Ubiquiti Cameras - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By giomania
  • 1 Post By FlyOnTheWall
post #1 of 15 Old 02-25-2020, 04:54 PM - Thread Starter
horsegoer's Avatar
Quoted: 29 Post(s)
Ubiquiti Cameras
So in process of designing smart home for house we are buying. I do like the Ubiquiti cameras but they are a tad expensive. Anything else a slightly less expensive that performs well? Thanks.
Seems like Swann or Reolink might be good alternatives.
beau
horsegoer is offline
post #2 of 15 Old 02-26-2020, 07:52 AM
smoothtlk's Avatar
Quoted: 338 Post(s)
Liked: 107
Did you decide on an automation controller yet?
That is the first decision.
Cameras comes later if you want things to be compatible.
Automation control system then NVR, then camera, then wiring, then installation. In that order.
smoothtlk is offline
post #3 of 15 Old 02-26-2020, 02:35 PM
giomania's Avatar
Quoted: 828 Post(s)
Liked: 629
Dahua International models
Do yourself a favor and visit the “AVS Forum” for IP cameras:
www.ipcamtalk.com
Sent from my iPhone using Tapatalk Pro
NickTheGreat likes this.
Lumagen Radiance Pro HDR Tone Mapping Guide: Click Here
Lumagen Radiance Pro Setup & Calibration Tips: Click Here
UHD-BD Backup & Playback Guidance Link
giomania is offline
post #4 of 15 Old 02-26-2020, 04:24 PM
FlyOnTheWall's Avatar
Quoted: 175 Post(s)
Liked: 41
www.ipcamtalk.com
yes. this and only this.
Ubiquiti cameras are not worth the price.
giomania likes this.
FlyOnTheWall is online now
post #5 of 15 Old 02-26-2020, 10:25 PM
coug7669's Avatar
Quoted: 78 Post(s)
Liked: 47
Swann cameras are locked down to their brand only.
coug7669 is offline
post #6 of 15 Old 02-27-2020, 06:29 PM - Thread Starter
horsegoer's Avatar
Quoted: 29 Post(s)
smooth thanks. going to use either Alexa or Google home hub..if that's what you mean by controller.
post #7 of 15 Old 02-27-2020, 06:30 PM - Thread Starter
horsegoer's Avatar
Quoted: 29 Post(s)
thanks gio
post #8 of 15 Old 02-28-2020, 04:58 AM
smoothtlk's Avatar
Quoted: 338 Post(s)
Liked: 107
I would say that's more of a user interface than a true automation controller. Borderline.
But it will get you started. Don't be surprised that you later want to upgrade to a true automation controller.
The problem with that is you would have purchased the expensive stuff (rest of devices) that go with one ecosystem and no other ecosystem is completely compatible. Which then means you will be removing, throwing away, ebaying hardware and redoing stuff.
post #9 of 15 Old 02-28-2020, 08:22 PM
Bigus's Avatar
Quoted: 713 Post(s)
Liked: 625
I third the recommendation for Dahua cameras and the ipcamtalk forum.
In this instance, I don't agree with camera choice being subservient to NVR and automation controller or hub. Cameras have a very specific purpose and many cameras are simply junk for that purpose. If you can't see well enough to identify someone in broad daylight, much less twilight, much less dark, then you might as well stick a fake camera up there for the deterrent effect and save yourself a whole heck of a lot of money on the rest of the system. Megapixels are near meaningless.
Start with what the proper locations are at your property for cameras. Then figure out the proper camera for the task at that location (ability to ID a face, motion detection, 24hr backup recording, license plate ID, night performance with or without lights etc.). Then look at your cameras and automation controller and see what options there are for NVR that can bridge that gap, if desired. Not that unusual for someone to have a reasonably capable automation system that their security cameras aren't a part of.
One recommendation would be to check out Blue Iris as a software based NVR system. Will handle most any camera and can interface with lots of automation systems, so a pretty good and inexpensive tool to bridge that gap.
Bigus is online now
post #10 of 15 Old 02-29-2020, 02:21 AM - Thread Starter
horsegoer's Avatar
Quoted: 29 Post(s)
thanks all. Dahua seems to get reviews. Hikevision does as well.
post #11 of 15 Old 02-29-2020, 07:42 AM
smoothtlk's Avatar
Quoted: 338 Post(s)
Liked: 107
The assumption to that recommendation was if one wanted the system to be integrated.
If you don't care about that, then you don't need to plan it as a system.
But what happens very consistently as non-informed users buy stuff and then get more and more interested and get tired of all the seperate "apps" and want to integrate. Then, invariably find that no automation controller integrates with everything so likely some do dad (like a camera, like an NVR) ends up having to be swapped with something that does integrate.
This story is happening more and more as people are now becoming aware of "home automation" having been introduced by Google, HomeDepot, Samsung, Amazon and are then dissatisfied with evolving it beyond the basics.
Our "job" is to help bridge those gaps. It starts with good planning up front to minimize misdirection and rework.
Then certainly you need a system that is up to the task that won't break the bank.
BlueIris is a great tool to help integrate disparate cameras and automation systems. We use it often. Wish there was a Linux build. And also wish that someone would write some neat 360 stitching capability for it (while I was on the wish tangent ).
post #12 of 15 Old 02-29-2020, 08:47 AM
Bigus's Avatar
Quoted: 713 Post(s)
Liked: 625
No arguments there. If there were a lot of great camera options it would make that easier. But there aren't. Just a couple of brands that do the job well, and dozens that are junk. Unfortunately a lot of what you find in packaged systems is junk.
Yeah, Linux BI would be nice. Not really any good Linux based software VMS unless you want to pony up the $$$$$ for commercial grade.
Bigus is online now
post #13 of 15 Old 02-29-2020, 03:21 PM - Thread Starter
horsegoer's Avatar
Quoted: 29 Post(s)
Thanks. Are there any good controllers out there that are less expensive than Control4? Thanks
beau
post #14 of 15 Old 03-02-2020, 08:53 AM
NickTheGreat's Avatar
Quoted: 536 Post(s)
Liked: 414
There's gobs of controllers cheaper than C4. Like, most of them.
I'm running Homeseer on a Windows machine. I like it, but it really depends on what you need and what you feel comfortable with.
I'll second (or third) the recommendation for IPCAmtalk.com. It's a great forum. I have another Windows machine running Blue Iris with about 6 or 8 cameras now. It's a work in progress, but I'm very pleased with it.
NickTheGreat is offline
post #15 of 15 Old 03-02-2020, 09:16 AM
MinHeadroom's Avatar
Quoted: 168 Post(s)
Liked: 294
While Ubiquiti networking products are a great ecosystem, I’ve read quite a few gripes about their IP cams, especially given their added overhead cost.
I use a usg, have 5 AP’s, and two managed (overkill) switches, but I rely on a Blue Iris windows box for my 16 cameras and I love it.
MinHeadroom is offline
Reply Home A/V Distribution
