HDMI switch with two outputs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-12-2019, 08:58 AM - Thread Starter
ks_man's Avatar
I'm looking for an HDMI switch that has two outputs so that I can send video to an hdmi extender (and then back to the tv) and the other to my a/v receiver. My receiver is HDMI 1.3a and I'm looking to update my TV to 4k/HDR/etc. I'd rather not upgrade my receiver as the audio performance is very good and it would be a pain to change in my rack. It seems I can get a cheaper receiver with pre-outs but that would still be pretty bulky and require some effort getting things installed in my rack.
I'm assuming a matrix switch would operate a little differently then what I'm looking for which is essentially passing the same signal to two different devices like a splitter. If that isn't possible then is there something else that could accomplish what I want in a smaller form factor than a full receiver? I found these two devices but one only has one hdmi input and the other doesn't have 7.1 outputs (I only need 5.1).
https://www.essenceelectrostatic.com...1-channel-dac/
https://www.essenceelectrostatic.com...t/hdacc-ii-4k/
ks_man is offline
post #2 of 8 Old 06-12-2019, 12:48 PM
FlyingDiver's Avatar
Quoted: 230 Post(s)
Liked: 65
If you're actually looking for a 1-input, 2-output HDMI splitter, this will work: https://www.monoprice.com/product?p_id=15651
FlyingDiver is online now
post #3 of 8 Old 06-12-2019, 02:42 PM - Thread Starter
ks_man's Avatar
Thanks but I would probably need four inputs with two outputs.
ks_man is offline
post #4 of 8 Old 06-12-2019, 02:48 PM - Thread Starter
ks_man's Avatar
Am I thinking about this wrong? Would a basic matrix switch work with both outputs set to the same input? Thanks!
ks_man is offline
post #5 of 8 Old 06-12-2019, 03:00 PM
Quoted: 230 Post(s)
Liked: 65
That was not at all clear from your initial post. How about this one? https://www.monoprice.com/product?p_id=15376
post #6 of 8 Old 06-12-2019, 03:02 PM
Quoted: 230 Post(s)
Liked: 65
Probably. The problem you're going to have is that the switch is probably going to try to force both outputs to the same resolution.
post #7 of 8 Old 06-12-2019, 03:30 PM - Thread Starter
ks_man's Avatar
Was just starting to see that regarding the resolution. So the switch that you linked, if I output one to the tv (through an extender) and one to the receiver (hdmi 1.3a) would the tv only get 1080p? Thanks!
--Edited--
Assuming the above is correct and a matrix switch won't work, do you think I would have handshake issues if I did a switch like you first linked to a device like this and then from this device to an extender to my tv?
ks_man is offline
post #8 of 8 Old 06-12-2019, 05:23 PM
Quoted: 230 Post(s)
Liked: 65
That's more likely to work. You can get a 4-to-1 switch from the same source, I think. Then run the output to something that will extract the audio without messing with the video. Then to your extender. That's a lot of pieces to the puzzle, though.
Reply Home A/V Distribution
