Best Cat6 wire to run in house/walls for internet? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-24-2019, 02:43 PM - Thread Starter
todd1010's Avatar
Quoted: 119 Post(s)
Liked: 29
I'm wanting to run some wire to several rooms in the house and I've got some great access to all of them. I just need help figuring out what kind of cable (Cat6) to use.
Its confusing to see all of the types.
I've seen, Plenum, Riser, Stranded, Solid, etc.
Confusing!
Receiver : Pioneer Elite SC-LX701
Main & Center Speakers : Phase Technology PC 3.5, & Surrounds
Amplifiers : Emotiva UPA-1 Monoblocks, SVS SB3000 Subwoofer
MonsterPower HTS5100, Harmony Elite Remote
TV & Sources: Sony 75” 900F, Bluesound Node 2, Xbox One & Apple TV4K
todd1010 is offline
post #2 of 8 Old 07-24-2019, 07:15 PM
ifor's Avatar
Quoted: 106 Post(s)
Liked: 83
Riser Cat6.
Should be solid, not stranded.
AV Professional for 23 Years
ifor is offline
post #3 of 8 Old 07-24-2019, 07:22 PM
FlyOnTheWall's Avatar
Quoted: 162 Post(s)
Liked: 38
Confusing!
For the average home owner, just buy a box of this and be done with it. Comes in every color imaginable. https://www.monoprice.com/product?p_id=8103
FlyOnTheWall is offline
post #4 of 8 Old 07-24-2019, 07:26 PM
Quoted: 459 Post(s)
Liked: 381
If you are going the CAT6 route make sure all the hardware (wall plates, ports, etc) is also rated for CAT6.
Install into low-voltage flexible conduit if at all possible. It will save headaches in the future.
Current system:
Sony 75X900e/Sony STR-DN-1080, CS-3/CS-8/CS5
Sony X800 4K blu-ray player/Dish Hopper3
Roku 4 Premier/Sony PS-4
Cheddarhead is offline
post #5 of 8 Old 07-24-2019, 07:29 PM
Quoted: 162 Post(s)
Liked: 38
and get those EZ Cat 6 ends... will save you money in and time in the long run
post #6 of 8 Old 07-24-2019, 08:01 PM
smoothtlk's Avatar
Quoted: 305 Post(s)
Liked: 95
You install EMPTY conduit (with a pull string). The Cat6 for new construction doesn't have to be on conduit. The conduit is for FUTURE wiring. Conduit is near worthless if you put wire into it from day 1.
smoothtlk is offline
post #7 of 8 Old 07-24-2019, 08:14 PM
Quoted: 162 Post(s)
Liked: 38
this.
and only this.
post #8 of 8 Old 07-24-2019, 08:16 PM
Quoted: 459 Post(s)
Liked: 381
You aren't wrong but you can install your Cat6 in conduit from day one and leave the pull string for later use. We do it all the time for office installations. They always decide to add more connections to each work area.
Current system:
Reply Home A/V Distribution
