TV stands > OK to go above the size specs? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By kjfalls
post #1 of 5 Old 11-19-2019, 02:59 PM - Thread Starter
peter17319's Avatar
I got a stand like this from Costco ~6 years ago. Brand is Whalen, I think? It says it's for "TVs up to 60 inches and 130 pounds". For those 6 years I've been hanging a 60" plasma that's 66 pounds.
I might be upgrading to a 65", and I'm sure that will be fine (Vizio P-Series Quantum X, only weighs 54 pounds).
But I'm also considering the 75" model. The weight is good (79 pounds), but am I running the risk of creating too much strain/torque?
A 75" TV nowadays is certainly lighter and thinner than they were 6-7 years ago, so maybe I shouldn't worry as long as it's not too heavy?
Am I over-thinking this?
peter17319 is offline
post #2 of 5 Old 11-25-2019, 07:47 AM - Thread Starter
peter17319's Avatar
Bumping as BF rapidly approaches.
post #3 of 5 Old 11-25-2019, 08:04 AM
kjfalls's Avatar
Location: Dennison IL, just across the state line from Terre
Quoted: 339 Post(s)
Liked: 118
I don't think you'll have any problem mounting a current 75" TV using a mount which held an earlier 65" model. Just make sure the VESA mount size is the same as the TV you're purchasing and the weight of the new TV is less than the mounts MAX.
Adamg (Ret-Navy) likes this.
kjfalls is offline
post #4 of 5 Old 11-25-2019, 09:19 AM
Mocs123's Avatar
Quoted: 330 Post(s)
Liked: 178
I don't see a problem with mounting a larger TV on that stand as long as it's under the weight limit.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, 4 - 15" DIY Sealed Subs
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is online now
post #5 of 5 Old 11-25-2019, 10:09 AM - Thread Starter
peter17319's Avatar
No worries there. It's the kind of stand with two hooks that attach to the VESA mounts on the TV, and there are lots of holes to use. Not exactly like this, but similar.
Reply Theater Room Items & Accessories
