Can I run a single Virgin Tivo over Cat5e to multiple TVs? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By xs10shl
post #1 of 6 Old 10-22-2018, 12:35 PM - Thread Starter
Liked: 0
I have just refurbished my home, and put Cat5e cabling into 5 rooms where I may have a TV. Each run terminates with a faceplate downstairs next to where I have just had a Virgin Tivo box installed. I want to be able to operate my Tivo on each TV, and my idea is to connect the Tivo to a 'box' which allows the single connection to run to the multiple Cat5e faceplates in each room.
I am a real novice in this, as you can probably see, so please, no sarcastic remarks from the experts on here. I would just appreciate some help.
Does what I have done make sense?
What equipment do I need to make it happen?
If I don't have remote control access to the Tivo box downstairs, will I be able to change channel upstairs?
Many thanks.
LVYO30 is offline
post #2 of 6 Old 10-22-2018, 07:57 PM
FlyOnTheWall's Avatar
Quoted: 144 Post(s)
Liked: 30
Many thanks.
5 may be tricky, as most kits come with 4 or 8. Do some research on HDBaseT. Here is just a basic example of the 8 piece kit to you can see how this tech works.
https://www.monoprice.com/product?p_id=10683
You can buy a remote of each room, but you are probably better off using a Tivo app on your phone or Tablet that works over IP
FlyOnTheWall is online now
post #3 of 6 Old 10-25-2018, 08:14 PM
Quoted: 14 Post(s)
Liked: 2
Also, keep in mind that all 5 TVs would always have to be on the same channel at the same time with just one Tivo box. Is that okay with you?
Budget AV & IT Solutions
Audio/Video, Wi-Fi, Security, & More
Serving Eastern Pennsylvania
flyoffacliff is offline
post #4 of 6 Old 10-26-2018, 09:30 AM
xs10shl's Avatar
Quoted: 59 Post(s)
Liked: 33
I installed a Roamio in the media closet and several TiVo minis over cat6 at the TVs, which uses similar wiring to what you are doing. It is truly the “poor mans” distributed media network. On the plus side it’s allowed each family member to grab an available tuner to watch whatever they want simultaneously, at the cost of $199 per TV. On the minus side, it’s proven to be low on reliability - even with the new Hydra software, we generally have to reboot the mini about once a week.
NickTheGreat likes this.
xs10shl is offline
post #5 of 6 Old 10-26-2018, 10:28 AM
NickTheGreat's Avatar
Quoted: 514 Post(s)
Liked: 388
What model of Tivo do you have?
The official solution would be to lease or buy Tivo Mini's. They've gone up in price, but for $200 (each) you could plop one at the TV, wire to the Cat5 you've already got, and be in business. Then you could watch different channels and all your recorded stuff independently.
The different models of TiVo's have different numbers of tuners, so you may not be able to watch live TV on all 5 TV's at once. Or at least not 5 different channels.
NickTheGreat is offline
post #6 of 6 Old 10-26-2018, 12:37 PM
holl_ands's Avatar
Quoted: 927 Post(s)
Liked: 502
CAT5/6 ALTERNATIVE:
All you need is a One-To-SIX Port HDMI SPLITTER....and five pairs of the fol. CAT-5/6 HDMI EXTENDER Systems. Orei is limited to 1080p, so only the local UDTV would support "4K" playback via direct HDMI Cable Connection:
https://www.amazon.com/164-Feet-Exte.../dp/B01GYH8DOM [up to 1080p, typ. $50 per TX/RX Pair]
Fol. support [email protected] for a few more $$$'s...where the higher cost units drive longer distances:
https://www.amazon.com/UltraHD-Exten.../dp/B07B3Y5RMX
https://www.amazon.com/gofanco-HDMI-.../dp/B06X3S94YT
https://www.amazon.com/UltraHD-Exten.../dp/B07B5VD7GG
Multi-Port RF SPLITTERS that support up to [email protected]:
https://www.amazon.com/gofanco-Proph.../dp/B07F2QGHDN [8-Port, $130]
https://www.amazon.com/SIIG-HDMI-60H.../dp/B07DXGLQZ2 [8-Port, $140]
WIRELESS ALTERNATIVE:
If you don't mind being restricted to 1080p at the remote locations [and "4K" to Local UDTV only], you can do it all via fol. One-To-Many HDMI WIRELESS Extender System....you will need one Transmitter and Multiple Receivers [$200 for first TX/RX plus $45/RX].....and a 2-Port HDMI Splitter to drive both Local HDTV/UDTV and Wireless Extender Transmitter:
https://www.amazon.com/dp/B07B4NRKLG/ref=psdc_3236443011_t3_B00LSS10PM
If you want [or plan] to send [email protected] [60Hz not yet supported] to one or more Remote Locations, then you could use an HDMI Splitter and fol. TX/RX HDMI WIRELESS Extender System, which supports up to THREE RX from ONE TX:
https://www.amazon.com/J-Tech-Digita.../dp/B076BTC811 [up to $400 for each TX/RX plus $200/RX]
To drive all five remote rooms, you would need either another J-Tech or OREI Wireless Remote Systems (check with User Manual or call mfr to see what is needed to configure more than one System per Home)....or a mixed system employing one or more of the above CAT5/6 HDMI Extender Systems.
Note that all of the above systems include an IR Repeater capability so that an IR Blaster at the Transmitter Location repeats R/C Codes detected at each remote location....
ADDENDUM: Also see my earlier link re Multi-Drop Wireless HDMI Extenders:
https://www.digitalhome.ca/forum/203...ml#post3064489
Actiontec Q+A section indicates that it supports up to FOUR Receivers off of ONE Transmitter:
https://www.amazon.com/dp/B00LSS10PM...rum-convert-20
holl_ands is offline
Reply Home A/V Distribution
