HDMI over TCP/IP? Any devices with low latency? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By sbarnesvta
post #1 of 3 Old 07-16-2019, 06:33 AM - Thread Starter
sofakng's Avatar
Quoted: 118 Post(s)
Are there any devices (1080p or 4K) that can encode an HDMI audio/stream stream and send it over a network as TCP/IP? I'd like to decode it on my PC for viewing.
I think the type of device I'm looking for is an "IPTV encoder" and there seems to be several available but I'm not sure on the latency.
VideoStorm also makes a NetPlay device but I've heard it's fair high latency so it won't work for video games.
sofakng is offline
post #2 of 3 Old 07-18-2019, 09:50 PM
sbarnesvta's Avatar
Quoted: 27 Post(s)
The best I have seen is Crestron's Video Over IP solution called NVX, is it 4K 4:4:4 60fps, latency is in the 30ms range.
Most others I have used are in the 60-90ms range depending on the network configurations which IMO is unusable for gaming.
If I am spacing out a system, I would recommend HDBaseT if it is an option or leaving the gaming PC/Console local in the room it is used.
ezlotogura likes this.
SBTS-Inc.com
- Certified Crestron Master Programmer and DM T-4K, D-4K, E-4K, DM-NVX Certifications.
- RTI Programmer/ Driver Developer
- Rational Acoustics Smaart Certified
- QSC QSYS Lvl 2 Certified Programmer
sbarnesvta is offline
post #3 of 3 Old 07-31-2019, 01:29 PM
videostorm's Avatar
For gaming, if you are using Xbox you can already directly stream this to Windows PCs (microsoft free app).
Video Storm LLC
videostorm is offline
Reply Home A/V Distribution
