What is a good speaker wire termination for in-ceilings? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-20-2019, 02:29 PM - Thread Starter
Magnus_CA's Avatar
Quoted: 26 Post(s)
Cool What is a good speaker wire termination for in-ceilings?
Hi,
I plan to install a mix of Golden Ear and Triad in-wall and in-ceiling speakers in my home. The terminals are the spring loaded type so I don't think bananas or spades will work. What is everyone using to terminate their copper into IW and IC speakers these days? Bare wire? Or should I put something to resist oxidation?
Thanks in advance for the replies!
Magnus_CA is offline
post #2 of 5 Old 06-20-2019, 07:29 PM
Bigus's Avatar
Quoted: 587 Post(s)
Liked: 540
I usually tin the ends if I'm going to leave it a bare wire mechanical connection.
Bigus is offline
post #3 of 5 Old 06-24-2019, 06:20 PM
ifor's Avatar
Quoted: 94 Post(s)
Liked: 82
Bare wire
AV Professional for 23 Years
ifor is offline
post #4 of 5 Old 06-25-2019, 06:56 AM
smoothtlk's Avatar
Quoted: 274 Post(s)
Liked: 84
No reason you can't put a shot of anti-oxidant on the wire ends. Install the largest AWG wire that the connector supports.
smoothtlk is offline
post #5 of 5 Old 06-28-2019, 10:51 AM
Neurorad's Avatar
Quoted: 279 Post(s)
Liked: 155
Originally Posted by ifor View Post
Bare wire
+1
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Reply Home A/V Distribution
