Nuvo G Concerto, Essentia, MPS4, ... Integration, modernization and preservation - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 54Likes
post #31 of 397 Old 09-03-2018, 08:57 AM
broconne's Avatar
Quoted: 17 Post(s)
Originally Posted by Bobone View Post
Hi
Joe:
- Sorry to hear that it is tricky! I have no idea if this might help: https://github.com/openhab/openhab2-...ing.chromecast
All:
- how do I include my VB files? Using the code function #?
Bob
I think putting them in a code function may work (not sure how long they are?). Other option is to put them in github. You could create a public gist and just link to them?
https://gist.github.com/
A/B Pre-Build Thread
broconne is offline
post #32 of 397 Old 09-03-2018, 09:46 AM - Thread Starter
Quoted: 96 Post(s)
How to install HomeSeer - ChromeCast solution.
Hi,
Several people have requested the scripts for my Chromecast solution.
The solution works very well, but it is really a hack... Not something that is very dynamic and sometimes built for my specific needs.
If other users could comment on the instructions below, it will be very helpful.
Step 0: Chromecast Audio
- buy a Chromecast (35USD) and install it as source 1.
- You will love CCA with or without this solution.
Step 1: HomeSeer
- Install HomeSeer (any version) as free trial on any old PC. In May and November they give 50-60% discounts. https://homeseer.com/current-downloads/#HS3
- Install ChromeCast Plugin as free trial from the site https://shop.homeseer.com/collection...lug-in-for-hs3 or beta test: https://forums.homeseer.com/forum/me...n-beta-testing
Step 2: Serial Communication
- make sure you have a (USB) serial communication from PC to Nuvo serial port. Identifiy the PC port number.
Step 3: Install Scripts
Four key vb scripts (attached) to be placed in the /scripts folder.
- "Startup.vb" should replace the default script and calls InitMetadata.vb
- "InitMetadata.vb" opens a terminal port session and creates some Global Variables
- "PortCallback.vb" listens to the Nuvo traffic and reacts to it
- "SendMetadata.vb" sends metadata to the GC
Step 4: Adapt scripts
- MY CCA is connected as source 1 on the GC. You need to do this or edit the script.
- My serial device is defined as Port #5 . You need to edit this to your specific Port # in the scripts.
- My CCA belongs to a "Floor" called "Nuvo". Hence the reference to e.g device name "Artist": Artist = hs.DeviceStringByName("Nuvo Artist")
- you need to set up a Timer manually: "TitleTimer". (Third menu/page on the internal web site, I believe. It will also become a “device” as seen on the status page (first).
Step 5: Create a few events
- see screen shots in the pdf files
- They basically trigger on CCA changes and run SendMetadata.vb plus some other tweaks.
Step 6: Adapt a Nuvo source
- I have very slightly modified the display names on the Nuvo menus as can be seen on the screenshot from the Nuvo Configurator.
- I took an Airport Express source and changed the display names to: “REWIND, NEXT and MENUMODE”. The Nuvo protocol messaging does not change. It remains: PREV, NEXT and HPLAYPAUSE
Step 7: Create ZoneControl devices and events
- Create a "On/Off" (0/1) device called "ZoneEvents" (see screenshot)
- I have two different approaches to this. Will attach in a later post (This part is optional)
Step 8: (optional) Menumode
- commented out in callback.vb
Good luck!
My Dream likes this.
Bobone is offline
post #33 of 397 Old 09-03-2018, 10:00 AM
broconne's Avatar
Quoted: 17 Post(s)
Bobone, thanks for all the info. Do you know what firmware version your Nuvo GC is on?
broconne is offline
post #34 of 397 Old 09-03-2018, 11:29 AM - Thread Starter
Quoted: 96 Post(s)
Zone Control
HomeSeer makes it possible to either design simple Web based zone devices or use HSTouch to make smartphone front ends.
I have only tinkered around with the web devices that are seen on the "Home" page (PDF screen shots above).
(I hope Matt continues his development of a HSTouch control. It could be very nice)
Cloning the devices is an easy way to make several zone controls and events, as can be seen in the PDFs and using ZoneControl.vb (attached).
However, I found it annoying with so many nearly identical Events and also created the generic script GenZoneControl.vb.
It enables me to have only one event with several OR triggers (for zone changes) and GenZoneControl understands which zone changed.
(I guess it was a maintenance issue when developing that drove me down this lane...)
Lastly, dont forget the device "ZoneEvents" (suppose I should have used a global variable instead...) to avoid loops.
Bobone is offline
post #35 of 397 Old 09-03-2018, 11:53 AM - Thread Starter
Quoted: 96 Post(s)
Menus and menu items
Lastly, I created another variant of the menu with selectable menu items. (I called it multi-line in my video)
With it, you can make any depth that you wish and use UP/DOWN, NEXT/PREV to navigate.
It's a hack and the performance can certainly be improved (very touch sensitive) but it works.
- Rename it as "PortCallback.vb" to replace the standard script.
Enclosed are also two different webscraping techniques that I needed to populate my menus. (I am sure that this can be done better!)
- Klimat.vb will act strangely/crash as it take some of my local data
Bobone is offline
post #36 of 397 Old 09-04-2018, 05:40 AM
broconne's Avatar
Quoted: 17 Post(s)
Interestingly I still can't get my program to display track status on the Nuvo. I can get it to display the other 4 line, but it refuses to display track status. I have set the source type to apple airport.
Can you log and paste some of your output of what you send for track status?
I am on firmware 2.66q - not sure which firmware you are on?
Here is what my output looks like:
Code:
08:26:24.782 [Transmit] DEBUG org.nuvo.network.NetworkWriter - Sending Message: '*S5DISPInfo,1200,70,2'
broconne is offline
post #37 of 397 Old 09-04-2018, 07:50 AM
jmorris644's Avatar
Quoted: 42 Post(s)
Code:
The only difference that I see from what I have is that I use all caps. *S5DISPINFO. Also, make sure you have a cr/lf at the end.
Joe
A Proud Father >
Daughter's Music
jmorris644 is offline
post #38 of 397 Old 09-04-2018, 08:12 AM
broconne's Avatar
Quoted: 17 Post(s)
I started with all caps because that is what is in the protocol spec. I changed it to the mixed case based on Bobone's code (to see if it mattered). I am sending only a <CR> as that is why the protocol spec says (and it works for all other message types).
When you send this message to the Nuvo do you get a response back? And if so what is it?
I am wondering if I still have some setting wrong in my Nuvo that would make it ignore this particular message.
broconne is offline
post #39 of 397 Old 09-04-2018, 08:22 AM - Thread Starter
Quoted: 96 Post(s)
Code:
Strange!
Comments:
- my commands look like your's
- I mix lowercase/uppercase. No problem.
- the Chr(13) is important at the end, as Joe pointed out.
- "2" means "Play", "3" is Pause
- modified the Airport EXPRESS
- I have v2.66.(p)
What App are you testing with? Are you actually getting the new Duration or is that value blank? (it looks correct based on your Output)
- try to fill in a set number or trigger on a Duration change
- what happens when you press play/pause on the keypad?
Bob
Bobone is offline
post #40 of 397 Old 09-04-2018, 12:59 PM - Thread Starter
Quoted: 96 Post(s)
First, I have seen something similar before, i.e. that the displyline goes blank. Do not know how to replicate it though..
Here is what happens when I run an immediate script:
Code:
sep-04 21:49:32	 	Nuvo Receive	#OK
sep-04 21:49:30	 	Event	Running script statement immediately: &hs.SendToComPort(5, "*S1DISPInfo,” & 1200 & ”," & 70 & ",2" & Chr(13))
- a long shot: redo your quotation marks. I see some inconsistency above in the Unicode character used. Your machine may be more sensitive than mine.
Bobone is offline
post #41 of 397 Old 09-04-2018, 01:03 PM
jmorris644's Avatar
Quoted: 42 Post(s)
Code:
I think you may be right. The quoting is incorrect!!
A Proud Father >
Daughter's Music
post #42 of 397 Old 09-04-2018, 05:44 PM
broconne's Avatar
Quoted: 17 Post(s)
Bobone and jmorris.. I am not following. There are no quotation marks sent in the message to the Nuvo. Are you talking about the single quotes? That is simply how the logging library I am using has decided to notate string values.
Are you both transmitting messages wrapped in actual quotes or am I missing something?
broconne is offline
post #43 of 397 Old 09-05-2018, 12:03 AM - Thread Starter
Quoted: 96 Post(s)
Hi Bro...
You should be getting back ”#OK” from Nuvo following the command ”*S5DISPInfo,1200,70,2” + CR.
Do you? What does the display look like? Completely Blank or just unchanged symbols, timers and progress bar ? What do you get back with the command “*S5DispInfo?”
If you don’t get back “#OK” with the first command, then either the command or some Nuvo setup is wrong.
To check the command:
1) close the port in HomeSeer.
2) start RealTerm or similar and open the port to Nuvo with "57600,N,8,1"
3) test if you get a better response from the Nuvo with the command above. Test with some other commands as well, see what happens. Is it only the DispInfo command that doesn’t respond?
4) close down the port in RealTerm and reopen it in HomeSeer by running InitMetadata.vb
If it works, something on the HomeSeer side is wrong.
- Go through the command/string build-up? ("Execute immediate script command" is pretty handy).
If it doesn’t, something on the Nuvo side is wrong. Not sure what... Try a mix of the following, not necessarily in order.
- Alloff
- reboot
- unplug the MPS4
- reinstall the source (non-NuvoNet) (had to do this once)
- test another source driver
Good luck,
Bob
Bobone is offline
post #44 of 397 Old 09-05-2018, 07:19 AM
jautor's Avatar
Quoted: 1385 Post(s)
Liked: 896
Also make sure you terminate every NuVo command with a CR/LF pair. If I remember correctly, I had a lot of trouble with some commands that were sensitive to the pair receive (as opposed to just one of them), but I think it was inconsistent - some commands didn't care. But it's been a long time since I worked through that...
Jeff
NOTE: If you find dead photo / blocked Photobucket links in any of my posts, please PM me and I will fix them.
jautor is offline
post #45 of 397 Old 09-05-2018, 08:05 AM
jmorris644's Avatar
Quoted: 42 Post(s)
Jeff
I wholeheartedly agree.
Hey Jeff!!
A Proud Father >
Daughter's Music
post #46 of 397 Old 09-05-2018, 05:15 PM
jmorris644's Avatar
Quoted: 42 Post(s)
This is what my debug window says
*S4DISPLINE1,"Makana Radio"
*S4DISPLINE2,""
*S4DISPLINE3,""
*S4DISPLINE4,"Pua Tubarose"
*S4DISPINFO,2273,20,2
A Proud Father >
Daughter's Music
post #47 of 397 Old 09-05-2018, 05:42 PM
broconne's Avatar
Quoted: 17 Post(s)
*S4DISPLINE2,""
*S4DISPLINE3,""
Thanks for the tips. Commands look the same. I will try adding a CR/LF instead of just CR.
broconne is offline
post #48 of 397 Old 09-06-2018, 01:52 PM
jautor's Avatar
Liked: 896
FYI - The public Sonos API is available. Looks fairly straightfoward to do the metadata displays once you do some hoops to locate the correct unit/group/household. And yet another "must talk to the Cloud to talk to your own devices in your house" architectures that I hate... Integration that doesn't work if the Internet is down!
But the basics are there, and in HTTP/JSON so easy enough to talk to.
I may not have time this weekend to play with it, but will ASAP...
Jeff
jautor is offline
post #49 of 397 Old 09-06-2018, 04:20 PM
jmorris644's Avatar
Quoted: 42 Post(s)
Jeff
I just received the email too.
If what you say is true, and I am not doubting it, then I am disappointed that it is cloud based. Why?!?!?!?
edit: { Ok, I just looked through the api. Initially it will require use of the Sonos Cloud to control any devices. They do state that maybe at some time there will be a LAN version of the api. But in the meantime it looks like the cloud is the only way.
You are also correct in regards to the hoops to jump through in order to get access to a device. It looks fairly straight forward but possibly painful.}
Joe
A Proud Father >
Daughter's Music
post #50 of 397 Old 09-07-2018, 02:31 AM - Thread Starter
Quoted: 96 Post(s)
Sorry, I may know what is going on...
First, the correct response to your command is NOT "#OK" as I mentionned above, but "S5DISPINFO,DUR2250,POS70,STATUS2"
I noticed that If I send the command while a song is already playing, my infoline (DISPINFO) can go blank in some (unclear) cases
If I then press Pause on the panel, the correct data shows again as well as when I press Play. (Both activate PortCallback.vb code calling the Play/Pause Events and finally running SendMetadata.vb to update the display)
What may be happening is that the *DISPINFO command is sent with impossible data?
- Possibly because Duration is set to 0 or inconsistent “Duration” in some other way
This could happen if:
- Duration is 0 when the trigger launches the event. —> goes blank
(possibly when Duration < Position? ...have not tested)
- the CCA Title event triggers several times. This is an issue with the plug-in that I tried to moderate by checking if the “nuvotitle” global variable really changes.
-> Try modifying the Event "CCA Title" to trigger on Duration instead of Image or Title (changes). Not ideal for radio stations, but test with Spotify.
EDIT:
- After another test, I am back to thinking that there is/was also a unicode problem with the quotation marks. Replace them with your own machine's quotation marks so that they are read correctly.
- the following works: "hs.SendToComPort(5, "*S1DISPInfo," & 2250 & "," & 700 & ",2" & Chr(13)). --- No matter when I run it. (sent to the com port through a manual event running "Execute immediate script command")
But, if Duration is set to 0, I get a blank display....
Bob
Bobone is offline
post #51 of 397 Old 09-15-2018, 07:34 AM
broconne's Avatar
Quoted: 17 Post(s)
Quick follow up here now that I have been able to test. Sending a CR/LF doesn't fix the issue I am seeing with the Trackstatus not being updated. I still get no response from the Nuvo for that command only.
I am going to press on with the rest of my driver and circle back to this one.
broconne is offline
post #52 of 397 Old 09-15-2018, 07:37 AM
jmorris644's Avatar
Quoted: 42 Post(s)
very strange. Before moving on, the last thing to try that I can think of is to force the last 3 parameters to integers. A needle in the straw.
A Proud Father >
Daughter's Music
post #53 of 397 Old 10-02-2018, 03:00 PM
xs10shl's Avatar
Quoted: 59 Post(s)
Liked: 33
Since my MPS4 bricked, the NuvoNet port is now non-functional, which means I'll need to either find another bootable MPS4, or use an MV-MP (or an unobtainable NV-NNA) in order to access the API.
With respect to the NV-MP: if I get a used one without the software install disk, does anyone know if it will work simply as a pass-thru for NuvoNet? Or is there a software installation and registration required, in order to activate the box? My only interest here is to use it as a NuvoNet pass-thru - I'm not interested in any other functionality provided by the MP.
xs10shl is offline
post #54 of 397 Old 10-02-2018, 03:06 PM
jmorris644's Avatar
Quoted: 42 Post(s)
When you say "access the API", are you referring to the GC or Essentia API? IF so, you can access that API directly through the serial port on the GC or Essentia.
A Proud Father >
Daughter's Music
post #55 of 397 Old 10-02-2018, 05:46 PM
xs10shl's Avatar
Quoted: 59 Post(s)
Liked: 33
I don't know why I had it in my head that I couldn't use the API directly. Thx.
xs10shl is offline
post #56 of 397 Old 10-03-2018, 07:34 AM
jautor's Avatar
Liked: 896
As jmorris said, you can access most of the API from the serial port. There are some commands (MENU building, etc.) that only flow over NuVoNet and those you need the adapter to use.
Note that NV-MP and NV-NNA is the same hardware as far as we're concerned. I have one of each, and the only difference is the NNA (IIRC) has more source/peripheral identification LEDs on it, but otherwise they do the same thing. The other difference is that the NV-MP was sold along with the Autonomic MCS PC-based server software (which later became the MPS4).
So no, you don't need the software disc - it's the media server software that uses the NV-NNA/MP to access NuVoNet.
Jeff
jautor is offline
post #57 of 397 Old 10-17-2018, 01:52 PM
Liked: 0
Nuvo Essentia - update to system
Hello,
I have come across your thread and must say it has a lot of useful information.
I currently have a Nuvo Essentia system (from 2008) with using in 6 keypads (3 of which the led display is no longer lighting up). I have replaced some keypads over the years. I was thinking of either upgrading entire system to Sonos system or integrate with equipment I currently have. The sources I use most often 1) streaming thru apple tv to have capability to listen to spotify thru out the house, controlled thru iphone. 2) satellite (mostly for outdoor zone) when watching tv outdoors.
As I mentioned the keypads giving out one by one. I've replaced but wonder if there is another option on how to control zones (power/volume/source) thru app or other option rather than replacing keypads again & also modernize at the same time.
Any guidance is greatly appreciated. Thanks.
cocomia is offline
post #58 of 397 Old 10-19-2018, 08:25 AM - Thread Starter
Quoted: 96 Post(s)
Originally Posted by cocomia View Post
Hello,
Not sure that I am the best to answer this question compared to others, but my gut feeling is that you might want to continue buying Essentia keypads off Ebay. At least for a while.
There are two parts to this:
1) control zones (power/volume/source)
2) control source (select/pause/Next/previous/)
I personally like keypads for 1) but prefer smartphones for 2).
I am not sure that Sonos/Nuvo will ever have as good user interface as the content provider apps such as Spotify, etc...
On the other hand "two in one" is practical...
But then I don't think that Sonos has any wall mounted keypads?
Some would argue that you should upgrade to the new Nuvo gear. Probably the cleanest if you like keypads as well as apps.
Both Sonos and Nuvo are expensive!
You could get a little of both by:
- waiting for Joe's MG1 (coming soon?)
- or tweaking/hacking:the Chromecast/HomeSeer solution provides me with some of the source control on the keypads. I also get some volume control through the smartphone. I could configure a HomeSeer app for more zone control, but have not bothered to do so yet as my Nuvo App with MPS4 is still working.
So:
- if you like what you have: go for Ebay and possibly extend with the MG1 (coming soon.... ) -->Less expensive
- if you want to upgrade: go for Sonos or Nuvo if you like keypads: --> More expensive
Bobone is offline
post #59 of 397 Old 10-19-2018, 08:27 AM - Thread Starter
Quoted: 96 Post(s)
Originally Posted by nyankov View Post
I changed the 640 GB harddisk of my MSP4 Elite with a 1TB SSD through a low-level copy process a year ago. Plus increased the RAM from 1 GB to 2 GB. Kept the old disk with the system files and everything on it just in case. Everything works perfectly. It is a simple operation that any computer technician can perform in less than a couple of hours. I would actually highly recommend such an "upgrade", as the original Seagate HDD of the MSP4 is of a kind prone to degradation (not the most expensive model at the time either) and will certainly stop working with time.
Wow, this is exactly what I have been looking for!
Could you please give us a step by step recipe on how this is done?
Bob
Bobone is offline
post #60 of 397 Old 10-19-2018, 11:40 AM
Liked: 0
You could get a little of both by waiting for Joe's MG1 (coming soon?) or tweaking/hacking:
- Meanwhile, the Chromecast/HomeSeer solution provides me with some of the source control on the keypads. I could configure a HomeSeer app for zone control, but have not bothered to do so yet as my Nuvo App with MPS4 is still working.
So:
- if you like what you have: go for Ebay and possibly extend with the MG1 (coming soon.... ) -->Cheap
Hello,
Thanks for the prompt reply.
Great summary of the options.
Agree with you that upgrading to Nuvo player portfolio line or to Sonos is a expensive option.
Considering the only issue I'm having thus far is the keypads, otherwise everything is functioning.
What is the MG1 and it's purpose? What is homeseer? Are home audio installers familiar with this?
Do you also have the led keypads? How long are they lasting for you?
Again appreciate your prior detailed summary.
cocomia is offline
Reply Home A/V Distribution
essentia , grand concerto , mps4 , nuvo , nuvonet
