FIOS Connection - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Otto Pylot
post #1 of 9 Old 01-15-2020, 02:22 AM - Thread Starter
Liked: 0
FIOS Connection
We're renovating our 2nd floor and while the walls are open I'm dropping 6 coax cables to the basement. The cables fall on the opposite side of the house from where Fios enters... about 50 ft. I plan on using a cable amplifier/splitter, and my question is... Should I used an adapter the extend the Fios input to the side of the house where the coax drops down, or should I extend each new coax approx 50 ft to reach the side of the house that Fios enters... or does it matter?
Tom
TomD906 is offline
post #2 of 9 Old 01-15-2020, 08:29 AM
Ratman's Avatar
Quoted: 2533 Post(s)
Liked: 2348
I'd suggest:
1) 6-way splitter in basement from the 2nd floor drops.
2) 50' coax from splitter to the FiOS entry.
3) Test.
If there is a problem. Then add a amp at the FiOS entry point.
Alternatively, you could always run 50' (+) x 6 coax feeds from the 2nd floor to a 6-way distribution amp at the FiOS entry point.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #3 of 9 Old 01-15-2020, 09:47 AM
Otto Pylot's Avatar
Quoted: 3743 Post(s)
Liked: 2690
Conduit as well?
BobWalters likes this.
I never trust an atom, they make up everything.
Otto Pylot is offline
post #4 of 9 Old 01-15-2020, 10:49 AM
Ratman's Avatar
Liked: 2348
Originally Posted by Otto Pylot View Post
Conduit as well?
Or... conduits? And pull strings in the conduits for future upgrades/needs?
And why not run some Cat6 or 7 just in case?
Just sayin'.
post #5 of 9 Old 01-15-2020, 10:52 AM
Otto Pylot's Avatar
Liked: 2690
Just sayin'.
Well, yeah
post #6 of 9 Old 01-15-2020, 11:07 AM
Ratman's Avatar
Liked: 2348
Do I get a "Amen" brothers and sisters?
post #7 of 9 Old 01-15-2020, 01:31 PM
Otto Pylot's Avatar
Liked: 2690
Originally Posted by ratman View Post
do i get a "amen" brothers and sisters? :d
amen!
post #8 of 9 Old 01-15-2020, 02:19 PM
Ratman's Avatar
Liked: 2348
Don't forget to put some tithes in the basket that's being passed.
post #9 of 9 Old 01-15-2020, 04:57 PM
Otto Pylot's Avatar
Liked: 2690
I did. Some extra conduit that I had laying around and a ball of string .
Reply Cable, Digital Cable - Non-HDTV
