Minnesota Energy Code in ceiling speakers backboxx? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-26-2019, 08:44 AM - Thread Starter
jjohnston7's Avatar
Quoted: 63 Post(s)
I am looking to build a house, and I hear new energy codes in MN require a speaker back box to maintain the moisture barrier etc. I am looking at the below, but it looks thing and I want to make sure it won't resonate or make my speakers sound weird. their FAQ says they recommend the magnet touch the back of the box, which My fear is that would cause some buzzing or vibration, but they say it doesn't...
I just wanted to get all of your take on it too, and see if there are other products that are similar or better. I like this because its more universal, since I don't know if I am doing 5.25", 6.5", or 8" speakers.
https://www.backboxx.com/backboxx-tm-application
jjohnston7 is offline
post #2 of 5 Old 08-26-2019, 07:31 PM
FlyOnTheWall's Avatar
Quoted: 162 Post(s)
Liked: 38
you could always use spray glue and glue some soft felt to the inside of the box that touches the magnet
FlyOnTheWall is offline
post #3 of 5 Old 08-26-2019, 08:51 PM
ifor's Avatar
Quoted: 106 Post(s)
Liked: 83
ifor is offline
post #4 of 5 Old 08-27-2019, 11:05 AM
AV_Integrated's Avatar
Quoted: 1677 Post(s)
Liked: 1213
Or, you just wait until you move in a put in the speaker and call it a day. You can also buy any number of speakers which are plenum rated and come with a back box built into the speaker itself.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #5 of 5 Old 08-31-2019, 09:33 AM
Neurorad's Avatar
Quoted: 283 Post(s)
Liked: 159
I used this for the attic, against fiberglass insulation
https://www.homedepot.com/p/Tenmat-R...130E/204286308
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Reply Home A/V Distribution
