Home Network Setup - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By DanPackMan
post #1 of 5 Old 07-13-2019, 07:53 PM - Thread Starter
MonoPestoso's Avatar
Home Network Setup
Hello,
I am looking to upgrade the networking in my house so I can hardwire most things and then add Ubiquiti AP for anything wireless.
The question I have is if this will work.
I am looking to get the following items for a network rack setup:
TP-LINK 8-Port Gigabit Ethernet Poe+ Unmanaged Energy-Efficient Switch with 124W 8-Poe+ Ports | Plug and Play | Metal | Desktop/Rackmount | Lifetime (TL-SG1008PE)
TP-LINK TL-SG1024D 24-Port Gigabit Rackmountable Switch
3 X Ubiquiti UniFi AP AC PRO 802.11ac Scalable Enterprise Wi-Fi Access Point (UAP-AC-PRO-E-US)
I am new to this networking thing so I am wondering if I can connect the standard 24 port switch to anything hardwired in the house and then run a cable from that switch to the 8 port POE switch to run the AP AC PROs?
Would this cause any issues powering the APs?
Any help would be greatly appreciated
MonoPestoso is offline
post #2 of 5 Old 07-13-2019, 07:59 PM
Liked: 0
Why not a 48 port switch? Or...do you need all 21 of the other ports on the 24?
Sent from my Pixel 2 XL using Tapatalk
Raffi Shahinian is offline
post #3 of 5 Old 07-13-2019, 08:10 PM - Thread Starter
The only reason would be to save a little money and making it a little easier on a newbie.
It looks like the 48 port TPLink switch is a smart one. I am not sure it this makes a huge difference instead of just using 2 unmanaged switches (one standard and a second PoE)
post #4 of 5 Old 07-13-2019, 09:16 PM
DanPackMan's Avatar
Quoted: 488 Post(s)
Liked: 1240
From what you describe it should work fine. Once cable from your router to a port on the first switch, one cable between that switch and the POE switch. The POE switch will power the APs only, it won't care what else is connected to the first switch.
Raffi Shahinian likes this.
DanPackMan is online now
post #5 of 5 Old 07-13-2019, 11:46 PM - Thread Starter
Thanks that helps!
Reply Home A/V Distribution
