Nuvo P100 goes solid red .. everytime - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: level of expertise
User / installer 0 0%
Nuvo Technical support 0 0%
Voters: 0. You may not vote on this poll
post #1 of 2 Old 01-11-2020, 08:57 PM - Thread Starter
Liked: 0
ok So i have a Nuvo P100,
I have tried to get it connected to the group on the network with "NO" success.
SO .. here is what I have tried
Ethernet connected directly into my NUvo P100.
restart, wait . goes slow blinking white to slow blinking green , then solid RED..
Ethernet connected , restarted . press up= Down button to reset the unit.
starts white ( press the up=down Button) immidiatly goes to slow green .. then goes solid red
Ethernet connected , downloaded the TLVupdate from Legrand on usb drive .
with unit off , inserted USb , turned on and let it attempt to manually upgrade.
starts up white , then few blinks goes Green .. ( USB is flashing active) stays slow blink green then goes solid RED.
I have tried these several times each as well.
The odd thing is the unit will not grab an IP , I have been monitoring the IPs and it has full activity. I have reset two other P100 with the ethernet connection so I know it works.
any idea how to log into this unit at a more granular level to fix this.
any suggestions would be greatly appreciated.
I believe it may be really old firmware but cant say with no eyes inside the unit.
Thank you in advance for any assistance.
JJ
Jerry Jerry is offline
post #2 of 2 Old 01-12-2020, 08:29 AM
brantmacga's Avatar
Quoted: 26 Post(s)
Try a different Ethernet cable. If that doesn’t work, try a different switch port. This has worked for me in the past for this same issue.
Are you trying to (unsuccessfully) connect to the network while doing the tlv update? If so this is prob why you see a solid red at the end of the update.
brantmacga is offline
Reply Home A/V Distribution
legrand nuvo , nuvo red light error
