Theatre Room. Wall paint - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By rontalley
  • 1 Post By BIGmouthinDC
  • 1 Post By dsskid
post #1 of 8 Old 01-23-2020, 10:36 PM - Thread Starter
rtekkam's Avatar
Hi all, building a new dedicated theatre room. Sheetrock is installed. Now just have to figure out the color of walls. The carpet is a dark greysh black. I plan to have led light ambient around the crown molding.
Looking for suggestions of ideal color/ texture for wall paint.
Sent from my Pixel 3a using Tapatalk
rtekkam is offline
post #2 of 8 Old 01-24-2020, 08:25 AM
dsskid's Avatar
Quoted: 296 Post(s)
Liked: 277
If you are looking to protect the actual fidelity of the picture, without adding color contamination, then I suggest a neutral color.
Depends on how dark you want to go. Spears & Munsell N7 nn would be my choice, or varying shades darker or lighter.
https://www.myperfectcolor.com/paint...al-value-scale
ISF Calibrator
Samsung PN64F8500, Denon AVR-S910.
Pioneer Kuro Elite Pro-111FD, Denon AVR-X2400H, Palliser Flicks lOlOOlOl Dax material.
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #3 of 8 Old 01-24-2020, 08:42 AM
rontalley's Avatar
Quoted: 834 Post(s)
Liked: 426
You want to look at wall acoustical treatment. Without treating the walls acoustically, you will have echos and standing waves that will negatively effect the sound quality. Also depends on your viewing platform. i.e. Projector vs. TV and even then what type of TV and/or PJ. For PJs, it's more critical to get the theater as dark as possible to increase contrast.
Good info in this thread:
https://www.avsforum.com/forum/24-di...ter-image.html
I painted my ceilings black, covered my front wall in all black velvet and my walls are grey and my panels are covered in black velvet. This made a HUGE difference in Picture Quality (PQ) and Sound Quality (SQ).
For example, same color walls but ceiling black and wall treatment:
ID:	2675156   Click image for larger version
dsskid and rtekkam like this.
My Media Room
AVR 1-Yamaha RX-A3050 (7.2.4), AVR 2 Pioneer VSX-815-K(Used for 4ch Amp TF+TR)
Mains-Polk Audio RTi8, Center-Polk Audio CSi5, Surrounds-Polk Audio RTi4, Ceilings-Micca M-8C, Sub 1- UM18-22 (4cu.ft DIY) - iNuke 6000DSP, Sub 2-Klipsch RW12D
Projector-BenQ 3550 4K, Screen-110" Silver Ticket STR-169110, TV-Vizio P-65 4K
rontalley is online now
post #4 of 8 Old 01-24-2020, 10:14 PM - Thread Starter
rtekkam's Avatar
Thank you.
rtekkam is offline
post #5 of 8 Old 01-25-2020, 06:45 AM
Quoted: 6228 Post(s)
Liked: 5957
the darkest shade you can stand will result in the best on screen blacks. Remember the black you see on the screen is a white screen with no light shining on it. When you project an image light off the screen will reflect off surfaces in the room and make it's way back to the screen turning black areas gray. I wouldn't be able to handle an all black room but many enthusiasts do.
rboster likes this.
post #6 of 8 Old 01-25-2020, 06:53 AM
dsskid's Avatar
Quoted: 296 Post(s)
Liked: 277
A good compromise would be a black screen wall, and dark (Neutral) grey surrounding walls. Accessorize with color objects in the room to break it up.
rtekkam likes this.
ISF Calibrator
dsskid is offline
post #7 of 8 Old 01-26-2020, 10:12 PM - Thread Starter
rtekkam's Avatar
Appears there is something wornf with that link. I was able to access that discussion thread. Very useful information. Now I can't seem to get it. Appx 7000 posts.
rtekkam is offline
post #8 of 8 Old 01-26-2020, 11:10 PM
rontalley's Avatar
Quoted: 834 Post(s)
Liked: 426
Hmm. It works for me:
My Media Room
Reply Theater Room Items & Accessories
