AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Home A/V Distribution (https://www.avsforum.com/forum/36-home-v-distribution/)
-   -   VideoStorm is ghosting... (https://www.avsforum.com/forum/36-home-v-distribution/1418609-videostorm-ghosting.html)
slm95 07-03-2012 02:56 PM
I have a 4x4 component videostorm matrix (CMX44). My inputs are two cable boxes, a bluray player, and a ViewHD converter which is hooked up to an Apple Tv3.
The two cables boxes and bluray player work fantastic.
The Apple TV is hooked up with an HDMI cable to the ViewHD converter, which then connects with component to the fourth input on the VideoStorm matrix. When I select the ViewHD (Apple tv) it results in horrible ghosting. The ghosting only appears with this source and never with the other 3.
I isolate the problem down to the video storm, I plugged in the ATV3 directly into a TV with an HDMI cable and it worked perfectly. I then hooked up the ATV3 to the ViewHD converter, and plugged in the converter directly into my TV with component cables. It also worked perfectly, thus the issue is clearly the videostorm. Why is it causing ghosting with this source but not with my bluray or cable boxes?
I also tried plugging in the ViewHD into where I had the Bluray plugged in, and same result, ghosting...
If anyone has any ideas it would be greatly appreciated.
Thank you.
slm95 07-07-2012 08:20 AM
Bump...
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
