HDMI switch for 2out, 1in - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-11-2019, 04:37 AM - Thread Starter
Quoted: 64 Post(s)
Looking for something simple that I can’t seem to find. I want to play my Playstation 4 Pro with the option between two different 4k TVs. Was looking for a 1in, 2out switch with an IR remote to switch between the output. The output of the one TV I choose to use should be [email protected]
Seems like all the switches have 1out and multiple inputs.
dseg is offline
post #2 of 9 Old 08-11-2019, 07:33 AM
FlyingDiver's Avatar
Quoted: 244 Post(s)
Liked: 71
Switches are multi-in, one-out. You want a splitter.
https://www.monoprice.com/product?p_id=10249
FlyingDiver is offline
post #3 of 9 Old 08-11-2019, 08:01 AM - Thread Starter
Quoted: 64 Post(s)
Seems like splitter allow multiple outputs at the same time which reduces the output ability, ei. [email protected] to [email protected] x2
I just need one output but have the option of two different ones with the full ability of [email protected]
dseg is offline
post #4 of 9 Old 08-11-2019, 09:04 AM
Quoted: 244 Post(s)
Liked: 71
No it doesn't. That would be the case if your video card was trying to drive multiple displays, but it's not true for an HDMI splitter.
No one makes what you want because there's no need for it.
post #5 of 9 Old 08-12-2019, 10:29 AM
NickTheGreat's Avatar
Quoted: 527 Post(s)
Liked: 403
Would an HDMI matrix not do what you're looking for? As far as not reducing quality?
NickTheGreat is offline
post #6 of 9 Old 08-12-2019, 10:31 AM
Quoted: 244 Post(s)
Liked: 71
In this context there's no difference between a matrix and a splitter. They both duplicate the incoming signals to all outputs.
post #7 of 9 Old 08-12-2019, 11:23 AM
FlyOnTheWall's Avatar
Quoted: 163 Post(s)
Liked: 38
matrix would be overkill in your situtation, but would still work fine.
FlyOnTheWall is offline
post #8 of 9 Old 08-15-2019, 04:24 PM
AV_Integrated's Avatar
Quoted: 1684 Post(s)
Liked: 1215
If you have a 4K60 signal and want to use HDR, then you need to ensure that whatever splitter you are using is 18Gb/s capable. Most splitters are older and only are 10Gb/s rated. So, make sure it is HDMI 2.0 w/18Gb/s capability.
If both displays support 4K60, then you will be fine. If they don't support the same resolution, then you need to ensure only one display is on at any time.
Be VERY aware, that 18Gb/s HDMI splitters have a significant cost bump over cheaper 1x2 standard HDMI splitters that don't support full 4K60 and don't support HDCP 2.2 and won't pass the resolution you are working with!
https://www.amazon.com/Comprehensive...gateway&sr=8-3
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #9 of 9 Old 08-17-2019, 05:38 AM
Joe Fernand's Avatar
Quoted: 638 Post(s)
Liked: 347
No matter if you use a Distribution Amp (Splitter) or Matrix the key feature in the DA or Matrix will be supporting the maximum capability of your Display devices - second you have to know if the two display devices have equal or different capabilities, if the Displays have differing capabilities that may sway your decision between a DA or a Matrix.
As AV_Integrated says where you have differing capability Display devices connected via a DA you may find all is well as long as you ensure one Display is powered off - that is not always the way though as some DA"s will still read the EDID (Capabilities) of the device which is in Standby.
Joe
Octava Inc. Multi-cast HD over LAN solutions.
RuiPro UK and EU Sales and Support
The Media Factory. Residential and Commercial systems.
Joe Fernand is offline
Reply Home A/V Distribution
