Verizon FiOS HDTV - Page 628 - AVS Forum | Home Theater Discussions And Reviews
 250Likes
post #18811 of 19392 Old 10-29-2015, 08:09 PM
geenice's Avatar
Anyone ever buy a HD box off eBay and get it to work without paying a box rental fee or nah?
geenice is offline
post #18812 of 19392 Old 10-30-2015, 05:35 AM
Quoted: 4280 Post(s)
Liked: 5234
I don't believe that you can because Verizon will need the serial number to activate it and to the best of my knowledge you have to rent the box.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is online now
post #18813 of 19392 Old 10-30-2015, 05:35 AM
geenice's Avatar
geenice is offline
post #18814 of 19392 Old 10-30-2015, 09:44 AM
JDLIVE's Avatar
Quoted: 113 Post(s)
Liked: 64
Send a message via Yahoo to JDLIVE
If you want to use your own hardware, get a Tivo or a networked tuner like HDHomerun Prime and then all you'd need to pay for would be a CableCard.
JDLIVE is offline
post #18815 of 19392 Old 10-30-2015, 01:48 PM
davehancock's Avatar
Quoted: 113 Post(s)
Liked: 60
Those are often stolen.
Dave Hancock
davehancock is offline
post #18816 of 19392 Old 10-30-2015, 01:50 PM
geenice's Avatar
Duly noted
geenice is offline
post #18817 of 19392 Old 11-29-2015, 07:19 AM
sangs's Avatar
Quoted: 36 Post(s)
Liked: 31
This place is deader than Chris Christie's presidential aspirations.
dturturro likes this.
sangs is offline
post #18818 of 19392 Old 11-29-2015, 07:32 AM
Quoted: 113 Post(s)
Liked: 60
Thumbs down
Is that a reflection on:
  • FiOS?
  • AVS Forum?
  • or Success of DSL Reports?
sangs likes this.
Dave Hancock
post #18819 of 19392 Old 11-29-2015, 07:34 AM
sangs's Avatar
Quoted: 36 Post(s)
Liked: 31
  • FiOS?
  • AVS Forum?
Just this particular FiOS forum.
sangs is offline
post #18820 of 19392 Old 12-08-2015, 08:31 AM
Liked: 5234
Has anyone noticed in the past 2 weeks or so that you need to turn up the volume on your TV higher to get the same listening level as you used to have? It's almost as if Verizon lowered the reference level of the sound coming out of the set top box. I checked the settings on my box and they are all the same and my neighbor who has FiOS has the same exact experience.
John
jrref is online now
post #18821 of 19392 Old 12-08-2015, 08:44 AM
TitusTroy's Avatar
Quoted: 4200 Post(s)
Liked: 3752
so with picture quality not as good as it used to be with FiOS is it still the best among the major cable companies?...does it still offer a significant advantage in terms of picture quality when compared to TWC, RCN etc?...I mention RCN because it's available in my building and I like that they use TiVO boxes
TitusTroy is online now
post #18822 of 19392 Old 12-08-2015, 09:07 AM
UHD Addict
aaronwt's Avatar
Quoted: 8956 Post(s)
Liked: 5735
I have not noticed that issue here using a TiVo Roamio Pro, TiVo Bolt, and TiVo Mini.
49TB unRAID1a--53TB unRAID2--70TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #18823 of 19392 Old 12-08-2015, 09:08 AM
dsskid's Avatar
Quoted: 271 Post(s)
Liked: 258
They finally upgraded the app so you can watch all programming on your iPad, as well as programming you have DVR'd, while in your home, provided you have the Quantum system.
jrref likes this.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #18824 of 19392 Old 12-08-2015, 12:07 PM
Liked: 5234
I think FiOS still has the best picture quality even though it might not be as good as it was when it first came out.
John
jrref is online now
post #18825 of 19392 Old 12-08-2015, 12:43 PM
Quoted: 113 Post(s)
Liked: 60
It NEVER had basically superior picture quality. The video signal was/is divided into 6MHz channels (just like copper coax) and uses
the same modulation technique (QAM) as cable. The only potential quality difference would be how many channels that is crammed into one of those 6MHz channels. When it is 2 HD channels per QAM (6MHz channel), then the best quality is preserved. When they start cramming 3 HD channels in a QAM, then quality suffers. Much of this is determined on the local level, so in some areas 2 HD channels per QAM may be normal, while in other areas 3 channels per QAM may be normal. It is not unusual for some of the cable channels (like TNT) to have 3 channels per QAM, while the local OTA HD channels to be 2 per QAM. However, as the local stations start sending sub-channels, then THEY are decreasing quality, and the cable companies (including FiOS) have little incentive to allocate bandwidth for quality that is just not there anymore.
Dave Hancock
post #18826 of 19392 Old 12-08-2015, 01:44 PM
Liked: 5234
I agree with what you are saying but do you think cable has a better picture than FiOS? I've seen FiOS side by side with Cablevision here in NY and you can see that FiOS has a better picture even with all the cramming of HD channels.
John
jrref is online now
post #18827 of 19392 Old 12-08-2015, 02:16 PM
scott_bernstein's Avatar
Quoted: 98 Post(s)
Liked: 59
I have not noticed this. Are you referring to a particular channel?
scott_bernstein is offline
post #18828 of 19392 Old 12-08-2015, 06:21 PM
Liked: 5234
It seems to be all channels best I can tell.
John
jrref is online now
post #18829 of 19392 Old 12-09-2015, 04:54 AM
Dmon4u's Avatar
Quoted: 204 Post(s)
Liked: 125
Where is the Roku App with VOD ?
"There you go again..." - Good Ol' R. Reagan's favorite Troll line !
Dmon4u is offline
post #18830 of 19392 Old 12-09-2015, 06:43 AM
UHD Addict
aaronwt's Avatar
Liked: 5735
Depends on the area. Around here, Comcast doesn't come anywhere close to the majority of the FiOS channels. Of course teh quality of many channels on FiOS has deteriorated as they crammed more per QAm while staying at MPEG2. But in general when I visit my parents house and see their Comcast channels, they typically look bad when compared to what I see at home.
aaronwt is offline
post #18831 of 19392 Old 12-09-2015, 08:34 AM
TitusTroy's Avatar
Liked: 3752
I've noticed the ESPN and sports channels in general look much better on FiOS...I hear the premium movie channels have taken a hit in terms of picture quality with the most recent QAM slotting...but I guess FiOS is still the best choice compared to the competition
jrref likes this.
post #18832 of 19392 Old 12-19-2015, 06:11 AM
j45rpm's Avatar
Liked: 3
How much more are folks paying for quantum over regular FiOS tv? I don't really need more tuners–I'm not finding myself with conflict issues with the 2 tuners I've got now–but the newly released ability to stream recordings outside my home network with quantum is tempting. But it's not tempting enough to go from $15/month for the DVR to $30, which is what one rep quoted me. Is that really the deal that folks are taking?
j45rpm is offline
post #18833 of 19392 Old 12-19-2015, 09:10 AM
Liked: 5234
I thought it was only $10 extra but if you a not recording more than two shows at a time then you don't need it. The only other advantage is that Quantum upscales to 1080P vs 1080i for the older boxes giving you a slightly sharper picture.
John
jrref is online now
post #18834 of 19392 Old 12-19-2015, 03:15 PM
j45rpm's Avatar
Liked: 3
Thanks, John. That's good information to have.
I'm mostly thinking of it as a way to get Slingbox-type functionality without a slingbox. I'm not a huge fan of IR blasters, I'm not a huge fan of additional ads on top of the cost of a standalone-device, and I'd rather rent something from Verizon that can be replaced as newer tech comes out as opposed to owning a box that inevitably becomes obsolete in a year or two.
But on the other hand, I'm not a fan of paying much more for cable than I am. :P I will probably wait and see what Verizon does in that space, and hope prices come down.
j45rpm is offline
post #18835 of 19392 Old 12-19-2015, 03:17 PM
mrkalel's Avatar
Quoted: 37 Post(s)
But on the other hand, I'm not a fan of paying much more for cable than I am. I will probably wait and see what Verizon does in that space, and hope prices come down.
Hey fellows..you know Verizon just launched DVR remote streaming to their mobile apps? Works really really well! I get Hi-Def even on LTE.
Sent from my Nexus 6P using Tapatalk
jrref likes this.
mrkalel is offline
post #18836 of 19392 Old 12-19-2015, 03:19 PM
j45rpm's Avatar
Liked: 3
Yep! That's what I was trying to refer to–sorry for being unclear.
That's what attracts me to the idea of getting quantum TV (the DVR remote streaming doesn't work with the non-quantum TV DVRs, or so I've been told). I'm just having trouble pulling the trigger given the added monthly cost.
j45rpm is offline
post #18837 of 19392 Old 12-19-2015, 03:23 PM
mrkalel's Avatar
Quoted: 37 Post(s)
I think for all the headache and cost and annoyance associated to Slingbox... Just get quantum. (Plus everything else u get)
mrkalel is offline
post #18838 of 19392 Old 12-25-2015, 07:17 PM
leftyguitar1963's Avatar
Quoted: 128 Post(s)
Liked: 172
I heard Verizon sold off their Fiber biz in CA, TX & FL to Frontier.
I wonder what's in store for us in the impacted states? Hopefully better customer service for one.
leftyguitar1963 is offline
post #18839 of 19392 Old 12-25-2015, 07:41 PM
Quoted: 128 Post(s)
Liked: 172
http://meetfrontier.com/get-to-know-us
post #18840 of 19392 Old 12-26-2015, 02:48 PM
arnoldevns's Avatar
Quoted: 14 Post(s)
Yes, that deal was announced months ago. I think they'll actually take over sometime in the new year, but I wouldn't count on exactly when that will be.
arnoldevns is offline
Reply HDTV Programming
