Reusing old speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-04-2019, 09:01 PM - Thread Starter
Liked: 0
Hello everyone! Im new to this forum and looking for some help! I moved into a house that had originally been fitted with a NUVO system. The original owner took out all of the nuvo receivers/ amplifiers and the face plates on the walls at some point. What im working with now is a bunch of zones with ceiling speakers, and a central hub where all of those wires terminate. What I would like to do is find some way to use all of the in ceiling speakers that are in the house. I would like to use them to stream music from pandora, amazon, etc. and control each zone over wifi from my phone. My AV guy wants to do a full sonos setup. There are 11+ zones with 22 speakers total (I believe there are also some outdoor speakers, but not sure on that. Do I have any options besides sonos to accomplish what im trying to accomplish?
Thanks in advance for any help!
jspoljor is offline
post #2 of 2 Old 11-05-2019, 09:38 AM
AV_Integrated's Avatar
Quoted: 1663 Post(s)
Liked: 1205
Do you want independent volume control in all of the rooms?
Do you want in-room control of that volume, or do you want to have to pull out your phone to adjust volume in every single room?
What wiring is at the wall plate location in each room? Is it cat-5e or similar network wiring?
There are tons of distributed audio systems available. A often recommended system is from Home Theater Direct...
https://www.htd.com/Products/Whole-House-Audio
Just as an example. 12 zones with full control, keypads, and phone control runs a bit over $4,000...
https://www.htd.com/Lync-12v3-Set?cu..._keypadcolor=1
You can dumb down systems quite a bit, but this would be kind of typical for a quality distributed audio system. You want amplifiers for all 11 zones, which typically means getting two, 12-channel amplifiers.
But, you can get those on eBay as well.
https://www.ebay.com/sch/i.html?_fro...nnel+amplifier
At under $300 each, a couple would cost you under $600. So, that gets power to the speakers.
Then you need a controller. Going back to HTD, you can pick up their 12-zone controller, by itself, for $1,400...
https://www.htd.com/Lync12_4
and their smart gateway (I believe this is required)...
https://www.htd.com/GW-SL1 ($100)
So, about half the price point, and you get all the rooms under iPhone/Android control. You can add individual keypads to the system later on if you want to.
This will give you volume control and source selection, but you will still need to add sources. I do like Sonos as an option. But, you could get by with just one or two Sonos players and call it a done deal.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Reply Home A/V Distribution
