Speaker Wire Banana Plugs on Both Sides of Wall outlet. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-17-2019, 11:59 AM - Thread Starter
Liked: 0
Hopefully this is the right forum for this question. First time poster here.
I have installed keystone speaker wall plates for my home theatre. I found that I can not install banana plugs on both sides without them running into each other. Is there an alternative? Either shorter banana plugs or? I can't use a spade on the inside due to clearance problems. If I can use banana plugs on both ends of the speaker wire it would allow me much more choice of pre finished cables. Not a huge deal but more for curiosity's sake.
MorcoVelo is offline
post #2 of 3 Old 12-17-2019, 12:01 PM
eljaycanuck's Avatar
Quoted: 1994 Post(s)
Liked: 2832
Banana plugs are primarily for ease of un/plugging. I don't see the point of using them on the in-wall side of a plate. (I didn't on mine.) YMMV.
eljaycanuck is offline
post #3 of 3 Old 12-17-2019, 12:46 PM - Thread Starter
Liked: 0
Definitely trying to avoid bare wire and pins wouldn't be my first choice. Could go to a solder type rear, regular binding post front. Wanted to see if there were other options.
Reply Home A/V Distribution
