Audio streaming via wifi to two receivers from android tablet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-15-2019, 01:21 PM - Thread Starter
w0bbler's Avatar
Hi All, Looking for some advice on a budget solution for streaming pandora from an android tablet to two receivers via wifi. Did some searching on other threads and couldn't really find a good solution.
I have Pandora on an android tablet and two rather old receivers (no HDMI) and a really good wifi zone that is in range of both receivers. Is there a solution that will allow me to have the audio output from the android tablet transmitted via wifi to both receivers at the same time? I would also be fine connecting the tablet to a central location (like a media hub) via BT or wifi if that helps.
w0bbler is offline
post #2 of 3 Old 04-16-2019, 05:26 PM
ahard's Avatar
Quoted: 116 Post(s)
Liked: 50
Step 1: Buy this: https://www.amazon.com/J-Tech-Digita...f_=nav_signin&
Step 2: Buy this: https://www.walmart.com/ip/Google-Ch...-NEW/435188866
Step 3: Connect this https://www.walmart.com/ip/Google-Ch...-NEW/435188866 to this https://www.amazon.com/J-Tech-Digita...f_=nav_signin&
Step 4: Connect a left and right cable to the back of this https://www.amazon.com/J-Tech-Digita...f_=nav_signin& and connect the other end of the two wires to your receiver.
Step 5: Download the Google Home app from the Play Store on your tablet.
Step 6: Open the Google Home app and select the option to setup the device you bought in Step 2.
Step 7: Open the Pandora app.
Step 8: Look for the cast icon, select it and select your speaker.
Step 9: Enjoy your music.
XBL: Stunt1on1
ahard is offline
post #3 of 3 Old 04-16-2019, 05:58 PM - Thread Starter
w0bbler's Avatar
Hot damn, thanks ahard that is fantastic and exactly what I was looking for.
Thank you so much.
w0bbler is offline
Reply Home A/V Distribution
