Port Forwarding on Russound MCA-88X - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-09-2019, 04:55 AM - Thread Starter
aragno's Avatar
Does anyone know if it’s possible to use port forwarding in order to access a Russound device from outside the LAN?
The MCA-88X is using a static IP address.
An Amplifi router is being used in the LAN.
-Trey
Pioneer Elite SC-07Oppo BDP-93 (Region free mod)Sony KD-55X9005AKlipsch RFII Surround SpeakersHSU ULS-15 Subwoofer
aragno is offline
post #2 of 4 Old 08-09-2019, 12:51 PM
smoothtlk's Avatar
Quoted: 305 Post(s)
Liked: 95
Hi Trey,
Yes, you should be able to port forward.
There are two IP addresses - one for the amp, the other for the internal streaming device.
Are you just trying to control the matrix? Or also pick a streaming song?
smoothtlk is offline
post #3 of 4 Old 12-03-2019, 01:43 PM - Thread Starter
aragno's Avatar
I want to control the device while I am out of the house.
I am unable to determine where the port numbers are for the device and for the streamer.
Have any idea how to find the ports they are using?
aragno is offline
post #4 of 4 Old 12-03-2019, 03:08 PM
smoothtlk's Avatar
Quoted: 305 Post(s)
Liked: 95
From recollection, the Russound is on port 9621. The streamer has it's own IP address.
Reply Home A/V Distribution
