4K to projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 10-17-2017, 08:41 AM - Thread Starter
BladeZX's Avatar
Quoted: 49 Post(s)
Liked: 9
4K to projector
Since my Onkyo 636 will not do 4K with HDR, I am forced to get an HDMI switch to do this.
This way I can take the 4K signal directly to the projector but my question is how do I get the sound from the HDMI to the Onkyo now since the HDMI switch will only have one out on it.
BladeZX is offline
post #2 of 13 Old 10-17-2017, 10:44 AM
lizrussspike's Avatar
Quoted: 1264 Post(s)
Liked: 1889
BladeZX ,
What 4K projector and 4K player do you have?
That will help.
lizrussspike is offline
post #3 of 13 Old 10-17-2017, 10:51 AM - Thread Starter
BladeZX's Avatar
Quoted: 49 Post(s)
Liked: 9
Originally Posted by lizrussspike View Post
BladeZX ,
That will help.
Optoma UHD65
Looking to get video in 4K HDR from Xbox one S to projector using an HDMI switch but also get sound to my Onkyo 636 receiver
BladeZX is offline
post #4 of 13 Old 10-17-2017, 10:55 AM
Liked: 1889
What options do you have on the XBOX 1 S for outputs? Can you use an extra HDMI out of the XBOX 1 S and then bit stream into the Onkyo? Sorry I am not familiar with the XBOX 1 S.
post #5 of 13 Old 10-17-2017, 11:01 AM
Liked: 1889
Can you run your 4K HDMI to your projector, and the run optical into the XBOX 1 S.
What HDMI switch are you talking about? Do you currently have one in your system already?
post #6 of 13 Old 10-17-2017, 11:06 AM - Thread Starter
BladeZX's Avatar
Quoted: 49 Post(s)
Liked: 9
I do not have a switch yet - I am wanting to bring both the xbox one s (soon to be xbox one x) and ps4 pro to the projector but I also need to get the sound to the receiver
BladeZX is offline
post #7 of 13 Old 10-17-2017, 11:26 AM
Liked: 1889
Yea, not too sure about that HDMI 4K switch thing. I tried to use an non 4K receiver and did not have too much luck. I decided to get the Denon X4200, so that I can do audio and 4K from my 4K player to my 4K projector. Depending on your amount of speakers, you can get a decent 4K receiver cheaper than you think.
post #8 of 13 Old 10-17-2017, 11:49 AM
RonAlam's Avatar
Quoted: 123 Post(s)
Liked: 74
get a standalone 4k player
RonAlam is offline
post #9 of 13 Old 10-17-2017, 12:06 PM
Joe Fernand's Avatar
Quoted: 630 Post(s)
Liked: 345
HDFury Integral + Linker or New Vertex will do what you require - 2 x 4K UHD Inputs with 1 x Passthru to the Projector and the second Output down converted to work the AVR - cost is around $349.
Joe
Octava Inc. Multi-cast HD over LAN solutions.
RuiPro UK and EU Sales and Support
The Media Factory. Residential and Commercial systems.
Joe Fernand is offline
post #10 of 13 Old 10-17-2017, 12:32 PM
Liked: 1889
Thanks Joe Fernand for mentioning the HD FURY Integral. I was going to but am not an SME, so I could not speak intelligently about it. I was pretty sure that an 4K HDMI switch was not going to work with this.
BladeZX ,
For $349 you could get an Denon:
https://www.amazon.com/Denon-AVR-S72...ds=4K+receiver
This is a 4K 7.2 receiver. Just thought that I would show you another option.
post #11 of 13 Old 10-17-2017, 12:40 PM
Quoted: 630 Post(s)
Liked: 345
Keep in mind the options are Integral+Linker or the Vertex - the Integral will act as a Switch, Matrix or Distribution Amp with two 'equal' Outputs, if you then add the Linker it will down convert one Output to suit a legal AVR or Display.
The Vertex effectively combines the two units into a single chassis.
Joe
post #12 of 13 Old 10-17-2017, 01:02 PM
Tesla1856's Avatar
Quoted: 295 Post(s)
Liked: 106
Sounds like you just need a HDMI 2.0a (or better) 4K/HDR compatible Splitter right after the XBox.
Other "black boxes" might do something similar or split-off an acceptable audio tap. Kinda surprised the XBox-One doesn't have that already.
If what you need costs as much as Joe says, then upgrading AVR might be a wise choice. You will be all caught-up for these consoles and hopefully the next set.
You need a really-nice (high bandwidth) HDMI cable going to the projector, or all this is for nothing.
Epson 8350 3LCD Projector (96" @ 1080p) ~ Panasonic 850u 46" Plasma TV (1080p)
Onkyo TX-sr607 AVR ~ Cisco 8742hdc DVR (Spectrum) ~ Panasonic BD60 Blu-Ray Player
AppleTV-4 (iTunes,Plex,MA,Asphalt-8) ~ Simple Control HA ~ Alexa Echo Plus w/Hub
Harmony 670 Remote ~ HTPC (Kodi/Win10-64) Media-Server ~ Synology DS412+ 16tb Raid-5 NAS
Polk Audio Monitor Series-II CS-2 Center, 60 pair, three 40's / PSW-505 12-Inch Sub = 6.1
Tesla1856 is offline
post #13 of 13 Old 10-17-2017, 01:10 PM
Liked: 1889
^ +1 what Tesla1856 said. Depending on your cable length need, better make sure it is a good one. I had a blue rigger cable htat said 4K, great for 1080P, but not 4K.
Reply Home A/V Distribution
