Directv II HD/4k - Page 122 - AVS Forum | Home Theater Discussions And Reviews
 16465Likes
post #3631 of 6373 Old 04-09-2018, 06:54 AM
bluemoon737's Avatar
Quoted: 2210 Post(s)
Liked: 2710
Originally Posted by jmacari View Post
Did not realize it was a problem with my Sony 930D; for me, it's easier just to re-check the box in the DIRECTV menu....
The 930D shouldn't be effected since it doesn't support DV. Did your 930D just receive a software update before you started getting blanking?
-Jeff-
Man cave: Sony XBR75Z9D, Marantz SR8012, and OPPO UDP-203
Living room: Sony XBR75X950G, Denon x4500, and Sony UBP-X800M2
bluemoon737 is offline
post #3632 of 6373 Old 04-09-2018, 07:02 AM
Quoted: 760 Post(s)
Liked: 686
Originally Posted by rjhseven View Post
My PQ on the Masters today on Directv 4K station was very mediocre. It must be the settings as it actually looked better on our local CBS affiliate. Was getting correct resolution and System info showed HLG. It there a settings that are specifically set up for 4K that you have been happy with?
I thought it looked incredible! Turning to CBS made me feel like i just took my contacts out
joe221, tmdorsey, jmacari and 3 others like this.
wmoss35 is offline
post #3633 of 6373 Old 04-09-2018, 07:50 AM
jmacari's Avatar
Quoted: 304 Post(s)
Liked: 940
Just the latest update (Nougat) last month; DV??..... DIRECTV UHD supports HDR/HLG (do not think DV)...and resolution box checks itself ONLY every once in awhile.
Anthem MRX-720,Outlaw 7500 5ch amp, B&K ST 202 amp
Oppo BDP-103, Sony XBR-65X930D, Rotel RP-855, Phillips BDP-7501
Paradigm Studio 100 Fronts, Martin Logan Motion LX16 rears,Martin Logan Motion 2's
Paradigm Studio cc-590 Center, Martin Logan Dynamo subwoofer, DefTech Supercube 4000
Roku Ultra, DIRECTV 4K Genie HR-54 DVR, C61K-700, OPPO Sonica DAC, Amazon Fire TV
jmacari is offline
post #3634 of 6373 Old 04-09-2018, 07:58 AM
Liked: 2710
Not talking about DV "for" DirecTV...it was the DV Sony update that started the problem on the X1E chipset TVs. But...since you are saying you have blanking on a 930D with DirecTV (and that is with a C61K correct?)...it very well could be that this problem is more widespread and many (myself included) assumed it was related to Sony's DV update since I have only been looking at X1E TV threads (930E, 940E, Z9D, A1E) looking for the problem. So if your 930D just recently received a firmware update and you now have blanking the problem may be associated with some modification that was made elsewhere within the OS of the TV.
Edit: Of course we could also be talking about entirely different things. I am referring to the situation where randomly while watching an SDR program on DirecTV (although it is not limited to DirecTV...but it seems to be the most prevalent), the video "blanks out" for a brief moment looking like a almost instantaneous black screen inserted. The duration of each blanking event can also vary but most are pretty much split second and the events are very random following no particular pattern.
-Jeff-
post #3635 of 6373 Old 04-09-2018, 08:05 AM
ggsantafe's Avatar
Quoted: 349 Post(s)
Liked: 294
It is a Sony problem. Do you have your C61K hooked through an AVR? One thing you can do is turn HDR off on the input you are using on the Sony...a pain yes, but it will stop the "blanking"...just have to remember to turn HDR back to AUTO when you want to watch HDR material via that input (including HLG stuff on Directv which ironically does not show the blanking problem).
Originally Posted by njfoses View Post
The belief is this is on the Sony side as others are reporting the "blinking" problem with various sources besides DTV across the Sony threads.
I do have my Sony & C61K connected to my Denon 6200 - and have seen mention of the "turn HDR" off on the 930e thread. I did use the Netflix internal streaming function on the 930e last night and saw zero blinking during an 1 1/2 film. I was initially concerned that I had a problem with the Sony itself - now it seems clear that the problem is more to do with the actual DirecTV interface that - hopefully - Sony and/or DirecTV will solve quickly!
ggsantafe is offline
post #3636 of 6373 Old 04-09-2018, 08:13 AM
Liked: 2710
It's not just the DirecTV to Sony connection. It is any device connected via HDMI to Sony DV TVs but the C61K appears to be the most prevalent "offender" (and then it "seems" to only be an issue if an AVR is in the chain).
-Jeff-
post #3637 of 6373 Old 04-09-2018, 08:18 AM
jmacari's Avatar
Quoted: 304 Post(s)
Liked: 940
No, wrong problem....
Every once in awhile, when switching to DIRECTV UHD ( channels 104, 105, 106) the 4K Resolution had reverted back to 1080i resolution...then the user has to go into Settings Menu, TV Resolution page, and click on the 4k radio button to switch resolution back to 4k...its pretty well known problem amongst DIRECTV 4K users...quite random from my research.
joe221 likes this.
jmacari is offline
post #3638 of 6373 Old 04-09-2018, 08:30 AM
ggsantafe's Avatar
Quoted: 349 Post(s)
Liked: 294
So, from what I've read - is this issue related to the DV update that didn't allow DV to pass through hdmi?
post #3639 of 6373 Old 04-09-2018, 08:45 AM
P Smith's Avatar
Quoted: 1184 Post(s)
Liked: 557
Exclamation
no
DTV don't provide HDR UHD content in DV !
P Smith is offline
post #3640 of 6373 Old 04-09-2018, 10:25 AM
Liked: 2710
Oh THAT issue...yeah, that's all on DirecTV.
-Jeff-
post #3641 of 6373 Old 04-09-2018, 10:31 AM
Liked: 2710
Okay, let's clarify...the Sony "blanking issue" showed up when any version of the Sony DV firmware was/is installed on the TV but does NOT have anything to do with trying to get DV or anything else from DirecTV (as we know DirecTV does not do DV and to my knowledge has no plans to do it). The only reason to say DV at all is in relation to what Sony firmware initiated the problem. No doubt the problem is primarily on Sony's end but the C61K "seems" to be the most problematic source device to trigger the issue.
Now back to our regularly scheduled DirecTV programming...
-Jeff-
post #3642 of 6373 Old 04-09-2018, 02:47 PM
Super Moderator
DrDon's Avatar
Quoted: 2569 Post(s)
Liked: 5033
Another day, another letter.
This time, DirecTV is telling me I'm going to lose a number of Music Choice channels starting in May. Taste Of Italy, Classical Masterpieces, Nature Sounds and some others. However, the monthly charge for Music Choice will come off of my bill. Woooo. a whole three dollars. If I want to keep the channels, I need to upgrade my package. BUT.. from what I can tell, some of them are on 110 or 119 as selecting the channels either results in no audio or the wrong audio. My Tampa dish doesn't do 110 or 119. I used to know which Sonic Tap channels were on which bird, but never bothered to look up MC channel locations.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #3643 of 6373 Old 04-09-2018, 03:33 PM
jus711's Avatar
Quoted: 23 Post(s)
Liked: 24
Originally Posted by wmoss35 View Post
Yeah, i get the 4k channels. My issue is not getting hdr because i have a samsung ks9800 which doesnt get hlg over hdmi.. at least yet
I get hlg/hdr over the RVU on my ks8000
azz7686 likes this.
jus711 is offline
post #3644 of 6373 Old 04-09-2018, 11:36 PM
P Smith's Avatar
Liked: 557
Exclamation
Originally Posted by DrDon View Post
.... I used to know which Sonic Tap channels were on which bird, but never bothered to look up MC channel locations.
Use weekly updating channel's map by Gary Toma at iamedgecutter site
P Smith is offline
post #3645 of 6373 Old 04-10-2018, 08:17 AM
Super Moderator
DrDon's Avatar
Liked: 5033
Yeah, I have that bookmarked. Just hadn't bothered. All of the listed channels I'd lose are on 119, as I assumed.
DrDon is offline
post #3646 of 6373 Old 04-10-2018, 08:27 AM
P Smith's Avatar
Liked: 557
don't assume DTV does shuffling channels regularly
P Smith is offline
post #3647 of 6373 Old 04-10-2018, 09:25 PM
crsloan's Avatar
Quoted: 57 Post(s)
Liked: 37
The "blanking" seems to be more prevalent lately, C61K>Denon X4200>Input 2 on Z9D. There was a Directv flash update this evening but I don't know what it updated, if anything related to our issue. I have HDR turned off. Lately the C61K loses picture, TV screen goes blank, then picture reappears, like its re-acquiring the signal??? Running premium certified HS cables from Monoprice. I am still waiting for Dolby Vision update for both my Denon X4200 and Oppo. Maybe those firmware updates will fix current issue???
Terminader likes this.
Family Room: Sony XBR-77A9G 4K TV, Denon AVR X4500H, Oppo UDP 203 4K Blu Ray Player, Apple 4K TV, Directv HR54 Genie, Directv C61K 4K Client
Klipsch RF83s, L&R mains, RC64, Center, RS 62s, Surrounds, 4 Dolby Atmos RP 140SA, 2 SVS SB-16 Ultra Subs, 5.2.4 system.
Bedroom: Sony XBR 49 900F, Oppo UDP 203 4K Blu Ray Player, Directv C61K 4K Client.
crsloan is offline
post #3648 of 6373 Old 04-10-2018, 10:10 PM
P Smith's Avatar
Liked: 557
Exclamation
perhaps you did not read same recommendation repeated so many times here - connect C61k to TV directly and use optical cable to connect C61k to AVR; same point for "re-acquiring the signal" idea - nope, it's HDCP negotiation happening again and again
P Smith is offline
post #3649 of 6373 Old 04-10-2018, 10:38 PM
crsloan's Avatar
Quoted: 57 Post(s)
Liked: 37
OK I will try that, defeats the purpose of running everything thru the AVR. Thanks for the advice!!
crsloan is offline
post #3650 of 6373 Old 04-11-2018, 06:38 PM
chad473's Avatar
Quoted: 144 Post(s)
Liked: 160
So, I (apparently naively) assumed that a new install would give me 4K. Quickly find out after some investigating that I was given an hr44 and only later find out that you need extra hardware. So just confirming...the only current way to get 4K to a single tv is through either 54/61k combo or a HR54 and rvu setup, both of which involving a second outlet fee? That seems absurd. To their credit they are sending someone out next week with with an HR54, but at this point I’m wondering if I should wait for a single box solution for 4k rather than pay for the additional hardware now and then again when a more elegant solution is available.
Sony 55X900e
Vizio P50-C1 - My Calibration Settings
Xbox One X
PS4 Pro
chad473 is offline
post #3651 of 6373 Old 04-11-2018, 07:01 PM
crsloan's Avatar
Quoted: 57 Post(s)
Liked: 37
you will press the installer for RB LNB, but usually all of them knew the future shift to RB and do install RB DLNB, just be persistent during install process
same for HS17 server - vocalize the fact: you have more then 1 UHD TV and only HS17 can support two 4k streams simultaniously (HR54 serving just one 4k TV)
if the tech have no HS17 nor RB DLNB in his truck, just refuse the install, do postpone it with the tech or/and call DTV if the tech will not follow your request
OK,
Currently running 2 C61Ks and 1 HR54, Is there an upgrade fee to go to an HS17 and do they have to also upgrade the LNB?
crsloan is offline
post #3652 of 6373 Old 04-11-2018, 10:23 PM
P Smith's Avatar
Liked: 557
OK,
Only CSR could answer the question after reviewing details of your account and its history ...
joe221 likes this.
P Smith is offline
post #3653 of 6373 Old 04-12-2018, 04:50 AM - Thread Starter
Quoted: 965 Post(s)
Liked: 482
Originally Posted by Terminader View Post
I have one....it's called the HS17.
Sent from my Samsung S8+ using Tapatalk
hs17 is not standalone
it still requires a c61k
so 2 boxes, but 1 fee
TV- Samsung 55" UHD (UN55JU6500FXZA)
service - directv
Receiver - Denon AVR-X2100W,
Speakers -F L/R - Infinity Primus P363, C - Infinity Primus PC351
Sub - Klipsch Sub-12HG
(slow build out)
mdram is offline
post #3654 of 6373 Old 04-12-2018, 05:06 AM
I WANT MORE's Avatar
Quoted: 735 Post(s)
Liked: 525
It's possible you could be waiting a very long time.
Perhaps I misremembered.
I WANT MORE is offline
post #3655 of 6373 Old 04-12-2018, 05:22 AM
P Smith's Avatar
Liked: 557
take a dish H3 DVR !
P Smith is offline
post #3656 of 6373 Old 04-12-2018, 07:40 AM
chad473's Avatar
Quoted: 144 Post(s)
Liked: 160
I've done a lot of reading since last night and that's what I'm gathering. I can begrudgingly work with the current way of getting 4k, but I'd really like to avoid having to replace a bunch of equipment when they change their 4k delivery. From what I see a new dish is likely going to be needed at some point...but unless I'm looking in the wrong places.. They seem either incredibly tight lipped about future 4k plans, or they have no idea and are still figuring things out. My impression, at least...
All this goes out the window if they do significant coverage of the world cup in 4k this summer. I'll put up with whatever is needed to see that.
Sony 55X900e
Xbox One X
PS4 Pro
chad473 is offline
post #3657 of 6373 Old 04-12-2018, 08:12 AM - Thread Starter
Quoted: 965 Post(s)
Liked: 482
dish should be fine if you have a current dish, just an lnb swap to a reverse band
service - directv
(slow build out)
mdram is offline
post #3658 of 6373 Old 04-12-2018, 08:29 AM
Liked: 2710
If ever...just read the AT&T tea leaves, their own commercials for DIRECTV NOW effectively bash satellite service. I haven't seen any news of new birds and not sure how much life is left in the aging ones (SW1/2 among others). I think development on the satellite hardware side is waning and the business model will be to shift over to streaming.
-Jeff-
post #3659 of 6373 Old 04-12-2018, 08:32 AM - Thread Starter
Quoted: 965 Post(s)
Liked: 482
doubtful, way too many people cannot stream.
they have a captive clientele with 15% of us having no cable/internet options. its easier to fight 1 company (dish) than all the streaming options
service - directv
(slow build out)
mdram is offline
post #3660 of 6373 Old 04-12-2018, 08:45 AM
chad473's Avatar
Quoted: 144 Post(s)
Liked: 160
Good to know. We just moved in to this house and there was already a dish installed. Tech yesterday did mention an LNB swap from what was up there. Anyway to find out if it's reverse band in the hr44 diagnostics? Or are those not even being installed yet?
Sony 55X900e
Xbox One X
PS4 Pro
chad473 is offline
Reply HDTV Programming
