Running Fiber - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-29-2020, 03:23 PM - Thread Starter
horsegoer's Avatar
Quoted: 31 Post(s)
Running Fiber
When I prewire my home I will be running (3) cat 6 and a coax to each tv. Would it smart to run a fiber to future proof? If so how many strand fiber? Thanks.
beau
horsegoer is offline
post #2 of 7 Old 02-29-2020, 09:03 PM
ifor's Avatar
Quoted: 108 Post(s)
Liked: 84
Generally, Simplex Riser Multi-Mode is most common for interiors.
You're choice if you want to run duplex or not.
AV Professional for 23 Years
ifor is online now
post #3 of 7 Old 03-01-2020, 09:19 AM
Otto Pylot's Avatar
Quoted: 3958 Post(s)
Liked: 2847
The ONLY way to future proof is to run your cabling in a conduit so that any upgrades/repairs that need to be made can be done easier and safer. This is especially true for a/v (HDMI). 1.5" - 2.0" conduit should work for multiple cables. Video technology always outpaces connection technology so upgrading your cabling is practically guaranteed in the future.
As far as CAT-6 goes, I would run solid copper core CAT-6 (non-CCA and not pre-terminated CAT-6 ethernet patch cable). Just give yourself a nice service loop in the j-box to work with. With solid core you can extend an ethernet connection by terminating with punch down keystone jacks or extend and HDMI connection by terminating with HDBT.
If you are thinking on running fiber for a/v (HDMI), then the recommendation would be hybrid fiber (which is glass fiber wiring surrounded by solid copper wiring). As with any HDMI cable run, distance can work against you regardless of cable type (copper of hybrid fiber) so you may have to be creative. HDMI cabling can not be daisy chained so plan accordingly, and the most reliable HDMI connection is source to sink, with no wall plates, adapters, extenders, etc in-between.
For running HDMI cable the recommendation is Premium High Speed HDMI cable which is certified (for HDMI 2.0) by HDMI.org and comes with a QR label of authenticity. However, they are passive cables (HDMI.org does not allow for certification of active cables) and can only be certified up to 25'.
I never trust an atom, they make up everything.
Otto Pylot is online now
post #4 of 7 Old 03-01-2020, 05:54 PM - Thread Starter
horsegoer's Avatar
Quoted: 31 Post(s)
thanks. yes so maybe I'll pre wire "free air" then run conduits with pullstrings for pull cables later if need be.
post #5 of 7 Old 03-02-2020, 06:38 AM
Bigus's Avatar
Quoted: 713 Post(s)
Liked: 625
That would be my suggestion. Empty conduits that get from wall locations into accessible attic/basement/crawl spaces, and from those spaces to your centralized structured wiring location. Conduits don't have to be continuous from every wall location to the structured wiring location, just span wall or ceiling locations where access later is more difficult. Easier to pull cable piecemeal through a couple of segments of conduit if needed than one long continuous conduit run with multiple 90 deg bends.
Bigus is offline
post #6 of 7 Old 04-16-2020, 06:31 PM - Thread Starter
horsegoer's Avatar
Quoted: 31 Post(s)
Guys can one run flexible metal conduit and not EMT?
beau
post #7 of 7 Old 04-17-2020, 12:50 PM
Otto Pylot's Avatar
Liked: 2847
I've always run non-metal flexible conduit with a smooth interior, not ribbed.
Reply Home A/V Distribution
