(Help) HDMI on PS4 4k HDR premium - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Otto Pylot
post #1 of 11 Old 04-09-2019, 04:51 PM - Thread Starter
Liked: 0
Hello people. one help please
I would like to know which cables are best for 4k HDR.
I'm researching the Ultra Black Hd Monster Platinum 27Gbps and
Cable Wireworld Chroma 7.
I will use it on PS4 PRO on SAMSUNG TV UN55KS7500
could anyone help me to pass the cable to 4K HDR.
Sorry my Inglês . Im a Brazilian.
Andpodepah is offline
post #2 of 11 Old 04-09-2019, 05:49 PM
Otto Pylot's Avatar
Quoted: 3571 Post(s)
Liked: 2571
Monster cables, like AudioQuest are way overpriced and hyped for what you get. 27Gbps is an odd bandwidth. It should be 18Gbps for the HDMI 2.0b hardware specs (which can handle 4k HDR easily) or eventually 48Gbps for the newer HDMI 2.1 hardware specs (which are still being worked out).
Keep in mind that the cable is just a data pipe, there are other factors like the HDMI chipsets at the source and sink end, bend radius, cable distance, etc that play a big part in a successful cable run. Also, no cable mfr can guarantee that their cables will work 100% of the time for any given setup.
How long is your cable run? If it is under about 20' then a Premium High Speed HDMI cable (certified with a QR label of authenticity) should work just fine. Any cable mfr can submit their cables for certification so just look for the Premium High Speed HDMI cable name and the QR label.
Andpodepah likes this.
I never trust an atom, they make up everything.
Otto Pylot is offline
post #3 of 11 Old 04-09-2019, 06:25 PM - Thread Starter
Liked: 0
Got it. thank you for important information friend.
well, in this case in your opinion would you recommend me the Platinum Monster?
in the packaging of the monster there is no premium certificate QR but I already had a monoprice and it was good too.
post #4 of 11 Old 04-09-2019, 07:31 PM
Otto Pylot's Avatar
Liked: 2571
I wouldn't recommend Monster cables at all. How long is your cable run? The cable won't make pq any better. It's a digital signal. You either get it or you don't.
post #5 of 11 Old 04-09-2019, 07:36 PM - Thread Starter
Liked: 0
my monoprice cable lasted 2 years.
is that my friend has a monster cable and I found the image more progressive, more vibrant ... maybe it's my head thing
44/5000
but does the monster also work the correct HDR?
post #6 of 11 Old 04-09-2019, 08:05 PM
Otto Pylot's Avatar
Liked: 2571
44/5000
Again, the cable is just the data pipe. If you don't get sparkles, drop outs, etc then that's the best you can do. The cable can't make reds redder or greens greener. I'm not sure what you mean by the correct HDR. The HDMI chipsets at the source and sink are basically what determines what you can or can not get. The cable will just transmit the data if it can handle the bandwidth, which the current maximum bandwidth is 18Gbps. However, with 4k HDR, cable distance and installation is the key. How long is your cable run? I don't know what 44/5000 means.
post #7 of 11 Old 04-09-2019, 08:16 PM
TrendSetterX's Avatar
Quoted: 422 Post(s)
Liked: 316
44/5000
Há quanto tempo é o seu cabo HDMI e existe um receptor de áudio / vídeo entre a SAMSUNG e a PS4?
Theater: Sony 75x940E | Yamaha 3060 | DirecTv HR54 | ATV4K | MP 4K HDBaseT Extender | SVS PC2000 sub | 5.1 surround
Networking: ASUS RT-AC68U (wireless disabled) | Ubiquiti AmpliFi HD Mesh Wireless with wired back-hauls
Automation & Lighting: Control4 & Lutron Homeworks Interactive
TrendSetterX is online now
post #8 of 11 Old 04-09-2019, 08:29 PM - Thread Starter
Liked: 0
I understood better now. I typed this by mistake 44/5000 sorry
post #9 of 11 Old 04-09-2019, 08:30 PM - Thread Starter
Liked: 0
my cable is at most 3 meters, I'm going to use a 4k TV connected to Ps4 pro.
post #10 of 11 Old 04-09-2019, 09:16 PM
Otto Pylot's Avatar
Liked: 2571
At 3m (9') you can use a Premium High Speed HDMI cable from someone like Monoprice, BJC, or MediaBridge. A Premium High Speed HDMI cable is one that has been certified to meet the current HDMI 2.0b hardware specs. The cable can come from any mfr as long as it is labeled as a Premium High Speed HDMI cable and comes with a QR label for authenticity. A Premium cable is not a guarantee that it will work for everyone but it is as good as you can get because it has been tested and certified by the standardized testing program designed and implemented by HDMI.org. As long as your source (PS4) and sink (Samsung tv) have the same HDMI chipsets, and you have a clean cable installation (no sharp bends, extenders/adapters, or undo stress on the HDMI inputs) you should be fine. A 10' Premium High Speed HDMI cable is not that expensive, especially compared to a Monster cable.
post #11 of 11 Old 04-09-2019, 09:43 PM - Thread Starter
Liked: 0
I understood friend. Thank you very much for the explanations.
Reply Cable, Digital Cable - Non-HDTV
