HDMI ARC cabling - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-01-2020, 02:04 PM - Thread Starter
47okie's Avatar
HDMI ARC cabling
I'm not having any luck getting sound from my LG B9 television to my Yamaha AVR with the LG set to HDMI-ARC.
The devices are connected using HMDI cables at each end, but likely because of conduit limitations, the installer utilized Cat5e cable in the middle with Binary 1CAT Extender components (320 series) in the middle.
I'd like to know if the Binary/Cat5e cable and Extenders are the problem because they are not ARC compatible. I've looked on-line at the Extender specs but did not see any reference to ARC capabilities.
Thanks for any insights you might have.
47okie is offline
post #2 of 4 Old 02-01-2020, 02:26 PM
Otto Pylot's Avatar
Quoted: 3778 Post(s)
Liked: 2698
The most reliable connection is a single cable run, source to sink, with no wall plates, adapters, extenders in-between. The CAT-rated cable used should have been solid core CAT-6 (non-CCA and not CAT-6 pre-terminated ethernet patch cable). Anytime you introduce a "break" in the cable chain you can introduce errors. ARC is susceptible to distance so you need to ensure that your cabling is a simple as possible and that the cable can handle ARC.
The AVR also needs to be setup for ARC and you need to make sure that you are using the ARC-defined HDMI input/output.
I never trust an atom, they make up everything.
Otto Pylot is online now
post #3 of 4 Old 02-07-2020, 02:48 AM
Joe Fernand's Avatar
Quoted: 641 Post(s)
Liked: 347
Unless the Extender states it is ARC capable I would assume it is not - there are ARC enabled Extenders available if you have to stick with an 'over CAT' solution.
Joe
Octava Inc. Multi-cast HD over LAN solutions.
RuiPro UK and EU Sales and Support
The Media Factory. Residential and Commercial systems.
Joe Fernand is online now
post #4 of 4 Old 02-13-2020, 07:11 PM
bluewaves's Avatar
Quoted: 33 Post(s)
Liked: 34
Most HDMI Baluns are not ARC compatible, they need to explicitly say they are and even then you may have issues.
bluewaves is online now
Reply Home A/V Distribution
