CBS Transitioning to 16:9 Widescreen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 08-31-2013, 08:42 AM - Thread Starter
Tom Wellman's Avatar
Quoted: 28 Post(s)
Liked: 41
Well, I'm watching the US Open of Tennis on CBS (CBS 8-KFMB San Diego) and I've noticed that CBS at least in their sports coverage, the scorebox is outside the 4:3 safe zone.
I had a feeling a couple of months ago CBS would be in the process of doing this since there was a PGA event back in July & the CBS bug was outside the 4:3 safezone. I don't expect CBS to get rid of their scorebar for their football & basketball coverage, however what they can do is frame their games for 16:9 widescreen as opposed to keeping it 4:3 safe. Either way, chalk this up as progress for HDTV.
And the FOUL!
Tom Wellman is offline
post #2 of 13 Old 08-31-2013, 08:54 AM
Otto Pylot's Avatar
Quoted: 3457 Post(s)
Liked: 2508
Maybe it's your provider because up here in the Bay Area, CBS sports (OTA) has been fine for a very long time.
I never trust an atom, they make up everything.
Otto Pylot is offline
post #3 of 13 Old 08-31-2013, 09:23 AM - Thread Starter
Quoted: 28 Post(s)
Liked: 41
I don't know where you thought it was a complaint Otto Pylot because it wasn't.
And the FOUL!
post #4 of 13 Old 08-31-2013, 02:24 PM
Kascnef82's Avatar
Liked: 42
Lets see abc and nbc follow suit. Fox was the first. Probably channel 11 and my9 should do it. Yes network too. Cbs needs to letterbox channel 2 sd since its cut off.
quentenstash likes this.
Kascnef82 is offline
post #5 of 13 Old 09-01-2013, 09:04 AM - Thread Starter
Quoted: 28 Post(s)
Liked: 41
Well, it's only going to be a matter of time before YES Network goes to 16:9 widescreen format. Fox bought a 49% stake in that channel. This is just going on a hunch, but I could see YES going that route in time for the start of Nets basketball or Yankees baseball next season. You mentioned that WCBS in SD is cutoff. I remember when Fox went to 16:9 back in mid 2010, it took their network affiliates a couple of months to make transition. Honestly I would've thought ABC would've been the next major broadcast network to go 16:9 since ESPN produces their sports, then CBS, then NBC being the holdout.
And the FOUL!
post #6 of 13 Old 09-01-2013, 12:08 PM
Kascnef82's Avatar
Liked: 42
News 12 does 16:9 for weather alerts as a map of nj or another area has a red outline for severe weather. That map is cutoff in sd but shown in left side of screen.
post #7 of 13 Old 09-01-2013, 12:08 PM
Kascnef82's Avatar
Liked: 42
How about sny?
post #8 of 13 Old 09-02-2013, 11:13 AM
Kascnef82's Avatar
Liked: 42
Nfl network is 16:9. So is every other sports network. Espn classic is standard def and that's a good thing.
post #9 of 13 Old 09-02-2013, 06:32 PM
URFloorMatt's Avatar
I noticed during the PGA Championship that the CBS logo was outside the safe zone as well.
Going 16:9 doesn't mean much unless the graphics package is left-aligned, like Fox's football and baseball packages. CBS, NBC, and ESPN currently all have score boxes that are center-aligned for football (unless that changes up this week with the new season).
NBC's EPL graphics on Sunday were outside the safe zone and left-aligned, but also enormous and with ads attached so there wasn't a lot of benefit.
URFloorMatt is offline
post #10 of 13 Old 09-02-2013, 09:38 PM
Drewdawg's Avatar
Here is the CBS pic with the side panels in b/w so you can see what is cut out of the 4x3 safe area.
The court is in the square zone but the graphic is clearly out to the left.
Drewdawg is offline
post #11 of 13 Old 09-03-2013, 01:21 AM
sneals2000's Avatar
Quoted: 477 Post(s)
Liked: 242
Presumably the shot framing is for other international broadcaster who may still be 4:3 (or have 4:3 outlets for their 16:9 content)? The graphics are a different issue as they need not be shared by others?
The BBC have recently switched to 16:9 graphics safe (from their mixed economy of 4:3 and 14:9 graphics safe) since all BBC distribution domestically is now 16:9 SD or HD (with any conversion to 4:3 taking place "in receiver" where 4:3 centre-cut or 16:9 letterbox are universally available). Not all shows have redesigned their graphics yet - but the new network "end credit slide" is no longer anything but 16:9 safe, and a saturday football results show is now very 16:9.
sneals2000 is offline
post #12 of 13 Old 09-03-2013, 01:20 PM
Kascnef82's Avatar
Liked: 42
All broadcast news outlets with the exception of fox pbs and bbc use 4:3 safe zone even the local news outlets. Cnn and faux news use widescreen and msnbc does 4:3. The olympicsare 4:3 but could go 16:9 in 2014.
post #13 of 13 Old 09-03-2013, 07:25 PM
NetworkTV's Avatar
Quoted: 1227 Post(s)
Liked: 2105
Well, being tennis, it's not necessarily simple.
Unlike with most sports, tennis has a vertical field of play.
If you look close, there isn't that much outside of the play area shown above and below the court (and the lighter area above and below, while out of bounds for the ball, are still in play for the players). If the zoomed in too much further, they might run the risk of missing a quick dive for the ball when they have to move the camera to follow.
If the example were football and there was a ton of extra space on either side of the line of scrimage (especially in the back field), then it would be safer to say they were framing for 4x3.
NetworkTV is offline
Reply HDTV Programming
