatar
Quoted: 151 Post(s)
Liked: 44
I have so wanted to do this for a while but the hold up for me has been figuring out a way to get the TV to turn on automatically or by switch. Do any of you guys know of a reliable way to do that?
My theater room is in a basement so you have to walk down stairs before you get to the "lobby" where the TV would be. If I could have a switch or something at the top of the stairs to turn it on/off so that it would already be displaying when you reach the lobby, that would be great. If I have to walk down and manually turn it on and wit for it to display, that would really kill the experience IMO.
Anybody have a working solution for this?
Edit: to expand a bit I'm sure it could be controlled via smart app but I'm not a fan of that solution as I'd prefer something not requiring extra thought be put into it ahead of time to turn it on.
RockDawg is online now
post #113 of 132 Old Today, 05:50 AM - Thread Starter
0raid's Avatar
Quoted: 38 Post(s)
Liked: 48
Hello! - yes you can do it!! because my app is running on raspberry pi (rasp except mini linux device is also a mini controller with multi GPIO) + rasp support HDMI-CEC
so here some ideas!
1) connect a PIR sensor with the raspberry , so when the rasp detect movement open the display and stay ON for X minutes
2) connect a Magnetic Door Sensor with raspberry , so when you open the door , its open the display and stay ON for X minutes
3) Put a button/switch near the door , so you can manual turn on/off the display
4) With your mobile , you can turn ON/OFF the display if you are connect to the same WIFI network as the raspberry
5) Put a tablet (new / old) in the wall near the door and open from there the display
6) You can do it also with RF 433Mhz Remote Control
i can help you with all the above solution and make the custom code for your project!
Georgios
Sauwill likes this.
0raid is online now
post #114 of 132 Old Today, 11:19 AM
RockDawg's Avatar
Quoted: 151 Post(s)
Liked: 44
so here some ideas!
Georgios
Thanks for your offer to help. #3 would probably be my ideal solution. What hardware would I need?
post #115 of 132 Old Today, 11:31 AM - Thread Starter
0raid's Avatar
Quoted: 38 Post(s)
Liked: 48
Thanks for you offer to help. #3 would probably be my ideal solution. What hardware would I need?
any switch or button , then you need to run the wires from the switch to the raspberry / poster display and connect it to GPIO pins (i will make a small code for you and tell you in which pins you must connect it)
here is some examples of buttons and switches.
ID:	2651058   Click image for larger version
ID:	2651060   Click image for larger version
ID:	2651062   Click image for larger version
harrytasker1 likes this.
0raid is online now
post #116 of 132 Old Today, 11:42 AM
RockDawg's Avatar
Quoted: 151 Post(s)
Liked: 44
It would be very difficult to run a wire to the TV location. Is there a wireless switch that would work?
post #117 of 132 Old Today, 11:56 AM - Thread Starter
0raid's Avatar
Quoted: 38 Post(s)
Liked: 48
yes many , raspberry pi is compatible with almost anything!!
0raid is online now
post #118 of 132 Old Today, 03:58 PM
RockDawg's Avatar
Quoted: 151 Post(s)
Liked: 44
So I can use something like this?
https://www.amazon.com/dp/B07S2RM95K..._t2_B073DZQL8H
post #119 of 132 Old Today, 04:10 PM
Quoted: 25 Post(s)
Liked: 7
I know you mentioned you don’t want to use a smart app because you don’t want to have to say anything, but you wouldn’t have to. Create a routine in SmartThings or Alexa app that when your sensor is triggered, it turns the tv on. Simple to do and you won’t have to say anything. Samsung and Vizio are two brands I know can do it. I bet there are more
enovison is online now
post #120 of 132 Old Today, 04:21 PM
Quoted: 25 Post(s)
Liked: 7
Thanks for all of your great work on this! Do you think it’s possible to connect the raspberry pi to this attached LED sign? Check out this developer link. It could be a nice feature to have the currently playing movie title on the sign like In the real movie theaters!
https://brightledsigns.com/info/developers
Reply Theater Room Items & Accessories
movie posters , Raspberry Pi
