surround vs rear speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-11-2019, 06:45 PM - Thread Starter
velocci's Avatar
Quoted: 668 Post(s)
Liked: 47
Hi all, when watching cable TV, which speakers are usually more active, the surrounds or the rears?
Family Room: Onkyo TX-NR 646 AVR, Polk Audio RtiA3 fronts, Polk Audio CSiA4 center, BIC America F12 sub, Polk Audio RC-65i rears
Basement: Denon AVR-X3400 AVR, Klipsch RP280f fronts, RP450c center, SVS PB-2000 sub, Polk Audio RC-85i rears & surrounds
Www.coolfacemasks.ca
velocci is online now
post #2 of 8 Old 04-11-2019, 07:06 PM
Steve Sleeve's Avatar
Quoted: 91 Post(s)
Liked: 34
Surrounds by a mile in every application from streaming to 7.2 blu ray. Currently working on an atmos upgrade but I suspect the same answer.
Denon AVR-X6500h Klipsch RP-8000f RP-440C (4) RP-150MS sides in parallel RB-51 rears, 4 JBL C67P pendants for atmos, 2 monolith 12" subs
Epson 5040UB, Sony Ubp-X700, AC infintiy T9, Nvidia Shield, 142" 2.35 silver ticket screen
Steve Sleeve is offline
post #3 of 8 Old 04-12-2019, 03:44 AM - Thread Starter
velocci's Avatar
Quoted: 668 Post(s)
Liked: 47
I have 5.1 audio in my family room with rear speakers. I'm going to plug them into the surround speaker terminals on the back of the AVR.
post #4 of 8 Old 04-12-2019, 08:55 AM
Otto Pylot's Avatar
Quoted: 4038 Post(s)
Liked: 2897
Most of the audio comes from the front sound stage (R/L/C). The sides and rear speakers are for atmospheric effects. With a well balanced system, you'll hear most of the audio coming at you but you'll be surrounded by other sounds meant to enhance what you see and hear in front of you. Atmos adds another level above you to basically enclose the listener in an audio bubble. As far as cable tv goes, it all depends on the source programming and how you have your receiver setup but the basics of surround sound are the same.
I never trust an atom, they make up everything.
Otto Pylot is offline
post #5 of 8 Old 06-06-2019, 10:38 AM
Quoted: 121 Post(s)
I have my speaker distances set properly and I dont really hear anything out of my rear speakers in 5.1 from xfinity
My receiver even says dolby dig on the main screen...
all the sound seems like its coming out the front
redrovermiami is offline
post #6 of 8 Old 06-06-2019, 11:01 AM
m0j0's Avatar
Quoted: 1457 Post(s)
Liked: 2350
What do you mean by you have 5.1 audio, do you mean you have 5 speakers only, but your AVR has both side surround and rear surround connections, meaning it supports a 7.1 setup, and you are trying to decide where to plug the back speakers? If that is the case, then you must connect them to the side surround and not the rear surround connections if you want to receive all data from a 5.1 encoded signal.
m0j0 is online now
post #7 of 8 Old 06-06-2019, 01:06 PM - Thread Starter
velocci's Avatar
Quoted: 668 Post(s)
Liked: 47
yes, exactly. that's what i'll do next time I have to go behind my AVR.
post #8 of 8 Old 06-07-2019, 08:41 PM
Otto Pylot's Avatar
Liked: 2897
Set properly by what? An autocal or by ear? I have Xfinity for local HDTV only and when the program presents 5.1, it's fine. It all depends, in part, on the source. 95% of the audio comes from the front sound stage. The sides (5.1) and back (7.1) are for atmosphere only. Sometimes you hear it and sometimes you don't, again depending on the source.
How do movies sound (streamed and BD)?
Have you checked your setup (proper wiring, settings, etc)?
Xfinity for anything other than local HDTV and internet service is basically Comcrap.
Reply Cable, Digital Cable - Non-HDTV
audio , cable , rear , surround , television
