Difference (if any) in CATV coax cable quality? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Otto Pylot
post #1 of 4 Old 07-28-2018, 09:37 PM - Thread Starter
ncsercs's Avatar
Quoted: 178 Post(s)
Liked: 101
I have various pieces of coax cable used for antennas and the only constant is stated "18AWG".
The rest state either:
  • "rg-6/u"
  • "cl2 rg6u quad shielded"
  • "cl2 rg6 triple shielded"
What's the difference (if any)?
Nick
Every day I beat my own previous record for the number of consecutive
days I've stayed alive. - George Carlin - 1996
ncsercs is offline
post #2 of 4 Old 07-28-2018, 11:33 PM
Otto Pylot's Avatar
Quoted: 3571 Post(s)
Liked: 2571
18AWG is the "thickness" of the cable. AWG = American Wire Gauge. The smaller the number, the thicker the cable wire. The thicker the cable wire, in theory, the better the signal propagation. However, if the wire is CCA (Copper Coated Aluminum), which most older wire is, the less reliable it is as opposed to a solid copper wire.
CL2 just means that it has met certain standards for fire safety. It has nothing to do with the ability of the cable to transmit data.
The RG6 "shielding" just means that there is an extra layer of protection for interference.
Otto Pylot is offline
post #3 of 4 Old 07-31-2018, 03:30 PM - Thread Starter
ncsercs's Avatar
Quoted: 178 Post(s)
Liked: 101
Amazon Basics is the one that reads 'Triple Shielded'.
Never seen that before. It's either double or quad.
Nick
ncsercs is offline
post #4 of 4 Old 07-31-2018, 07:52 PM
Otto Pylot's Avatar
Liked: 2571
Marketing mostly. Unless you're running your cable right next to power lines double shielded should be ok for most applications. BTW, I forgot to mention that a CL2 rating, while usually attributed to fire, refers to the voltage that the cable can safely carry without shock. CL2 is rated for 150v and CL3 is rated for 300v.
egnlsn likes this.
Reply Cable, Digital Cable - Non-HDTV
