Multiple sub woofer amp wiring - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-22-2019, 02:15 AM - Thread Starter
Liked: 0
I am getting ready to wire up 5 sub woofer amps (Bheringer NX6000D and 4-NX3000D's) to the 2 sub outputs on my Onkyo RZ-3100. Can I simply use multiple "y connectors" when converting from RCA to the XLR style, or do I need to worry about signal degradation as it is split up. If so, is there a solution, such as a signal amplifier? Manic Mike
Manic Mike is offline
post #2 of 2 Old 10-22-2019, 03:10 PM
AV_Integrated's Avatar
Quoted: 1663 Post(s)
Liked: 1205
Best practice would be to use a unbalanced to balanced audio distribution amplifier.
But, you can do it with just some Y-cables and the right connections for the amps.
The amps want a balanced signal, but can accept a unbalanced signal as long as the wiring is correct.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Reply Home A/V Distribution
