Needing better quality sound for home theater turned klounge - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-16-2019, 08:50 PM - Thread Starter
bgmille's Avatar
Hello, if I could pick your brain for a minute.
Here is my layout of my current home karaoke setup. Looking for something to replace my receiver to allow for a better sound. I have overkill acoustic treatments in the space but have to crank it and the sounds degrades the more I increase. Have to run mixer levels it 60% gains and receiver at 70% to avoid hissing or feedback. But otherwise sounds decent. Thinking my receiver just doesn't cut it and need more power to the speakers. Would also be nice to be able to control pitch on certain Mics as well. If $$$ were no object...what would you do?
Name:	Annotation 2019-12-16 211953.jpg
bgmille is offline
post #2 of 2 Old 12-17-2019, 01:05 PM
Joe Fernand's Avatar
Quoted: 638 Post(s)
Liked: 346
How loud is loud in your space? You can use an App on a mobile phone to get a decent indication of how loud you are typically listening at your current listening position.
Room - you don't say how large or how the system is laid out.
If power is the issue your AVR has Pre Outs so simple enough to add one or more external power amps and relieve the AVR of some of the stress of driving eight loudspeakers.
AVR's don't control 'pitch' on a Mic - you require a different desk or some form of processor to undertake that trick.
Joe
Octava Inc. Multi-cast HD over LAN solutions.
RuiPro UK and EU Sales and Support
The Media Factory. Residential and Commercial systems.
Joe Fernand is offline
Reply Home A/V Distribution
