Good Matrix Switch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-08-2020, 06:40 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 2
Good Matrix Switch
Anyone know of a good matrix switch that has some sort of API or web UI exposed? I've been looking for whole house amp systems and thought I may as well just build my own with some amp boards and a matrix switch.
speakerz is offline
post #2 of 7 Old 03-08-2020, 08:08 PM
smoothtlk's Avatar
Quoted: 359 Post(s)
Liked: 115
Most all good matrix switches support integration with a control system.
smoothtlk is offline
post #3 of 7 Old 03-09-2020, 06:17 AM
ezlotogura's Avatar
Quoted: 274 Post(s)
Liked: 119
Video Storm has a 16x16 Audio Matrix with a Web UI. I use it with Control4, but you can probably write your own control for it as they have published codes
http://www.video-storm.com/manuals/CMX%20rs232.pdf - RS232
http://www.video-storm.com/manuals/CMX_hex_codes.txt - HEX codes
https://www.video-storm.com/proddeta...prod=CMX1616A2 - product page
ezlotogura is offline
post #4 of 7 Old 03-09-2020, 11:01 AM - Thread Starter
Quoted: 17 Post(s)
Liked: 2
Thanks, does it work well for you? I see there are some on ebay for $150 which is a good price for me.
speakerz is offline
post #5 of 7 Old 03-09-2020, 12:22 PM
ezlotogura's Avatar
Quoted: 274 Post(s)
Liked: 119
Well I use control4. I've had this matrix for a few years. Lately I am having audio issues, and C4 is currently investigating my project. No idea if its the C4 controller/streaming services/bad driver or the CMX switch. But I got my CMX switch used and like I said ~4 years ago, so who knows who hold it is and its held over just fine
I have no idea what it takes to program the hex/IR codes outside of control4. Mine has the ethernet board so c4 talks to it via IP control.
post #6 of 7 Old 03-13-2020, 12:16 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 2
I did a lot of research on all the options. I decided there is no need for me to get a matrix switch as I will be feeding all the zones by streaming services and plex. A matrix switch would still require me to buy a streaming device for each zone, so I am just going to get a few and plug them right into the amp inputs, using a bus for half the zones and line in for the other half.
speakerz is offline
post #7 of 7 Old 04-21-2020, 12:58 AM
Liked: 0
I've had the best luck with "No Hassle Audio Video" on Amazon lately. 18gbps 4K HDR with no issues
Ethan07 is offline
Reply Home A/V Distribution
