picture quality - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Otto Pylot
post #1 of 10 Old 02-05-2020, 06:06 PM - Thread Starter
Liked: 0
picture quality
I recently purchased a sony 900 2019 model 65". I have Xfinity, but the issue is my picture and voice lag. why is it that there seems to be sound quicker then the person speaking while moving there lips and the quality of the picture is not as good as my 14yr old Panasonic plasma that's upstairs? Could it be my HDMI cable? I did a reset of the cable box.
Now when i stream from the tv apps directly through my separate router for Netflix and amazon etc. the picture is superb. What does this mean?
Andrew Stines is offline
post #2 of 10 Old 02-06-2020, 06:48 AM
Ratman's Avatar
Quoted: 2919 Post(s)
Liked: 2989
Are you connecting the cable box directly to the TV or running through an AVR? If yes, that may be the cause of the delay.
Are you sure the cable box's video output settings are correct?
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #3 of 10 Old 02-06-2020, 08:53 AM
Otto Pylot's Avatar
Quoted: 4038 Post(s)
Liked: 2897
+1. I have my Comcast STB connected directly to the tv because it's an older STB (1080 only) and doesn't play nice with Deep Color on my C8, so I had to assign a different HDMI input on the tv so could disable Deep Color for that input. We only use Comcast for local HDTV network broadcasts only, no streaming, and the pq is great for cable and there are zero issues with audio lag. I use an optical cable from the tv to the receiver for 5.1 audio and all is fine. My system is hardwired to a single router for internet and streaming via the ATV4k.
As far as a cable goes, all you need is a Premium High Speed HDMI cable (QR label) properly installed and you're good to go.
I never trust an atom, they make up everything.
Otto Pylot is online now
post #4 of 10 Old 02-08-2020, 04:37 PM - Thread Starter
Liked: 0
I use a hdmi from the ARC port for the soundbar
post #5 of 10 Old 02-08-2020, 04:38 PM - Thread Starter
Liked: 0
I have the xfinity box set to auto picture for what they broadcast in.
I am ordering some 2.2 hdmi cables active hardware. maybe that will work?
post #6 of 10 Old 02-08-2020, 04:52 PM
Otto Pylot's Avatar
Liked: 2897
I'm assuming that you mean HDMI cables that are made for the HDMI 2.1 option sets, not 2.2. There is no such thing as an HDMI 2.1 cable. Keep in mind that there are no HDMI cables that have been certified by HDMI.org yet for some or all of the HDMI 2.1 options sets. You also need to remember that HDMI 2.0 is standardized around 18Gbps so unless your cable run is longer than 25', certified Premium High Speed HDMI cables should be fine. An active cable really does nothing more than extend the cable length so that there are no errors in the data path.
post #7 of 10 Old 02-08-2020, 05:55 PM - Thread Starter
Liked: 0
post #8 of 10 Old 02-08-2020, 06:24 PM
Otto Pylot's Avatar
Liked: 2897
Connect the STB directly to the tv and then use an optical cable from the tv to the soundbar for audio. That's what I do and it works perfectly. However, I don't stream anything from Comcast. Only local HDTV broadcast stations only so the audio is in discrete 5.1 only when presented. That would certainly rule out the Comcast STB and your tv. If you need to use ARC it could be poor implementation of ARC by the soundbar.
Ratman likes this.
post #9 of 10 Old 02-08-2020, 07:02 PM - Thread Starter
Liked: 0
my soundbar has atmos. will the optical be able to pass atmos?
post #10 of 10 Old 02-08-2020, 07:27 PM
Otto Pylot's Avatar
Liked: 2897
No. And some ARC configurations can just pass lossy Atmos. eARC can pass lossless Atmos.
Reply Cable, Digital Cable - Non-HDTV
