Bulk Cable Purchase - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 07-25-2018, 08:01 AM - Thread Starter
chadcj7's Avatar
Quoted: 75 Post(s)
Bulk Cable Purchase
I am planning the process out of running a lot of cabling fro my house that will soon break ground.
I have doen a search but I am coming up with nothing or stuff from several years ago.
Where is the best place to buy bulk speaker wire, bulk cat6 and bulk RG6 cabling? Looking for a good cable and good pricing. I am planning on non plenum for the cat6 cable but in wall rated. I am also looking at both 14/2 and 14/4 for speaker wire. Should I look at 12 gauge wire instead since some runs will be over 100 feet?
chadcj7 is offline
post #2 of 13 Old 07-25-2018, 08:12 AM
Quoted: 993 Post(s)
Liked: 540
Well at least for networking cat6, do you know how to terminate them with a plug? Check cablewholesale.com they have 1000 foot spools of Cat6 for between $100 and $200 and speaker cable starting at about $75 for 500 foot and RG6 starting around $50 for 1000 foot
liffie420 is offline
post #3 of 13 Old 07-25-2018, 10:12 AM - Thread Starter
chadcj7's Avatar
Quoted: 75 Post(s)
what do you mean by terminate with a plug? Do you mean in a patch panel or how to put the ends on them? If that is what you are referring to then my answer is, I have minimal experience but I have a buddy that does this for a living and he will be helping me with all the terminations
thanks for the website
chadcj7 is offline
post #4 of 13 Old 07-25-2018, 10:19 AM
Quoted: 993 Post(s)
Liked: 540
Yes I meant putting an end on them. Phone lines are easy you can get a little crimper that does it all for you. I know with Cat6 it is a little more involved. But thats all I was asking.
post #5 of 13 Old 07-25-2018, 10:43 AM
FlyOnTheWall's Avatar
Quoted: 144 Post(s)
Liked: 30
monoprice
especially if you are on the west coast
FlyOnTheWall is offline
post #6 of 13 Old 07-25-2018, 06:16 PM
Neurorad's Avatar
Quoted: 279 Post(s)
Liked: 155
I bought most of my cable from Monoprice, no significant issues yet. Although, some of the 4-conductor speaker cable was oddly colored. One conductor was blue, IIRC.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #7 of 13 Old 07-26-2018, 04:42 AM
Skytrooper's Avatar
Quoted: 395 Post(s)
Liked: 387
I’m a fan of Belden. Reasonably priced and great quality.
TV - LG 65B7P OLED / Receiver - Yamaha RX-A1040 7.2 / Blu Ray - Oppo BDP-83 / Turntable - Technics SL-3300
Game - Playstation 3 / Cable Box - Comcast X1 V4 4K / L&R Paradigm Studio 20 V3
Center - Paradigm CC-470 V3 / 4 Surrounds - Paradigm SA-15 V3 In Walls
Subwoofer 1 - Sunfire HRS-12 / Subwoofer 2 - Paradigm PW-2100
Skytrooper is offline
post #8 of 13 Old 07-26-2018, 04:48 AM - Thread Starter
chadcj7's Avatar
Quoted: 75 Post(s)
I have ordered form Monoprice before. I love their HDMI cables. While looking at their site for network and speaker cable it doesn't appear they have that big of a selection. Maybe I just need to look harder. The only thing I don't like about Monoprice is the shipping cost to KY are not the best
Where is a good place to buy Belden at?
chadcj7 is offline
post #9 of 13 Old 07-26-2018, 09:27 AM
Skytrooper's Avatar
Quoted: 395 Post(s)
Liked: 387
Try Amazon. I took a peek and the price went up a lot since I bought it 6 years ago.
post #10 of 13 Old 07-28-2018, 12:27 AM
MrBobb's Avatar
Quoted: 229 Post(s)
Liked: 107
Another vote for Monoprice, didn't know their shipping could be expensive but then I live in Cal. No option for UPS ground? usually the cheapest ship.
Only thing is, their coax, banana keystone termination are kinda cheap, recommend getting those somewhere else. If you have a local contractor place like GrayBar better.
Monoprice site is funky, their search engine often times don't return the stuff you are looking for but u start browsing, and they do have the stuff.
I suggest people, specially newbie don't CRIMP RJ45, it can be frustrating trying to shove 8 tinny wires in there. Pre-made CAT patch cables are cheap enough. In-walls, u want to PUNCH those anyways. Sometimes u don't even have to punch, I think I may have seen some tool-less RJ45 jacks in Monoprice, not sure, but Pros have been punching since forever if u want it tried&true.
Running my own wires was the most fun part of the project renovating my house. Hope the next owner appreciate it.
MrBobb is offline
post #11 of 13 Old 07-28-2018, 06:41 PM
Neurorad's Avatar
Quoted: 279 Post(s)
Liked: 155
When people ask me about my hobbies, I usually include retrofitting cables in my house. Yeah, I'm a hit at parties.
Neurorad is offline
post #12 of 13 Old 07-29-2018, 11:51 AM
Skytrooper's Avatar
Quoted: 395 Post(s)
Liked: 387
I think 14 ga speaker wire is good enough. 12 can be a little hard to deal with connecting to your speakers. If your looking to install cameras, it may be a good idea to get cat cable that is solid copper. Will handle POE (Power over Ethernet) current better. I believe Monoprice sells Pure Bare Copper Cat cable. I hope that isn't a marketing trick. Its usually called solid copper.
post #13 of 13 Old 04-18-2019, 08:21 AM - Thread Starter
chadcj7's Avatar
Quoted: 75 Post(s)
This thread is a little old but I wanted to bring it back to life as I am going to be purchasing bulk cat 6 cable and mist likely 14gauge speaker cable in bulk for the new home we are building very soon.
I feel like prices have gone up a little but what should I be looking for on both cables and where is the best and cheapest place to purchase from?
chadcj7 is offline
Reply Home A/V Distribution
