HDMI Switch For 4K60 HDR 4:4:4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 11-05-2019, 10:11 PM - Thread Starter
wrathloki's Avatar
Quoted: 746 Post(s)
Liked: 355
I’m looking for a HDMI switch (4-5 inputs) that can handle 4k60 HDR hopefully up to 4:4:4. I’ve been looking at some but a lot of reviews state that the actual performance doesn’t actually measure up to the performance advertised. I’m hoping folks here will know which ones are actually good and worth buying.
Living Room
Samsung 65JS8500
Onkyo NR-737
Onkyo SKF-4800 Fronts w/ HTP-980 Surrounds & Center and Klipsch R-12SW
Bedroom
Samsung 55JS8500 w/ Yamaha YAS-105 Soundbar
wrathloki is offline
post #2 of 15 Old 11-06-2019, 05:22 PM
ifor's Avatar
Quoted: 108 Post(s)
Liked: 84
AV Pro Edge
https://www.avproedge.com/ac-mx82-auhd.html
AV Professional for 23 Years
ifor is offline
post #3 of 15 Old 11-06-2019, 06:11 PM - Thread Starter
wrathloki's Avatar
Quoted: 746 Post(s)
Liked: 355
Originally Posted by ifor View Post
How much do those run? The fact that I have to request a quote makes me think it’s expensive.
Living Room
Samsung 65JS8500
Onkyo NR-737
Bedroom
post #4 of 15 Old 11-06-2019, 09:43 PM
smoothtlk's Avatar
Quoted: 305 Post(s)
Liked: 95
https://www.avprostore.com/18Gbps-Tr...-mx82-auhd.htm
Yes, all AVPro hardware is expensive. But it works. Quality, Performance and longevity.
smoothtlk is offline
post #5 of 15 Old 11-06-2019, 09:47 PM - Thread Starter
wrathloki's Avatar
Quoted: 746 Post(s)
Liked: 355
Yikes. I couldn’t even justify spending that much on a good receiver which will do the HDMI switching and give me great sound on top of it. I’m looking for something much, much cheaper, like around $100 or less.
Living Room
Samsung 65JS8500
Onkyo NR-737
Bedroom
post #6 of 15 Old 11-07-2019, 06:32 PM
FlyOnTheWall's Avatar
Quoted: 163 Post(s)
Liked: 38
check out monoprice and amazon.
but YMMV
FlyOnTheWall is offline
post #7 of 15 Old 11-07-2019, 06:43 PM - Thread Starter
wrathloki's Avatar
Quoted: 746 Post(s)
Liked: 355
but YMMV
At Monoprice even the highest spec switches have lots of reviews of people stating that they don’t do the full bandwidth signal like they should. On amazon if you search for HDMI it’s basically the Wild West with tons of sure to be garbage Chinese stuff. That’s why I came here to see if anyone would have any good suggestions.
Living Room
Samsung 65JS8500
Onkyo NR-737
Bedroom
post #8 of 15 Old 11-07-2019, 06:46 PM
Quoted: 163 Post(s)
Liked: 38
well. there was one above urs, but u didnt want to pay the price.
at only 100 bucks, good luck.
not sure why u don't just buy an AV receiver? Why do you need just a switch?
I had bought this one for a a client, but wasnt great.... https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
u def get what you pay for.
post #9 of 15 Old 11-07-2019, 06:50 PM - Thread Starter
wrathloki's Avatar
Quoted: 746 Post(s)
Liked: 355
Well yeah the price was crazy high, of course I wouldn’t want to pay that. As for the reason I don’t want a receiver, this is for a bedroom TV and space is an issue, not to mention I don’t want to spend quite so much as a receiver will cost. It’s just strange that there’s a lack of affordable HDMI switches out there. I mean take a $400 receiver and strip away all the functionality but the HDMI switching and it really doesn’t seem all that crazy that that could cost ~$100. Maybe I’m just SOL and there are no good, affordable options.
Living Room
Samsung 65JS8500
Onkyo NR-737
Bedroom
post #10 of 15 Old 11-07-2019, 06:51 PM
Quoted: 163 Post(s)
Liked: 38
u can try that amazon link above, and see if it works well for you. if its only for 1 TV, no need for the matrix, so im sure it will work fine for you acting just a switch
post #11 of 15 Old 11-07-2019, 07:02 PM - Thread Starter
wrathloki's Avatar
Quoted: 746 Post(s)
Liked: 355
I’ll check that one out, thanks.
Living Room
Samsung 65JS8500
Onkyo NR-737
Bedroom
post #12 of 15 Old 11-08-2019, 02:36 PM
Liked: 8
When I worked for a residential A/V company a few years ago we had good success with Key Digital products. My friend that worked there with me still uses his 2x1 HDR switch he got two years ago daily with AppleTV 4K/Roku Ultra and has had zero problems with it.
https://keydigital.org/category/18
cemetery55 is offline
post #13 of 15 Old 11-11-2019, 03:57 PM
AV_Integrated's Avatar
Quoted: 1678 Post(s)
Liked: 1214
Key Digital stuff isn't Amazon cheap either. More like the first link likely was.
I would just hit up Amazon or Monoprice and try it out. Keep in mind that the cabling for 4K is a huge issue and that you need to keep the runs as short as possible. If you use 4K 18Gb/s rated cabling in and out, try to keep the runs under 6 feet if possible.
Longer runs really hurt the chance of 4K working, and most issues with 4K are not going to be due to the switcher, but because the cable simply can't handle the bandwidth necessary.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #14 of 15 Old 11-23-2019, 11:26 PM
jeffm13's Avatar
I've been there, and done that. At least 4 or 5 times. The cheap ones--I think I've purchased every brand available on Amazon in the last five years--may or may not work out of the box. But they won't last. Within six months to a year, my bet is you'll start seeing HDMI handshake problems. Streaming video that just stops playing. Or simply an inability to see any output from your sources. And that's for 1080p.
4:4:4 is an entirely different story. You'll need to do your own research, but I decided to go with AVPro Edge. I haven't run 4k or HDR through the setup yet (projector is still only able to do 1080p), but I expect to upgrade real soon now. I'm running a 40-ft cat6 between the transmitter and receiver. I'll upgrade that cable to Cat-8 when I do my upgrade.
I haven't had a single hiccup from the AVPro Edge in the couple months I've had it installed. So I'm keeping my fingers crossed.
Good luck. And as most have said: YMMV.
Jeff
jeffm13 is offline
post #15 of 15 Old 12-13-2019, 09:40 AM
jefbak's Avatar
I use a kinivo 4k60hz switch and I am able to watch DV/Atmos content from my AppleTV4k at full 4K60hz. The switch is also compatible with Harmony Remote which is a plus.
The problem is that devices like Apple TV and cable boxes don't work that will with CEC and auto-switching and that can mean handshake problems that require unplugging and plugging back in all hdmi. These switches are capable just not super reliable which can be a headache.
TCL 55R625
Vizio SB36514-g6
Dolby Vision/Atmos over ARC
jefbak is offline
Reply Home A/V Distribution
