FIOS - TV 'Channel Currently Unavailable' - Please Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-01-2020, 08:54 AM - Thread Starter
boltjames's Avatar
Quoted: 150 Post(s)
Liked: 66
I've had Verizon FIOS for 10 years and recently I've lost channels on 1 of the 4 TV's in the house. It's our primary TV in the living room. I've lost Channel 2 (CBS), Channel 11 (WPIX), YES, NFL Network and a few others. There doesn't seem to be a pattern. Other channels are working brilliantly, no problem at all, but the ones I've lost have stayed lost. On the other 3 DVR's I get all the channels I'm paying for, no issues whatsoever. I've done the following:
1. Followed the troubleshooter, checked all physical connections, did the re-authorization multiple times, didn't work.
2. Swapped DVR with one that's functioning properly in another room; the one that worked well in the other room suffered the same channel losses so I'm guessing its not a DVR issue.
3. Removed the 5-way coax splitter on the side of my house and replaced it with another Verizon OEM splitter.
4. There is a coax connector in the cable run, I replaced that too.
On the 1 DVR that is the problem, for channels that I don't get, all say Channel Unavailable except YES which comes in highly broken up with sound cutting in/out and the picture all striped and distorted.
In the middle of the COVID situation I don't want a tech in my house so I did all I could to troubleshoot and fix myself. Any idea what the problem may be? Any help would be greatly appreciated.
boltjames is offline
post #2 of 6 Old 05-01-2020, 08:59 AM
Ratman's Avatar
Quoted: 2770 Post(s)
Liked: 2779
Call FiOS support. They may be able to troubleshoot remotely without a dispatch.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 6 Old 05-01-2020, 11:12 PM - Thread Starter
boltjames's Avatar
Quoted: 150 Post(s)
Liked: 66
Tried that, didn’t work unfortunately.
post #4 of 6 Old 05-02-2020, 03:34 AM
Ratman's Avatar
Liked: 2779
Some reading and some suggestions here:
https://forums.verizon.com/t5/Fios-T...ot/td-p/808573
Ratman is offline
post #5 of 6 Old 05-02-2020, 02:29 PM - Thread Starter
boltjames's Avatar
Quoted: 150 Post(s)
Liked: 66
Some reading and some suggestions herehttps://forums.verizon.com/t5/Fios-T...ot/td-p/808573
Thanks for your help, Rat. Verizon came today and it turned out to be a chipmunk gnawed the coax in a spot under my deck that I couldn’t see. Ugh. All good now.
post #6 of 6 Old 05-02-2020, 03:46 PM
Ratman's Avatar
Liked: 2779
Just as described in the link I provided.
Happy to help. Glad it's resolved.
Ratman is offline
Reply Cable, Digital Cable - Non-HDTV
